datasheet
STM32F4系统时钟设置之二
2019-06-13来源: eefocus关键字:STM32F4  系统时钟  设置
STM32F407系统时钟配置
时钟树
方法一,采用官方库提供的配置(这里外部晶振25MHz,系统配置为168MHz)
STM32F4启动与STM32F10X不同,时钟已经默认配置好
启动代码,文件:startup_stm32f4xx.s
Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
        IMPORT  SystemInit
        IMPORT  __main
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
可以看出,在进入main函数之前,系统调用了SystemInit函数.
SystemInit函数分析:SystemInit函数位于system_stm32f4xx.c文件中.此文件提供几个宏定义可以设置各个时钟:
/************************* PLL Parameters *************************************/
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
#define PLL_M      25
#define PLL_N      336
/* SYSCLK = PLL_VCO / PLL_P */
#define PLL_P      2
/* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
#define PLL_Q      7
而晶振频率则是在文件stm32f4xx.h中进行设置:
外部晶振:
#if !defined  (HSE_VALUE)
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
内部晶振:
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)16000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
综上,可以得出默认配置中:
锁相环压腔振荡器时钟PLL_VCO = 25 / 25 * 336 = 336MHz
系统时钟SYSCLK = 336 / 2 = 168MHz
USB,SD卡时钟 = 336 / 7 = 48MHz
SystemInit函数代码:
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the
  *         SystemFrequency variable.
  * @param  None
  * @retval None
void SystemInit(void)
  /* FPU settings ------------------------------------------------------------*/
  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
    SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
  #endif
  /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset CFGR register */
  RCC->CFGR = 0x00000000;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset PLLCFGR register */
  RCC->PLLCFGR = 0x24003010;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
#ifdef DATA_IN_ExtSRAM
  SystemInit_ExtMemCtl();
#endif /* DATA_IN_ExtSRAM */
  /* Configure the System clock source, PLL Multiplier and Divider factors,
     AHB/APBx prescalers and Flash settings ----------------------------------*/
  SetSysClock();
  /* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
SetSysClock函数分析,在SetSysClock函数中,配置了系统时钟,PLL倍频以及分频系数:
  * @brief  Configures the System clock source, PLL Multiplier and Divider factors,
  *         AHB/APBx prescalers and Flash settings
  * @Note   This function should be called only once the RCC clock configuration
  *         is reset to the default reset state (done in SystemInit() function).
  * @param  None
  * @retval None
static void SetSysClock(void)
/*            PLL (clocked by HSE) used as System clock source                */
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode, System frequency up to 168 MHz */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    /* Wait till the main PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
  else
  /* If HSE fails to startup, the application will have wrong clock configuration. User can add here some code to deal with this error */
如果外部时钟启动失败,系统会使用内部时钟
默认配置:
HCLK = SYSCLK / 1 = 168MHz
PCLK2 = HCLK / 2 = 84MHz
PCLK1 = HCLK / 4 = 42MHz
方法二,根据需要重新进行配置(这里外部晶振25MHz,系统配置为168MHz)
自己根据自己外部晶振大小和需要进行配置
void RCC_Config(void)
    RCC_DeInit();    //RCC寄存器初始化
    RCC_HSEConfig(RCC_HSE_ON);    //使用外部时钟
    if(RCC_WaitForHseStartUp() == SUCCESS)     //等待外部时钟启动
        RCC_PLLCmd(DISABLE);    //配置PLL前应先关闭主PLL
        RCC_SYSCLKConfig(RCC_SYSCLKSOURCE_PLLCLK);    //选择PLL时钟为系统时钟
        RCC_HCLKConfig(RCC_SYSCLK_Div1);    //HCLK(AHB)时钟为系统时钟1分频
        RCC_PCLK1Config(RCC_HCLK_Div4);    //PCLK(APB1)时钟为HCLK时钟8分频
        RCC_PCLK2Config(RCC_HCLK_Div2);    //PCLK(APB2)时钟为HCLK时钟2分频
        RCC_PLLConfig(RCC_PLLSource_HSE,25,336,2,7);    //PLL时钟配置,外部晶振为25MHz,系统配置为168MHz
        RCC_PLLCmd(ENABLE);    //PLL时钟开启
while(RCC_GetFlagStatus(RCC_FLAG_PLLRD
[1] [2]
关键字:STM32F4  系统时钟  设置
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/ic464497.html
上一篇:STM32软件复位的实现方法
下一篇:STM32F407时钟设置
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32F030R8-Nucleo使用PA2、PA3 UART2不能使用的问题
1. 开发环境开发平台:官方开发板STM32F030R8-Nucleo开发软件:Keil uVision5.24开发库:STM32Cube_FW_F0_V1.9.02. 实验现象根据官方例程,将UART1的配置更改为UART2,然后使用杜邦线接到PA2、PA3引脚,可串口就是无法收发数据。之后查看原理图发现,官方的Demo板,默认就没有将PA2、PA3扩展到外部引脚上,而是将这个USART2串口连接到了ST-Link的串口上,这样,ST-Link既可以下载程序,也可以当做开发板的USART2使用。截取部分具体电路图如下:其中SB14、SB13、SB63和SB62都是零欧姆电阻,问题就在这里了,SB14、SB13焊接了,但是SB63
发表于 2019-06-14
基于Ymodem协议的STM32F407的串口IAP
发送数据。成功接收的不会被确认。有错误的块被确认(NAK),并重发。Ymodem类似于Xmodem-1K,不同之处是提供批处理模式(batch mode)。在批处理模式下,可以使用一个命令发送一些文件。Ymodem使用循环冗余码校验作为错误校验方式。——摘自百度百科基于Ymodem协议的IAP引导程序硬件平台原子探索者STM32F407开发板通信接口串口实现流程按住复位键时按下KEY1键,在松开复位键之前按住KEY1不放,松开复位键,红色LED灯常亮,这时便进入固件升级程序,不断向上位机发送字符’C’请求上位机发送应用程序固件。这时打开上位机查询请求,上位机接收到请求后,通过串口发送第一个数据包,这个数据包主要包含了传输的文件的文件名和文
发表于 2019-06-14
STM32F10xxx支持三种复位
STM32F10xxx支持三种复位形式,分别为系统复位、上电复位和备份区域复位。一、系统复位除了时钟控制器的RCC_CSR寄存器中的复位标志位和备份区域中的寄存器(见图4)以外,系统复位将复位所有寄存器至它们的复位状态。当发生以下任一事件时,产生一个系统复位:1. NRST引脚上的低电平(外部复位) 2.  窗口看门狗计数终止(WWDG复位) 3.  独立看门狗计数终止(IWDG复位) 4.  软件复位(SW复位) 5.  低功耗管理复位可通过查看RCC_CSR控制状态寄存器中的复位状态标志位识别复位事件来源。软件复位通过将Cortex™-M3中断应用
发表于 2019-06-14
STM32F10xxx支持三种复位
一则STM32f103莫名反复复位的经验记录
最近在调试STM32F103RBT6时,发现只要一打开AD就会反复复位,将断点设置到启动代码处,发现复位是非常有规律的,总是执行过断点后就又回到断点了。找原理,查硬件,一切均没有问题。最后怀疑到代码上来,因为AD采样是另外一个产品中正常使用移植过来的,分为三大部分:对AD涉及到的外设和存储等的初始化,对AD的采集与存储(主要是中断),对AD的数据进行计算分析。将三大模块全部注释后再逐一开放,发现是对AD的初始化会导致复位。对AD的初始化代码再全部注释后逐一开放,发现是启动定时器TIM4的代码会导致复位。后来将与定时器有关的代码全部审查了一遍,也没有发现问题,同样的相似代码在TIM1上工作的很好。查网上的相似问题,也没有改善
发表于 2019-06-14
STM32F4的CCM内存之一
我们知道STM32F4当中有个CCM内存,如图所示,这个内存是挂在D总线上直接和内核相连,因此除了内核之外谁都不能访问,那么我们怎么将其利用起来呢? 首先,我们可以使用Keil的设置选项,将IRAM2打勾,让编译器选择什么时候使用这个内存。显然,我们还可以将这两个地址修改一下,将IRAM1改为0x10000000,这样,编译器就会优先分配CCM内存。 我们来看看结果,在MAP文件中,表明确实使用了这段内存,但是因为我们使用的内存较少, 还没有用到CCM。 这种自动分配的方式有什么问题呢?这段内存是内核专有的,除了内核任何其它总线都不能访问,这就意味着,一旦编译器将数据分配到CCM中,而同时使用了DMA
发表于 2019-06-14
STM32F4的CCM内存之一
STM32F4的CCM之二
前言有客户用STM32F427芯片,程序将CSTACK放在CCM RAM中,结果测试过一段时间的板子都出现了不能正常运行的情况。这个现象一度让我们怀疑是否是CCM RAM在测试过程中遭到了破坏,导致我们在解决问题的道路上浪费了不少时间。事实证明STM32的CCM RAM并没有那么脆弱,而解决问题时尽力从多个角度进行验证,不放过所有可能出问题的环节之心态更为重要。在具体讨论问题的原因之前,不妨先介绍一下STM32F4/STM32F3系列芯片上的CCM RAM。CCM RAM介绍ST的STM32F303, STM32F358, STM32F328, STM32F334系列和STM32F4的Advanced line系列芯片里都有CCM
发表于 2019-06-13
STM32F4的CCM之二
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
