1602液晶电子时钟程序
2018-01-14 20:22:04编辑:什么鱼 关键字:1602液晶  电子时钟
连线图:
; DB0---DPROT.0 DB4---DPROT.4 RS-------------P1.2
; DB1---DPROT.1 DB5---DPROT.5 RW-------------P1.3
; DB2---DPROT.2 DB6---DPROT.6 E--------------P1.4
; DB3---DPROT.3 DB7---DPROT.7 VLCD接10K可调电阻到GND*
#include "reg52.h"//头文件
#include "intrins.h"
#define uchar unsigned char//宏定义
#define uint unsigned int//宏定义
sbit RS=P1^2;//定义I/O的硬件接口
sbit RW=P1^3;
sbit E=P1^4;
sbit LED_1=P1^7;//;;;LED秒闪烁
uchar Hours=0;//定义小时
uchar Minutes=0;//定义分钟
uchar Seconds=0;//定义秒
bit Seconds_Scintillation=1;//定义秒闪烁标志
#define DPDR P0//并行数据接口定义
uchar code DispTab_1[]={'0','1','2','3','4','5','6','7','8','9'};//1602:0-9 数字
uchar code DispTab_2[]={'A','B','C','D','E','a','b','c','d','e'};//1602:A-e 字母
uchar DispBuf[8]; //8字节的显示缓冲区
char char_char_1[]={" www.mdizi.com "};//定义字符串
char char_char_2[]={" "};//定义空字符串
void delay(uint z)//1ms延时
uchar x,x1;
for(;z>0;z--)
for(x=0;x<114;x++)
for(x1=0;x1<1;x1++);
void Timer0() interrupt 1
statIC uchar Count_50;//
uchar temp;
TH0=0xb7;
TL0=0xff;//定时时间为20ms,每20ms中断一次
Count_50++;
if(Count_50==50)//20ms*50=1秒
{ Seconds_Scintillation=~Seconds_Scintillation;
led_1=~led_1;
Count_50=0;
Seconds++;
if(Seconds==60)
Seconds=0;
Minutes++;
if(Minutes==60)
Minutes=0;
Hours++;
if(Hours==24)
Hours=0;
if(Seconds_Scintillation==1)//秒闪烁标志判断
DispBuf[6]=':';
else
DispBuf[6]=' ';
DispBuf[0]=Hours/10;//转换成10进制显示
DispBuf[1]=Hours%10;
DispBuf[2]=Minutes/10;
DispBuf[3]=Minutes%10;
DispBuf[4]=Seconds/10;
DispBuf[5]=Seconds%10;
temp=DispBuf[0];
DispBuf[0]=DispTab_1[temp];//查表取字符
temp=DispBuf[1];
DispBuf[1]=DispTab_1[temp];
temp=DispBuf[2];
DispBuf[2]=DispTab_1[temp];
temp=DispBuf[3];
DispBuf[3]=DispTab_1[temp];
temp=DispBuf[4];
DispBuf[4]=DispTab_1[temp];
temp=DispBuf[5];
DispBuf[5]=DispTab_1[temp];
void write_Directive(uchar a)//写指令
RS=0;
RW=0;
delay(1);
E=0;
DPDR=a;
delay(1);
E=1;
delay(1);
E=0;
delay(1);
void write_Data(uchar a)//写数据
RS=1;
RW=0;
delay(1);
E=0;
DPDR=a;
delay(1);
E=1;
delay(1);
E=0;
delay(1);
void init()//初始化
{ uchar i;
TMOD=0x01;
TH0=0xb7;
ET0=1; //开T0中断
EA=1; //开总中断
TR0=1; //T0开始运行
DispBuf[6]=':';
delay(15);
write_Directive(0x38);
delay(5);
delay(5);
write_Directive(0x01);
write_Directive(0x02);//初始化后数据地址为0x80;即第一行,第一个位置
write_Directive(0x0c);//不显示光标
write_Directive(0x80+0x40);//第二行第一位地址
for(i=0;i<16;i++)
write_Data(char_char_1[i]);//显示字符串" www.mdizi.com "
void write_Data_String()//显示时间函数
write_Directive(0x80+0x04);//第一行,第五个位置地址
write_Data(DispBuf[0]);//第一行,第五个位置
write_Data(DispBuf[1]);//第一行,第六个位置
write_Data(DispBuf[6]);//第一行,第七个位置
write_Data(DispBuf[2]);//第一行,第八个位置
write_Data(DispBuf[3]);//第一行,第九个位置
write_Data(DispBuf[6]);//第一行,第十个位置
write_Data(DispBuf[4]);//第一行,第十一个位置
write_Data(DispBuf[5]);//第一行,第十二个位置
void main()
init();
while(1)
write_Data_String();//调用写连续的 16 个字符,1表示第一行;2表示第二行
delay(100);//延时 100ms,扫描一次
液晶显示器以其微功耗、体积小、显示内容丰富、超薄轻巧的诸多优点,在袖珍式仪表和低功耗应用系统中得到越来越广泛的应用。
这里介绍的字符型液晶模块是一种用5x7点阵图形来显示字符的液晶显示器,根据显示的容量可以分为1行16个字、2行16个字、2行20个字等等,这里以常用的2行16个字的DM-162液晶模块来介绍它的编程方法。
DM-162采用标准的14脚接口,其中VSS为地电源,VDD接5V正电源,V0为液晶显示器对比度调整端,接正电源时对比度最弱,接地电源时对比度最高,对比度过高时会产生“鬼影”,使用时可以通过一个10K的电位器调整对比度。RS为寄存器选择,高电平时选择数据寄存器、低电平时选择指令寄存器。RW为读写信号线,高电平时进行读操作,低电平时进行写操作。当RS和RW共同为低电平时可以写入指令或者显示地址,当RS为低电平RW为高电平时可以读忙信号,当RS为高电平RW为低电平时可以写入数据。E端为使能端,当E端由高电平跳变成低电平时,液晶模块执行命令。D0~D7为8位双向数据线。
DM-162液晶模块内部的字符发生存储器(CGROM)已经存储了160个不同的点阵字符图形,如表1所示,这些字符有:阿拉伯数字、英文字母的大小写、常用的符号、和日文假名等,每一个字符都有一个固定的代码,比如大写的英文字母“A”的代码是01000001B(41H),显示时模块把地址41H中的点阵字符图形显示出来,我们就能看到字母“A”
DM-162液晶模块内部的控制器共有11条控制指令,如表2所示,
它的读写操作、屏幕和光标的操作都是通过指令编程来实现的。(说明:1为高电平、0为低电平) 指令1:清显示,指令码01H,光标复位到地址00H位置 指令2:光标复位,光标返回到地址00H 指令3:光标和显示模式设置 I/D:光标移动方向,高电平右移,低电平左移 S:屏幕上所有文字是否左移或者右移。高电平表示有效,低电平则无效 指令4:显示开关控制。 D:控制整体显示的开与关,高电平表示开显示,低电平表示关显示 C:控制光标的开与关,高电平表示有光标,低电平表示无光标 B:控制光标是否闪烁,高电平闪烁,低电平不闪烁 指令5:光标或显示移位 S/C:高电平时移动显示的文字,低电平时移动光标 指令6:功能设置命令 DL:高电平时为4位总线,低电平时为8位总线 N:低电平时为单行显示,高电平时双行显示 F: 低电平时显示5x7的点阵字符,高电平时显示5x10的点阵字符 指令7:字符发生器RAM地址设置 指令8:DDRAM地址设置 指令9:读忙信号和光标地址 BF:为忙标志位,高电平表示忙,此时模块不能接收命令或者数据,如果为低电平表示不忙。 指令10:写数据 指令11:读数据
DM-162液晶显示模块可以和 单片机 AT89C51直接接口,电路如图1所示。
液晶显示模块是一个慢显示器件,所以在执行每条指令之前一定要确认模块的忙标志为低电平,表示不忙,否则此指令失效。要显示字符时要先输入显示字符地址,也就是告诉模块在哪里显示字符,表3是DM-162的内部显示地址.
关键字:1602液晶  电子时钟
来源: eefocus 引用地址:http://www.eeworld.com.cn/mcu/article_2018011437348.html
上一篇:PDIUSBD12 USB 驱动程序
下一篇:24C32~24C512的51单片机读写程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
1602液晶显示屏显示字符
本次实验的效果为实现特定字符在1602液晶显示屏上流动显示所用开发板为普中科技开发板,电路图如下:代码如下:#include<reg51.h>#define uchar unsigned char#define uint unsigned int  sbit rs = P2^6;sbit rw = P2^5;sbit lcden = P2^7;  unsigned char table1[16] = " Pechin Science ";unsigned char table2[27] = "Welcome to the world of
发表于 2018-07-14 20:39:12
总统助阵:液晶显示会回迁美国吗
6月28日,对于一直鼓吹制造业回迁美国的特朗普而言,是一个可以纪念的日子——美国总统亲自出席威斯康星州鸿海富士康液晶面板项目的“动工典礼“。这也是首次有大国元首莅临大型液晶显示项目的动工现场。  随着富士康美国项目的动工,一个非常有意思的话题也被关注起来:即,液晶制造会“回流”美国吗?对此,大屏君认为,从产业链、市场的角度加以分析,要比看特朗普的脸色更“科学”。  美国——液晶显示强国  显然,在富士康项目之前,全球主要的液晶显示项目集中在东亚地区:日本、我国台湾省、韩国和我国大陆地区。其中,近5年来主要新增产能集中在我国大陆地区;日本地区则处于“去产能”阶段,东芝、日立、松下先后退出或者削减液晶面板产能,夏普被台湾富士康系收入
发表于 2018-07-04 18:03:21
总统助阵:液晶显示会回迁美国吗
OLED电视或能降价30% 印刷式OLED成秘密武器
近日,日本面板供应商JOLED宣布在日本石川县能美市设立JOLED能美事业所,同时收购另一日本面板厂JDI旗下的能美工厂,以量产采用印刷式技术的OLED面板。能美工厂是JDI去年关停的5.5代面板线。在今年JOLED接手后,将改造成月产能2万片的印刷式OLED产线。  JOLED的印刷式OLED工艺是一种将液态发光材料像打印机墨水一样喷涂在基板上的生产工艺。早在2017年底,JOLED就已拿出采用印刷式OLED面板的产品。这是一块21.6英寸的面板,分辨率为3840x2160(4K,204 PPI),亮度为350nits,整个面板厚度仅为1.3毫米,重量仅为500克。据悉这块屏幕目前已经被索尼所承包,会率先应用到医疗领域
发表于 2018-07-04 18:00:44
三星LGD面板受国产厂商冲击 后者股价几乎腰斩
在大尺寸TV液晶面板的市场占有率和综合竞争力。  预计2019年上半年,该生产线将满产。  2017年12月20日,BOE(京东方)合肥第10.5代TFT-LCD生产线提前投产。图源:搜狐  新华社当时报道称,该10.5代线是全球最高世代线,也是全球首条10.5代线,设计产能为每月12万片玻璃基板。  在该生产线产品下线暨客户交付仪式上,京东方向三星、LG、SONY、Vizio、创维、康佳、海信、长虹、TPV、小米、海尔等交付了75英寸8K 60Hz、75英寸8K 120Hz等大尺寸超高清显示屏。  京东方高级副总裁张宇当时自信地说:“(这条线的投产)让中国在全球显示技术和规模上成为领跑者,(京东方在8K显示领域)现在没有竞争对手
发表于 2018-06-28 17:56:15
DS1302时钟与LCD1602液晶显示
,此过程I/O数据不会变化,而在低电平的过程中I/O数据进行改变;而到后8个时钟会读数据,对于SCLK的控制与前8个时钟相反。对于写数据的过程与读的过程相似只是后面读写的SCLK时钟控制信号不同。DS1302的时钟寄存器如下:    第6位用来选择时钟或RAM,第0位用来做读写的选择,对于第1、2、3为从000到111依次对应秒、分、时、日、月、周、年和控制字地址。LCD1602液晶    LCD1602它是一种专门用来显示字母、数字、符号等的点阵型液晶模块。用它来显示需要的字母、数字和符号等会比数码管和LED点阵都要方便。LCD1602的引脚图如下:    引脚
发表于 2018-06-25 21:56:15
51单片机1602液晶显示移动显示
(i=0;i<n;i++)    delaylms();  }  /****** 函数功能;判断液晶模块的忙碌状态 返回值:result。result=1,忙碌;result=0,不忙碌**********/  uchar busytest(void)  {   bit result;   RS=0;  //RS为低电平RW为高电平,可以读状态   RW=1;   E=1;   //E=1允许写   _nop_();
发表于 2018-06-25 20:17:55
小广播
何立民专栏
单片机及嵌入式宝典
