LED16*16点阵滚动显示程序
2018-01-14 20:20:24编辑:什么鱼 关键字:LED  16*16点阵  滚动显示
功能:LED16*16点阵滚动显示
说明:74LS164用作发送数据,P0,P2口用来列选
看本程序最好的工具最好旁边有标号和语法着色,推荐keil或UltraEdit
懒人提示:要改成自己所要的显示内容,要怎么改?
1.要改显示内容改第23~92行代码,还有第119行代码,具体改法见下面注释
2.要改滚动速度改第102行代码
/*头文件*/
#include
#include
/*宏定义*/
#define uchar unsigned char
#define uint  unsigned int
/*函数声明*/
void delay();
/*全局变量*/
uint lie; //列选标志
/** 字模:反显,纵向取模,开头和结尾均加入32个0xFF,用于改善屏滚动显示时循环的连贯性   **/
/** 杭州市公交公司K316路,开往武林广场,发车时间20:30,欢迎大家乘坐!  --  **  宋体, 12  **/
/** 当前所选字体下一个汉字对应的点阵为:  宽度x高度=496x16,  调整后为: 496x16          **/
uchar code text[1056]={   //这里的数据为你要显示的内容的数据量+64(前后各32个0xff)
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
//改显示内容以上两行别改
0xEF,0xDF,0xEF,0x3F,0xE8,0xFF,0x00,0x00,0xED,0xFF,0xFE,0xFD,0xEF,0xF3,0xEC,0x0F,
0x6D,0xFF,0x8D,0xFF,0xED,0xFF,0xEC,0x03,0xEF,0xFD,0xEF,0xFD,0xEF,0xE1,0xFF,0xFF,
0xFF,0x7F,0xF8,0xFE,0xFF,0xF9,0xFF,0xE7,0x00,0x1F,0xFB,0xFF,0xFC,0xFF,0xFF,0xFF,
0x80,0x01,0xF7,0xFF,0xF9,0xFF,0xFE,0x7F,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xD8,0x03,0xDB,0xFF,0xDB,0xFF,0x5B,0xFF,0x80,0x00,
0xDB,0xFF,0xDB,0xFF,0xDB,0xF7,0xDB,0xFB,0xD8,0x07,0xDF,0xFF,0xDF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0x7F,0xFE,0xFB,0xFD,0xF1,0xF3,0xEB,0x8F,0xDB,0xDE,0x3B,0xFF,0x73,
0xFF,0xF7,0x8F,0xF7,0xF7,0xD7,0xF9,0xE1,0xFC,0xF3,0xFE,0x7F,0xFE,0xFF,0xFF,0xFF,
0xFF,0xFF,0xEF,0xFE,0xEE,0xFE,0xED,0xFD,0xE3,0x7D,0xEB,0xBB,0x6F,0xD7,0x8F,0xE7,
0xCF,0xCF,0xEF,0x97,0xE6,0x3B,0xEB,0x79,0xE9,0xFC,0xED,0xFD,0xEF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xF7,0xFF,0xB6,0x07,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,0xB6,0xDF,
0xB6,0xDF,0xB6,0x0F,0xB7,0xFF,0xBF,0xFB,0xBF,0xFD,0x80,0x03,0xFF,0xFF,0xFF,0xFF,
0xEF,0xFB,0xE0,0x03,0xEE,0xFB,0xFC,0x7F,0xEB,0x9B,0xE7,0xE3,0xEF,0xFB,0xFF,0xFF,
0xFF,0xFF,0xF3,0xE7,0xEF,0xFB,0xEE,0xFB,0xEE,0xFB,0xED,0x77,0xF3,0x8F,0xFF,0xFF,
0xFF,0xFF,0xF7,0xFB,0xF7,0xFB,0xE0,0x03,0xFF,0xFB,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xF8,0x0F,0xF7,0x77,0xEE,0xFB,0xEE,0xFB,0xE7,0x77,0xFF,0x8F,0xFF,0xFF,
0xFF,0xFB,0x81,0x03,0xBB,0xFB,0xB8,0x07,0x83,0x77,0xFB,0x77,0xF7,0xBF,0xEF,0x01,
0x0F,0x3B,0xD2,0xBB,0xDD,0xBB,0xDA,0xBB,0xC6,0x81,0xDF,0x3F,0xFF,0x7F,0xFF,0xFF,
0xFF,0xFE,0xFF,0xF2,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFD,0xFF,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xCF,0x80,0x3F,0xBD,0xFF,0xBD,0xFF,
0xBD,0xFF,0xBD,0xFF,0x80,0x01,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,
0xFB,0xBF,0xF7,0x7F,0xEE,0xFF,0x10,0x00,0xBB,0xFF,0xEF,0xFD,0xEF,0x7D,0xEF,0x7D,
0x6F,0x7D,0x80,0x01,0xAF,0x7D,0xEF,0x7D,0xEF,0x7D,0xEF,0x7D,0xEF,0xFD,0xFF,0xFF,
0xF7,0xFD,0xF7,0xFD,0xD7,0x01,0xD7,0xFB,0xD7,0xFB,0xD4,0x07,0xD7,0x77,0xD7,0x77,
0xF7,0x7F,0x01,0xFF,0xF6,0x1F,0xB7,0xE7,0xD7,0xFB,0xF7,0xFD,0xF7,0xF0,0xFF,0xFF,
0xF7,0xEF,0xF7,0x9F,0xF6,0x7F,0x00,0x00,0xF6,0xFF,0xF7,0x37,0xFF,0xEF,0xF7,0xDF,
0xF7,0x3F,0xF4,0xFF,0x00,0x00,0xF6,0x7F,0xF7,0x9F,0xF7,0xE7,0xF7,0xEF,0xFF,0xFF,
0xFF,0xFD,0xFF,0xF3,0xC0,0x0F,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0x5F,0xFF,
0x9F,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xFF,0xFF,
0xF7,0xEF,0xF7,0xE7,0xF7,0xEF,0x00,0x1F,0xF7,0xDF,0xF7,0xBF,0xBF,0xAD,0xBD,0xDB,
0xB9,0xB7,0xB4,0x6F,0xAD,0x9F,0x9C,0x7D,0xBD,0xFE,0xF8,0x01,0xFD,0xFF,0xFF,0xFF,
0xFF,0xFD,0xF7,0xFB,0x83,0xF7,0xF7,0xEE,0xF7,0x1E,0xF0,0x7D,0x06,0x9D,0xF6,0xEB,
0xF6,0xF7,0xB6,0xEB,0xD6,0x1B,0xC7,0xFD,0xF7,0xFC,0xF7,0xFD,0xF7,0xFF,0xFF,0xFF,
0xFF,0xDF,0xDF,0xDF,0xDE,0xDF,0xDC,0xDF,0xDA,0xDF,0xC6,0xDF,0x1E,0xDF,0xDE,0xDF,
0xD0,0x00,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xDE,0xDF,0xFF,0xDF,0xFF,0xFF,
0xFF,0xFF,0xC0,0x1F,0xDD,0xDF,0xDD,0xDF,0xDD,0xDF,0xC0,0x1F,0xF7,0xFF,0xF6,0xFF,
0xF7,0x3F,0xF7,0xFD,0xF7,0xFE,0x00,0x01,0xF7,0xFF,0xF7,0xFF,0xF7,0xFF,0xFF,0xFF,
0xFF,0xFF,0xE0,0x00,0x7F,0xFF,0x9F,0xFF,0xFF,0xFF,0xF0,0x1F,0xB6,0xDF,0xB6,0xDF,
0xB6,0xDF,0xB6,0xDF,0xB0,0x1F,0xBF,0xFD,0xBF,0xFE,0x80,0x01,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xF1,0xF3,0xEF,0xEB,0xEF,0xDB,0xEF,0xBB,0xEE,0x7B,0xF1,0xF3,0xFF,0xFF,
0xFF,0xFF,0xF8,0x0F,0xF7,0xF7,0xEF,0xFB,0xEF,0xFB,0xF7,0xF7,0xF8,0x0F,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xF3,0xFC,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xD7,0xFB,0xDB,0xF7,0xDD,0xCD,0xDE,0x3D,0xD9,0x3D,0xC7,0xCB,0xFB,0xFB,0xE7,0xF7,
0x0F,0xCF,0xE8,0x3F,0xEF,0x9F,0xEF,0xE7,0xEB,0xF3,0xE7,0xF9,0xEF,0xFB,0xFF,0xFF,
0xFD,0xFD,0x7D,0xFB,0x8C,0x07,0xDF,0xFB,0xFF,0xFD,0xC0,0x1D,0xDF,0xBD,0xBF,0x7D,
0xBF,0xFD,0xC0,0x05,0xDF,0xFD,0xDF,0xBD,0xDF,0xDD,0xC0,0x3D,0xFF,0xFD,0xFF,0xFF,
0xFB,0xFF,0xFB,0xFE,0xFB,0xFD,0xFB,0xFB,0xFB,0xF7,0xFB,0xCF,0xFA,0x3F,0x01,0xFF,
0xFA,0x7F,0xFB,0x9F,0xFB,0xEF,0xFB,0xF3,0xFB,0xF9,0xFB,0xFC,0xFB,0xFD,0xFF,0xFF,
0xFF,0xFF,0xE7,0x6B,0xDF,0x6B,0xD7,0x57,0xD6,0xD7,0xD6,0xAD,0x54,0x6E,0x92,0xDD,
0xD7,0x03,0xD7,0x9F,0xD6,0x6F,0xDF,0x6F,0xD7,0xF7,0xCF,0xF3,0xDF,0xF7,0xFF,0xFF,
0xEF,0xBB,0xEB,0xBB,0xAB,0x77,0xAB,0x77,0xA0,0x2F,0xAF,0xCF,0xAF,0x9F,0x80,0x01,
0xAF,0xBF,0x6F,0xDF,0x60,0x4F,0x6D,0x67,0x6B,0x73,0xCB,0x77,0xEE,0x7F,0xFF,0xFF,
0xFF,0x7D,0xFE,0xFD,0xF9,0xDD,0xC7,0xDD,0xFB,0xDD,0xFC,0xDD,0xFF,0xDD,0x00,0x01,
0xFF,0x5D,0xFE,0xDD,0xFD,0xDD,0xC3,0xDD,0xFD,0xDD,0xFE,0xFD,0xFF,0xFD,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
//改显示内容以下两行别改
/*主函数*/
void main()
{uchar i,j;
 uint m=0;//m是从字模数组里向后取数据时的计数器,用以改变显示文字的内容,及滚动显示效果
 SCON=0;  //初始化串口为工作方式0(同步通信方式,TxD输出同步脉冲)
 lie=0x7fff; //列选标志初始化
 while(1) //重复循环显示
 {for(j=0;j<10;j++) //j用来控制屏上1帧显示内容停留的时间,即用来控制滚动速度
 { for(i=1;i<=31;i+=2)
    {P0=0xff;//先关显示,以免164内数据移动过程中在屏上产生不良影响,大家可以把这两句去掉比较下显示效果
     P2=0xff;
     SBUF=text[i+m];//从串口发送字模数据(为什么要先发后一个数据,看下电路应该会明白吧:)
     while(TI==0);  //等待发送完毕
     TI=0;
     SBUF=text[i+m-1];//从串口发送数据,补全整一列数据
     while(TI==0);
     TI=0;
  P0=lie%256;//选中要显示的那列,同时等于打开了那列的显示
     P2=lie/256;
     delay(); //延时,等待一段时间,让这列显示的内容在人眼内产生“视觉暂留”现象,略知生理的人应该都知道吧。
  lie=_iror_(lie,1); //列选标志移位,准备用来选中下一列
  }//返回显示下一列,直到16列都显示完成
  m+=2;//显示内容向后移一列
  if(m>1024)//这个数据为你的字模数组的大小-32,我的是1056-32=1024
  m=0;
/*延时子程序*/
void delay()
{uint n;
 for(n=0;n<90;n++)
来源: eefocus 引用地址:http://www.eeworld.com.cn/mcu/article_2018011437346.html
上一篇:89C51串并转换驱动数码管示例程序
下一篇:PDIUSBD12 USB 驱动程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
51单片机实现LED流水灯(数组方式和位运算方式)
/* 名称:51单片机实现LED流水灯(数组方式和位运算方式)说明:今天又重新开始系统的学习51了,LED就算个开端吧。 要注意两点: 1、sfr和sbit是C语言扩展出来的关键字。其中sfr用于对特殊功能寄存器进行声明,sbit用于对某些特殊功能寄存器的某位进行声明。这里和宏定义很相似,但是不能用宏定义进行替换,对于前者是因为51单片机的寄存器存在于内部空间0x80-0xFF,这空间属于直接寻址,51特殊功能寄存只能直接寻址,不能间接寻址。如果用宏定义的话,在翻译成汇编时就会认为是通过总线访问对应的外部地址了。对于后者,sbit是定义一个标志位,也叫位变量。而类似于#define key1 P3
发表于 2018-07-21 13:08:22
S3C2440学习之GPIO按键控制LED灯
/* 名称:S3C2440学习之GPIO按键控制LED灯 说明:这是实验2440GPIO的输入功能。基本的流程和51单片机开发的差不多。都是对GPIO端口寄存器的控制不同的是,51单片机可以直接对进行位控制,而2440中GPIO只能对32位的寄存器进行写入或者读出。这样的话,对于有些逻辑操作要稍微复杂点。还有个不同的是,无论是STM32还是51在进行IO按键输入的时候,都需要进行按键消抖,在这里却没又体现出来按键消抖,这是为什么呢?据我了解是这样,在进行51和STM32实验的时候,按键控制的是数码管(数字增加,降低),所以按键的机械抖动会给数码管数字的变化带来显著的影响。在这里是按键控制led灯的亮和灭
发表于 2018-07-21 11:58:46
STM32定时器之控制LED灯循环显示
/* 名称:STM32定时器之控制LED灯循环显示 说明:对于STM32来说,其定时器要比C51的定时器要多,功能也更复杂。就数目来说来说,STM32的定时器可以分为基本定时器,通用定时器和高级定时器(还包括Systick、看门口定时器和窗口定时器)。就STM32F103,一般来说,它有2个高级定时器TIM1和TIM8、4个通用定时器TIM2/3/4/5、2个基本定时器TIM6和TIM7。而C51一般只有几个定时器。就功能来说, STM32中: 对于基本定时器,其功能就是和C51差不多,只有定时功能。 对于通用定时器,它的功能有定时、输出比较、输入捕获。虽然目前,我也不知道后面两个
发表于 2018-07-21 11:56:24
STM32之LED按键中断
****************************************************************************************************************************************前言:本文主要是通过按键中断,实现当按下按键时,LED灯灭,释放按键时,LED灯亮。(不过我设置LED的起始状态为亮,也就是上电就点亮了LED灯。)下面看main.c#include "stm32f10x.h"#include "led.h"#include "exti.h"  int main(void) {     init_led_gpio();  turn_led(LED1,ON);    /*exti line
发表于 2018-07-21 11:48:43
ARM裸机程序开发——按键控制LED灯
这几天将TQ2440上的IO控制引脚学习了一下,了解了一下关于引脚的一些寄存器的配置,熟悉了一下写ARM裸机程序的流程,写一下自己学到的东西。★程序启动初始化◇关闭看门狗有一个专门的寄存器来控制看门狗,看门狗的作用就是在一定的时间内会重新启动系统,这里我们只是写一个简单的逻辑程序用不到看门狗 ,将其关掉。设置WTCON寄存器,将其第5位置0,就可以禁用看门狗◇设置栈指针C语言中设置的变量,以及调用的函数等信息都会被存放在栈中,因此栈指针必须要设置◇调用main函数main函数中设置了关于IO寄存器的一些设置操作★TQ2440硬件相关硬件主要涉及到LED灯与GPIO,按键与GPIO之间的连接◇LED灯硬件
发表于 2018-07-21 11:48:01
STM32实战1:按键点亮LED小灯
理论知识已经学习完成,之后我们进入实战篇,在实战的学习中,我完成了第一个项目,用按键点亮了led灯下面是我的程序led主程序#include "sys.h"#include "led.h"void LED_Init(void){GPIO_InitTypeDef GPIO_InitStructure;RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC , ENABLE);//初始化PCIO时钟GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;GPIO_InitStructure.GPIO_Speed
发表于 2018-07-21 11:17:40
小广播
何立民专栏
单片机及嵌入式宝典
