STM32启动过程详解
2017-09-13 19:21:54来源: eefocus 关键字:STM32  启动过程
一、STM32启动文件详细解析
STM32启动文件详细解析(V3.5.0) 以:startup_stm32f10x_hd.s为例
  1. ;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
  2. ;* File Name          : startup_stm32f10x_hd.s
  3. ;* Author             : MCD Application Team
  4. ;* Version            : V3.5.0
  5. ;* Date               : 11-March-2011
  6. ;* Description        : STM32F10x High Density Devices vector table for MDK-ARM
  7. ;*                      toolchain.
  8. ;*                      This module performs:
  9. ;*                      - Set the initial SP
  10. ;*                      - Set the initial PC == Reset_Handler
  11. ;*                      - Set the vector table entries with the exceptions ISR address
  12. ;*                      - Configure the clock system and also configure the external
  13. ;*                        SRAM mounted on STM3210E-EVAL board to be used as data
  14. ;*                        memory (optional, to be enabled by user)
  15. ;*                      - Branches to __main in the C library (which eventually
  16. ;*                        calls main()).
  17. ;*                      After Reset the CortexM3 processor is in Thread mode,
  18. ;*                      priority is Privileged, and the Stack is set to Main.
  19. ;* <<< Use Configuration Wizard in Context Menu >>>
  20. ;*******************************************************************************
  21. ; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  22. ; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
  23. ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
  24. ; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
  25. ; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
  26. ; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  27. ;*******************************************************************************
  28.
  29. ; Amount of memory (in bytes) allocated for Stack
  30. ; Tailor this value to your application needs
  31.  Stack Configuration                     ;栈定义
  32. ;    Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
  33. ;
  34.
  35. Stack_Size      EQU     0x00000400              ;EQU伪指令,作用是左边的符号名代表右边的表达式
  36.
  37.                 AREA    STACK, NOINIT, READWRITE, ALIGN=3   ;定义栈段:名称为STACK,未初始化,可读写,ELF 的栈段按2^3=8对齐
  38. Stack_Mem       SPACE   Stack_Size              ;分配一片连续的存储区域并初始化为 0,栈空间:0x400个字节
  39. __initial_sp                            ;栈空间顶地址
  40.
  41.
  42.  Heap Configuration                  ;堆定义
  43. ;     Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
  44. ;
  45.
  46. Heap_Size       EQU     0x00000200
  47.                 AREA    HEAP, NOINIT, READWRITE, ALIGN=3
  48.
  49. __heap_base                         ;堆空间起始地址
  50. Heap_Mem        SPACE   Heap_Size               ;堆空间:0x200个字节
  51. __heap_limit                            ;堆空间结束地址
  52.
  53.
  54.     PRESERVE8                       ;PRESERVE8 指令指定当前文件保持堆栈八字节对齐
  55.     THUMB                           ;告诉汇编器下面是32位的Thumb指令,如果需要汇编器将插入位以保证对齐
  56.
  57. ; Vector Table Mapped to Address 0 at Reset         ;中断向量表定义
  58.                                 ;实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
  59.                 AREA    RESET, DATA, READONLY           ;定义一块数据段,只可读,段名字是RESET
  60.                 EXPORT  __Vectors               ;EXPORT:在程序中声明一个全局的标号__Vectors,该标号可在其他的文件中引用
[1] [2] [3] [4] [5] [6] [7]
关键字:STM32  启动过程
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/article_2017091334410.html
上一篇:stm32编程配置一个I/O为EXTI中断的步骤
下一篇:STM32 ADC的规则通道和注入通道的区别
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
STM32
启动过程
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
何立民专栏
单片机及嵌入式宝典
