STM flash数据读取
2017-07-13 22:46:49来源: eefocus 关键字:STM  flash  数据读取
  1. ////
  2. /////////**************************.h文件*********************************///////////////////////////////////
  3. #ifndef _FLASH_CTRL_H_
  4. #define _FLASH_CTRL_H_
  5. #ifdef STM32F10X_HD
  6. #define FLASHADDRSTART 0x0807F800 //
  7. #define FLASHADDREND 0x08080000 //
  8. #elif STM32F10X_MD
  9. #define FLASHADDRSTART 0x0801FC00 //
  10. #define FLASHADDREND 0x0801FFFF //
  11. #elif STM32F10X_LD
  12. #define FLASHADDRSTART 0x08001000 //
  13. #define FLASHADDREND 0x080013FF   //
  14. #endif
  15.  #ifdef  STM32F10X_HD //大容量产品,flash>=256K
  16. #define FLASH_PAGE_SIZE    ((u16)0x800)//2K
  17. #elif STM32F10X_MD //小容量产品, flash <256K
  18. #define FLASH_PAGE_SIZE  ((u16)0x400)//1K
  19. #else
  20. #define FLASH_PAGE_SIZE  ((u16)0x400)//1K
  21. #endif
  22. #define UCHAR unsigned char
  23. #define CHAR  char
  24. #define ULONG unsigned long
  25. #define UINT unsigned int
  26. #define boolen UCHAR
  27. #ifndef true
  28. #define true 1
  29. #endif
  30. #ifndef false
  31. #define false 0
  32. #endif
  33. #define BLOCK_SIZE 64
  34. typedef struct _tagFLASHWORDBUFF
  35. {
  36.  ULONG ulItems[BLOCK_SIZE/4];
  37. }
  38. FLASHWORDBUFF;
  39. typedef struct _tagFLASHHALFWORDBUFF
  40. {
  41.  UINT ulItems[BLOCK_SIZE/2];
  42. }FLASHHALFWORDBUFF;
  43. typedef struct _tagFLASHBYTEBUFF
  44. {
  45.  UCHAR ulitems[BLOCK_SIZE];
  46. }
  47. FLASHBYTEBUFF;
  48. boolen writeFlash(UCHAR* str,UINT len);
  49. UINT readByteFlash(UINT len);
  50. UINT readHalfWordFlash(UINT len);
  51. UINT readWordFlash(UINT len);
  52. #endif
  53. /////////////////////////********************.c文件***************************///////////////////////////////////////////////
  54. /* Includes ------------------------------------------------------------------*/
  55. #include "flashctrl.h"
  56. #include "stm32f10x_flash.h"
  57. /* Private variables ---------------------------------------------------------*/
  58. vu32 NbrOfPage = 0x00;
  59. u32 EraseCounter = 0x00, Address = 0x00;
  60. volatile FLASH_Status FLASHStatus;
  61. FLASHBYTEBUFF flashBytebuff;
  62. FLASHHALFWORDBUFF flashHalfWrodbuff;
  63. FLASHWORDBUFF flashWordbuff;
  64. /* Public function------------------------------------------------------------*/
  65. /******************************************************************************
  66. * Function Name: writeFlash
  67. * Description  : Erease the range (FLASHADDREND - FLASHADDRSTART) of flash,and
  68. *                Write the string to it.
  69. * input        : the writed of string - str, the len of str
  70. * output       : write or erease success return 1, otherwise return 0.
  71. *******************************************************************************/
  72. boolen writeFlash(UCHAR* str,UINT len)
  73. {
  74.  FLASH_Unlock();
  75.  NbrOfPage = ( FLASHADDREND - FLASHADDRSTART ) / FLASH_PAGE_SIZE;
  76.  FLASH_ClearFlag(FLASH_FLAG_BSY | FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPRTERR);
  77.  FLASHStatus = FLASH_COMPLETE;
  78.  for(EraseCounter = 0; (EraseCounter < NbrOfPage) && (FLASHStatus == FLASH_COMPLETE); EraseCounter++)
  79.  {
  80.       FLASHStatus = FLASH_ErasePage(FLASHADDRSTART + (FLASH_PAGE_SIZE * EraseCounter));
  81.   }
  82.  if(FLASHStatus != FLASH_COMPLETE )//擦除不成功
  83.  {
  84.   return false;
  85.  }
  86.  Address = FLASHADDRSTART;
  87.  while((Address < FLASHADDREND ) && (FLASHStatus == FLASH_COMPLETE))
  88.  {
  89.   //instr = (*str)|((*(str+1))<<8);
  90.   if(len == 0) break;
  91.   FLASHStatus = FLASH_ProgramWord(Address, *(u32*)str);//一次性写入四个字节=1个字
  92.   Address = Address + 4;
  93.   len-=4;
  94.   str+=4;
  95.   //str+=2;
  96.   if(len < 4)
  97.   {
  98.    //由于是按字的写入方式,即一次性写入4个字节的数据,
  99.    //所有后面剩余的(4-len%4)%4个字节的补零处理
  100.    FLASHStatus = FLASH_ProgramWord(Address, *(u32*)str);
  101.    break;
  102.   }
  103.  }
  104.  FLASH_Lock();
  105.  if(FLASHStatus != FLASH_COMPLETE)
  106.  {
  107.   return false;
  108.  }
  109.  else return true;
  110. }
  111. /******************************************************************************
  112. * Function Name: readByteFlash
  113. * Description  : read specified length string from flash,the begin flash is : FLASHADDRSTART
  114. *                A byte by byte to read.
  115. * input        : the readed of string - str, the len of str
  116. * output       : return the length of string take away 1
  117. *******************************************************************************/
  118. UINT readByteFlash(UINT len)//
  119. {
  120.  UINT i=0;
  121.  Address = FLASHADDRSTART;
  122.  for(i=0;i
  123.  {
  124.   flashBytebuff.ulitems[i] = (*(__IO int8_t*) Address);
  125.   Address+=1;
  126.  }
  127.  return i;
  128. }
  129. /******************************************************************************
  130. * Function Name: readHalfWordFlash
  131. * Description  : read specified length string from flash,the begin flash is : FLASHADDRSTART
  132. *                A Halfword by halfword to read.
  133. * input        : the readed of string - str, the len of str
  134. * output       : return the length of string take away 1
  135. *******************************************************************************/
  136. UINT readHalfWordFlash(UINT len)//
  137. {
  138.  UINT i=0;
  139.  Address = FLASHADDRSTART;
  140.  for(i=0;i
  141.  {
  142.   flashHalfWrodbuff.ulItems[i] = (*(__IO uint16_t*) Address);
  143.   Address+=2;
  144.  }
  145.  if(len/2 )
  146.  {
  147.   flashHalfWrodbuff.ulItems[i] = (*(__IO uint16_t*) Address);
  148.  }
  149.  return i;
  150. }
  151. /******************************************************************************
  152. * Function Name: readWordFlash
  153. * Description  : read specified length string from flash,the begin flash is : FLASHADDRSTART
  154. *                A word by word to read.
  155. * input        : the readed of string - str, the len of str
  156. * output       : return the length of string take away 1
  157. *******************************************************************************/
  158. UINT readWordFlash(UINT len)
  159. {
[1] [2]
关键字:STM  flash  数据读取
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/article_2017071334144.html
上一篇:STM32 IO 问题
下一篇:STM32 USB那点事之6
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
STM
flash
数据读取
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
何立民专栏
单片机及嵌入式宝典
