STM32 内部flash的读写程序
2017-07-13 22:38:45来源: eefocus 关键字:STM32  内部flash  读写程序
  1. /* Base address of the Flash sectors */
  2. #define ADDR_FLASH_SECTOR_0     ((uint32_t)0x08000000) /* Base @ of Sector 0, 16 Kbytes */
  3. #define ADDR_FLASH_SECTOR_1     ((uint32_t)0x08004000) /* Base @ of Sector 1, 16 Kbytes */
  4. #define ADDR_FLASH_SECTOR_2     ((uint32_t)0x08008000) /* Base @ of Sector 2, 16 Kbytes */
  5. #define ADDR_FLASH_SECTOR_3     ((uint32_t)0x0800C000) /* Base @ of Sector 3, 16 Kbytes */
  6. #define ADDR_FLASH_SECTOR_4     ((uint32_t)0x08010000) /* Base @ of Sector 4, 64 Kbytes */
  7. //stm32f205rbt6 max 128Kbyte
  8. #define ADDR_FLASH_SECTOR_5     ((uint32_t)0x08020000) /* Base @ of Sector 5, 128 Kbytes */
  9. #define ADDR_FLASH_SECTOR_6     ((uint32_t)0x08040000) /* Base @ of Sector 6, 128 Kbytes */
  10. #define ADDR_FLASH_SECTOR_7     ((uint32_t)0x08060000) /* Base @ of Sector 7, 128 Kbytes */
  11. #define ADDR_FLASH_SECTOR_8     ((uint32_t)0x08080000) /* Base @ of Sector 8, 128 Kbytes */
  12. #define ADDR_FLASH_SECTOR_9     ((uint32_t)0x080A0000) /* Base @ of Sector 9, 128 Kbytes */
  13. #define ADDR_FLASH_SECTOR_10    ((uint32_t)0x080C0000) /* Base @ of Sector 10, 128 Kbytes */
  14. #define ADDR_FLASH_SECTOR_11    ((uint32_t)0x080E0000) /* Base @ of Sector 11, 128 Kbytes */
  15.
  16. static uint32_t GetSector(uint32_t Address)
  17. {
  18.   uint32_t sector = 0;
  19.
  20.   if((Address < ADDR_FLASH_SECTOR_1) && (Address >= ADDR_FLASH_SECTOR_0))
  21.   {
  22.     sector = FLASH_SECTOR_0;
  23.   }
  24.   else if((Address < ADDR_FLASH_SECTOR_2) && (Address >= ADDR_FLASH_SECTOR_1))
  25.   {
  26.     sector = FLASH_SECTOR_1;
  27.   }
  28.   else if((Address < ADDR_FLASH_SECTOR_3) && (Address >= ADDR_FLASH_SECTOR_2))
  29.   {
  30.     sector = FLASH_SECTOR_2;
  31.   }
  32.   else if((Address < ADDR_FLASH_SECTOR_4) && (Address >= ADDR_FLASH_SECTOR_3))
  33.   {
  34.     sector = FLASH_SECTOR_3;
  35.   }
  36.   else if((Address < ADDR_FLASH_SECTOR_5) && (Address >= ADDR_FLASH_SECTOR_4))
  37.   {
  38.     sector = FLASH_SECTOR_4;
  39.   }
  40.   else if((Address < ADDR_FLASH_SECTOR_6) && (Address >= ADDR_FLASH_SECTOR_5))
  41.   {
  42.     sector = FLASH_SECTOR_5;
  43.   }
  44.   else if((Address < ADDR_FLASH_SECTOR_7) && (Address >= ADDR_FLASH_SECTOR_6))
  45.   {
  46.     sector = FLASH_SECTOR_6;
  47.   }
  48.   else if((Address < ADDR_FLASH_SECTOR_8) && (Address >= ADDR_FLASH_SECTOR_7))
  49.   {
  50.     sector = FLASH_SECTOR_7;
  51.   }
  52.   else if((Address < ADDR_FLASH_SECTOR_9) && (Address >= ADDR_FLASH_SECTOR_8))
  53.   {
  54.     sector = FLASH_SECTOR_8;
  55.   }
  56.   else if((Address < ADDR_FLASH_SECTOR_10) && (Address >= ADDR_FLASH_SECTOR_9))
  57.   {
  58.     sector = FLASH_SECTOR_9;
  59.   }
  60.   else if((Address < ADDR_FLASH_SECTOR_11) && (Address >= ADDR_FLASH_SECTOR_10))
  61.   {
  62.     sector = FLASH_SECTOR_10;
  63.   }
  64.   else /* (Address < FLASH_END_ADDR) && (Address >= ADDR_FLASH_SECTOR_11) */
  65.   {
  66.     sector = FLASH_SECTOR_11;
  67.   }
  68.
  69.   return sector;
  70. }
写函数!
  1. /* Get the 1st sector to erase */
  2. int writeFlash(uint32_t startAddr,uint32_t endAddr,uint32_t* data,uint32_t len){
  3.     /* Private macro -------------------------------------------------------------*/
  4.     /* Private variables ---------------------------------------------------------*/
  5.     uint32_t FirstSector = 0, NbOfSectors = 0, Address = 0;
  6.     uint32_t SectorError;
  7.     /*Variable used for Erase procedure*/
  8.     FLASH_EraseInitTypeDef EraseInitStruct;
  9.
  10.     /* Unlock the Flash to enable the flash control register access *************/
  11.     HAL_FLASH_Unlock();
  12.
  13.     FirstSector = GetSector(startAddr);
  14.     /* Get the number of sector to erase from 1st sector*/
  15.     NbOfSectors = GetSector(endAddr) - FirstSector + 1;
  16.
  17.     /* Fill EraseInit structure*/
  18.     EraseInitStruct.TypeErase = FLASH_TYPEERASE_SECTORS;
  19.     EraseInitStruct.VoltageRange = FLASH_VOLTAGE_RANGE_3;
  20.     EraseInitStruct.Sector = FirstSector;
  21.     EraseInitStruct.NbSectors = NbOfSectors;
  22.     if(HAL_FLASHEx_Erase(&EraseInitStruct, &SectorError) != HAL_OK)
  23.     {
  24.         /*
  25.         Error occurred while sector erase.
  26.         User can add here some code to deal with this error.
  27.         SectorError will contain the faulty sector and then to know the code error on this sector,
  28.         user can call function 'HAL_FLASH_GetError()'
  29.         */
  30.         HAL_FLASH_Lock();
  31.         return -1;
  32.     }
  33.     /* Program the user Flash area word by word
  34.             (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/
  35.
  36.     Address = startAddr;
  37.     while(len -- ){
  38.         if(data == NULL) break;
  39.         if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, Address, *data) == HAL_OK)
  40.         {
  41.             Address = Address + 4;
  42.         }
  43.         else
  44.         {
  45. HAL_FLASH_Lock();
[1] [2]
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/article_2017071334132.html
上一篇:stm32f407以太网及USB OTG快速开发
下一篇:AT24C128 EEPROM的读写
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
STM32
内部flash
读写程序
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
何立民专栏
单片机及嵌入式宝典
