stm32中的数据类型定义
2016-12-16 09:38:01来源: eefocus 关键字:stm32  数据类型定义
STM32F10X.H
 1 #include "core_cm3.h"
 2 #include "system_stm32f10x.h"
 3 #include
 5 /** @addtogroup Exported_types
 6   * @{
 7   */
 9 /*!< STM32F10x Standard Peripheral Library old types (maintained for legacy purpose) */
10 typedef int32_t  s32;
11 typedef int16_t s16;
12 typedef int8_t  s8;
14 typedef const int32_t sc32;  /*!< Read Only */
15 typedef const int16_t sc16;  /*!< Read Only */
16 typedef const int8_t sc8;   /*!< Read Only */
17
18 typedef __IO int32_t  vs32;
19 typedef __IO int16_t  vs16;
20 typedef __IO int8_t   vs8;
21
22 typedef __I int32_t vsc32;  /*!< Read Only */
23 typedef __I int16_t vsc16;  /*!< Read Only */
24 typedef __I int8_t vsc8;   /*!< Read Only */
26 typedef uint32_t  u32;
27 typedef uint16_t u16;
28 typedef uint8_t  u8;
29
30 typedef const uint32_t uc32;  /*!< Read Only */
31 typedef const uint16_t uc16;  /*!< Read Only */
32 typedef const uint8_t uc8;   /*!< Read Only */
33
34 typedef __IO uint32_t  vu32;
35 typedef __IO uint16_t vu16;
36 typedef __IO uint8_t  vu8;
37
38 typedef __I uint32_t vuc32;  /*!< Read Only */
39 typedef __I uint16_t vuc16;  /*!< Read Only */
40 typedef __I uint8_t vuc8;   /*!< Read Only */
41
42 typedef enum {RESET = 0, SET = !RESET} FlagStatus, ITStatus;
43
44 typedef enum {DISABLE = 0, ENABLE = !DISABLE} FunctionalState;
45 #define IS_FUNCTIONAL_STATE(STATE) (((STATE) == DISABLE) || ((STATE) == ENABLE))
46
47 typedef enum {ERROR = 0, SUCCESS = !ERROR} ErrorStatus;
源定义在#include
 1 /*
 2  * 'signed' is redundant below, except for 'signed char' and if
 3  * the typedef is used to declare a bitfield.
 4  */
 6     /* 7.18.1.1 */
 8     /* exact-width signed integer types */
 9 typedef   signed          char int8_t;
10 typedef   signed short     int int16_t;
11 typedef   signed           int int32_t;
12 typedef   signed       __INT64 int64_t;
14     /* exact-width unsigned integer types */
15 typedef unsigned          char uint8_t;
16 typedef unsigned short     int uint16_t;
17 typedef unsigned           int uint32_t;
18 typedef unsigned       __INT64 uint64_t;
19
20     /* 7.18.1.2 */
21
22     /* smallest type of at least n bits */
23     /* minimum-width signed integer types */
24 typedef   signed          char int_least8_t;
25 typedef   signed short     int int_least16_t;
26 typedef   signed           int int_least32_t;
27 typedef   signed       __INT64 int_least64_t;
28
29     /* minimum-width unsigned integer types */
30 typedef unsigned          char uint_least8_t;
31 typedef unsigned short     int uint_least16_t;
32 typedef unsigned           int uint_least32_t;
33 typedef unsigned       __INT64 uint_least64_t;
34
35     /* 7.18.1.3 */
36
37     /* fastest minimum-width signed integer types */
38 typedef   signed           int int_fast8_t;
39 typedef   signed           int int_fast16_t;
40 typedef   signed           int int_fast32_t;
41 typedef   signed       __INT64 int_fast64_t;
42
43     /* fastest minimum-width unsigned integer types */
44 typedef unsigned           int uint_fast8_t;
45 typedef unsigned           int uint_fast16_t;
46 typedef unsigned           int uint_fast32_t;
47 typedef unsigned       __INT64 uint_fast64_t;
48
49     /* 7.18.1.4 integer types capable of holding object pointers */
50 #if __sizeof_ptr == 8
51 typedef   signed       __INT64 intptr_t;
52 typedef unsigned       __INT64 uintptr_t;
53 #else
54 typedef   signed           int intptr_t;
55 typedef unsigned           int uintptr_t;
56 #endif
57
58     /* 7.18.1.5 greatest-width integer types */
59 typedef   signed     __LONGLONG intmax_t;
60 typedef unsigned     __LONGLONG uintmax_t;
由上述可知:
1、有符号整型
  • s8 占用1个byte,数据范围 -2^7  到 (2^7-1)
  • s16 占用2个byte,数据范围 -2^15 到 (2^15-1)
  • s32 占用 4个byte,数据范围 -2^31 到 (2^31-1)2^31  = 2147483647
  • int64_t占用8个byte,数据范围 -2^63 到 (2^63-1)    2^63 = 9223372036854775807ll
2、无符号整型
  • u8  占用1个byte, 数据范围 0 - 2^8
  • u16 占用2个byte, 数据范围 0 - 2^16
  • u32 占用4个byte, 数据范围 0 - 2^32 2^32  = 4294967295
  • uint64_t 占用8个byte, 数据范围 0 - 2^64 2^64  = 18446744073709551615
3、浮点型
  •     float ——4个byte,有符号型,可以表达负数/小数; Float 类型至少要能精确表示到小数点后6位。
  •    double——8个byte,有符号型,可以表达负数/小数;Double 类型至少要能精确到小数点后 10 位。
二、不同数据类型混合运算
在C语言中,不同类型的数据间是可以混合运算的。在进行运算时,不同类型的数据要先转换成同一类型,然后进行运算。转换的规则如下:
注意:箭头的方向只表示数据类型级别的高低,由低向高转换,这个转换过程是一步到位的。
(三)数据类型转换规则
各类数据类型的转换,分为两种方式:隐式(编译软件自动完成),显式(程序强制转换)
隐式转换规则:
字符必须先转换为整数(C语言规定字符类型数据和整型数据之间可以通用)
   short型转换为int型(同属于整型)
   float型数据在运算时一律转换为双精度(double)型,以提高运算精度(同属于实型)
   赋值时,一律是右部值转换为左部类型
[注]
     当整型数据和双精度数据进行运算时,C先将整型数据转换成双精度型数据,再进行运算,结果为双精度类型数据
     当字符型数据和实型数据进行运算时,C先将字符型数据转换成实型数据,然后进行计算,结果为实型数据
显式转换规则:
例:(int)(x+y);
注:强制类型转换时,得到一个所需要的中间变量,原来变量的类型未发生变化。
关键字:stm32  数据类型定义
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/article_2016121632404.html
上一篇:STM32 USB数据接收与数据发送程序流程分析
下一篇:最后一页
论坛活动 E手掌握
微信扫一扫加关注
论坛活动 E手掌握
芯片资讯 锐利解读
微信扫一扫加关注
芯片资讯 锐利解读
全部
stm32
数据类型定义
小广播
独家专题更多
TTI携TE传感器样片与你相见,一起传感未来
富士通铁电随机存储器FRAM主题展馆
富士通铁电随机存储器FRAM主题展馆
馆内包含了 纵览FRAM、独立FRAM存储器专区、FRAM内置LSI专区三大部分内容。
走,跟Molex一起去看《中国电子消费品趋势》!
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2016 EEWORLD.com.cn, Inc. All rights reserved
