datasheet
STM32学习之:USART中断方式
2018-10-21来源: eefocus 关键字:STM32  USART  中断方式
 前面我们接收了串口通信的查询方式,现在我们来介绍中断方式
   步骤一:初始化GPIO
GPIO_InitTypeDef GPIO_InitStructure;
 /* Configure USART1 Tx (PA.09) as alternate function push-pull */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
 GPIO_Init(GPIOA, &GPIO_InitStructure);
 /* Configure USART1 Rx (PA.10) as input floating */
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
步骤二:开时钟
/* Enable USART1, GPIOA, GPIOD and AFIO clocks */
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD
                         | RCC_APB2Periph_AFIO, ENABLE);
在此说明,不用设置RCC_APB2Periph_AFIO也是可以的,也就是在此没有使用复用功能。
这两个步骤与查询方式是一样的。
步骤三:初始化USART1
USART_InitStructure.USART_BaudRate = 115200;
 USART_InitStructure.USART_WordLength = USART_WordLength_8b;
 USART_InitStructure.USART_StopBits = USART_StopBits_2;
 USART_InitStructure.USART_Parity = USART_Parity_No;      //设置奇校验时,通信出现错误
 USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
 /* Configure the USART1 */
 USART_Init(USART1, &USART_InitStructure);
 /* Enable the USART Transmoit interrupt: this interrupt is generated when the
     USART1 transmit data register is empty */
 USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
 /* Enable the USART Receive interrupt: this interrupt is generated when the
     USART1 receive data register is not empty */
 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
 /* Enable USART1 */
 USART_Cmd(USART1, ENABLE);
在这里要使能USART1的外设中断,如USART_ITConfig(USART1, USART_IT_TXE, ENABLE);这就是使能发送中断,但发送寄存器空时能产生中断。
步骤四:编写中断函数
uint8_t TxBuffer[] = "\n\rUSART Hyperterminal Interrupts Example: USART-Hyperterminal\
 communication using Interrupt\n\r";
uint8_t RxBuffer[RxBufferSize];
uint8_t NbrOfDataToTransfer = TxBufferSize;
uint8_t NbrOfDataToRead = RxBufferSize;
uint8_t TxCounter = 0;
uint16_t RxCounter = 0;
void USART1_IRQHandler(void)
 if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer[RxCounter++] = (USART_ReceiveData(USART1) & 0x7F);
    if(RxCounter == NbrOfDataToRead)
      /* Disable the USART Receive interrupt */
      USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
 if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    /* Write one byte to the transmit data register */
      USART_SendData(USART1, TxBuffer[TxCounter++]);
    if(TxCounter == NbrOfDataToTransfer)
      /* Disable the USART1 Transmit interrupt */
      USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
至此程序就结束了。
我们就会有个疑问,main()只包括前三个步骤的初始化和一个死循环,那么中断又是如何触发的呢,main()的结构如下:
int main(void)
 /* System Clocks Configuration */
 RCC_Configuration();
 /* NVIC configuration */
 NVIC_Configuration();
 /* Configure the GPIO ports */
 GPIO_Configuration();
 USART_Configuration();
 while (1)
原来是这样的:状态寄存器USART_SR的复位值为0x00C0H, 也就是第七位TXE和第六位TC复位值为1,而TXE=1,表明发送数据寄存器为空, TC=1表明发送已完成。而在USART的设置中有
这两句使能中断,也就是说当TXE=1就会进入中断,所以程序初始化后就能进入中断,执行
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news102141958.html
上一篇:STM32学习之:GPIO最简单操作步骤
下一篇:STM32学习之:NVIC的初步理解
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32双堆栈及其在uC/OS-II中的使用
,进入中断程序后就开始使用MSP,如果还有一个高优先级的中断难么就继续的使用MSP,在程序推出最后一级中断的时候就用用户堆栈恢复寄存器。下面以uCOS-II为例进行说明:首先建立一个堆栈  OS_STK   AppTaskStartStk[1024]  //32位STM32是向下生长的满栈,初始化堆栈后(在没有使用PSP以前,一直使用的是MSP)。                 |
发表于 2018-12-03
关于STM32中的assert_param()
在STM32的固件库和提供的例程中,到处都可以见到assert_param()的使用。如果打开任何一个例程中的stm32f10x_conf.h文件,就可以看到实际上assert_param是一个宏定义;在固件库中,它的作用就是检测传递给函数的参数是否是有效的参数。所谓有效的参数是指满足规定范围的参数,比如某个参数的取值范围只能是小于3的正整数,如果给出的参数大于3,则这个assert_param()可以在运行的程序调用到这个函数时报告错误,使程序员可以及时发现错误,而不必等到程序运行结果的错误而大费周折。这是一种常见的软件技术,可以在调试阶段帮助程序员快速地排除那些明显的错误。它确实在程序的运行上牺牲了效率(但只是在调试阶段
发表于 2018-12-03
stm32启动文件相关说明
说的直白点就是以下区别,在选择启动文件的时候有选择性区别!startup_stm32f10x_cl.s互联型的STM32F105xx,STM32F107xxstartup_stm32f10x_hd.s 大容量的STM32F101xx,STM32F102xx,STM32F103xxstartup_stm32f10x_hd_vl.s 大容量的STM32F100xxstartup_stm32f10x_ld.s 小容量的STM32F101xx,STM32F102xx,STM32F103xxstartup_stm32f10x_ld_vl.s 小容量
发表于 2018-12-03
stm32启动文件相关说明
STM32定时器相关介绍(主要是有UEV更新事件介绍)
单片机的定时器的确很强大,参考说明书中就占了一百多页,占参考手册1/4 有多了。STM32的定时器分了好几个类别,各个类别针对功能作用都不大相同。分有: 一、高级定时器       二、通用定时器       三、基本定时器       四、看门狗定时器       五、SysTick定时器      其中看门狗定时器和SysTick定时器本篇笔记阐述,这里主要记下对平时使用
发表于 2018-12-03
stm32时钟相关
我在原创的基础又从另一位博主处引用了一些内容。  时钟系统是处理器的核心,所以在学习STM32所有外设之前,认真学习时钟系统是必要的,有助于深入理解STM32。     下面是从网上找的一个STM32时钟框图,比《STM32中文参考手册》里面的是中途看起来清晰一些:         重要的时钟:   PLLCLK,SYSCLK,HCKL,PCLK1,PCLK2 之间的关系要弄清楚;       1、HSI:高速内部时钟信号
发表于 2018-12-03
stm32时钟相关
STM32之中断管理
关于STM32的中断,相信大家玩过单片机的朋友就知道,中断是MCU的一大优点,使MUC工作能够分清事情的”轻重缓急“ ,从而达到处理事情井井有条; 今天就讲解下STM32-Cortex-M3内核的中断管理机制,其他处理器的也类似;M3中F103系列的有60个可屏蔽的中断和16个内核级别的中断;     大家知道,操作一款MCU 其实实质就是操作的寄存器,而寄存器有机的结合起来就实现了特定的功能;中断系统也不例外,下面来认识一下中断系统中的几个重要的寄存器;    1. ISER[8](Interrupt Set-Enable Registers),就是中断使能寄存器组
发表于 2018-12-03
小广播
何立民专栏
单片机及嵌入式宝典
pt type="text/javascript" src="//v3.jiathis.com/code/jia.js?uid=2113614" charset="utf-8">
