datasheet
Tiny210裸机之按键中断
2018-10-12来源: eefocus关键字:Tiny210裸机  按键中断
start.S源码:
.global _start
_start:
    ldr sp, =0xD0030000  // 初始化栈,因为后面要调用C函数
    bl clock_init                // 初始化时钟
    bl ddr_init                   // 初始化内存
    bl nand_init                // 初始化NAND
    ldr r0, =0x36000000   // 要拷贝到DDR中的位置
    ldr r1, =0x0                 // 从NAND的0地址开始拷贝
    ldr r2, =bss_start         // BSS段的开始地址
    sub r2,r2,r0                  // 要拷贝的大小
    bl nand_read              // 拷贝数据
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    ldreq pc, =on_ddr
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
    ldr pc, =on_ddr
on_ddr:
    mrs  r0, cpsr
    bic    r0,r0,#0x1f  // 清M4~M0
    orr    r0,r0,#0x12
    msr    cpsr,r0        // 进入irq
    ldr sp, =0x3e000000    // 初始化普通中断模式的栈,指向内存
    bl irq_init
    mrs  r0, cpsr
    bic    r0,r0,#0x9f  // 开总的中断开关,清M4~M0
    orr    r0,r0,#0x10
    msr    cpsr,r0      // 进入user mode
    ldr sp, =0x3f000000    // 初始化用户模式的栈,指向内存
    ldr pc, =main
halt:
    b halt
.global key_IRQ
key_IRQ:
    sub lr, lr, #4                   // 1.计算返回地址
    stmdb sp!, {r0-r12, lr}  // 2.保护现场
    // 3. 处理异常
    bl do_irq
    // 4. 恢复现场
    ldmia sp!, {r0-r12, pc}^  // ^表示把spsr恢复到cpsr
irq.c源码:
#include "lib.h"
#define GPH2CON        (*(volatile unsigned int *)0xE0200C40)
#define GPH2DAT        (*(volatile unsigned int *)0xE0200C44)
#define GPH3CON        (*(volatile unsigned int *)0xE0200C60)
#define GPH3DAT        (*(volatile unsigned int *)0xE0200C64)
#define EXT_INT_2_CON        (*(volatile unsigned int *)0xE0200E08)
#define EXT_INT_3_CON        (*(volatile unsigned int *)0xE0200E0C)
#define EXT_INT_2_MASK        (*(volatile unsigned int *)0xE0200F08)
#define EXT_INT_3_MASK        (*(volatile unsigned int *)0xE0200F0C)
#define VIC0INTSELECT        (*(volatile unsigned int *)0xF200000C)
#define VIC0INTENABLE        (*(volatile unsigned int *)0xF2000010)
#define VIC0VECTADDR16        (*(volatile unsigned int *)0xF2000140)
#define VIC0ADDRESS          (*(volatile unsigned int *)0xF2000F00)
#define EXT_INT_2_PEND        (*(volatile unsigned int *)0xE0200F48)
#define EXT_INT_3_PEND        (*(volatile unsigned int *)0xE0200F4c)
int i = 0;
void do_irq(void)
    // 清中断
    EXT_INT_2_PEND |= 1<<3;
    EXT_INT_3_PEND |= 1<<0;
    // 清中断向量
    VIC0ADDRESS = 0;
    if(!(GPH2DAT & (1<<3)))
        wy_printf("counter(k4) : %d \n",i++);
    if(!(GPH3DAT & (1<<0)))
        wy_printf("counter(K5) : %d \n",i--);
extern void key_IRQ(void);
void irq_init(void)
    // 设置GPH2_3(K4),GPH3_0(K5)用于中断
    GPH2CON |= 0xf<<12;
    GPH3CON |= 0xf<<0;
    // 设置触发方式为下降沿触发
    EXT_INT_2_CON |= 0x2<<12;
    EXT_INT_3_CON |= 0x2<<0;
    // 使能中断(GPIO里面的)
    EXT_INT_2_MASK &= ~(1<<3);
    EXT_INT_3_MASK &= ~(1<<0);
    // 设置为IRQ中断
    VIC0INTSELECT &= ~(1<<16);
    // 使能中断(中断控制器里面的)
    VIC0INTENABLE |= 1<<16;
    // 设置中断向量
    VIC0VECTADDR16 = (int)key_IRQ;
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#define    CFG_PROMPT        "WY_BOOT # "    // Monitor Command Prompt
#define    CFG_CBSIZE        256        // Console I/O Buffer Size
char *argv[10];
int readline (const char *const prompt)
    char console_buffer[CFG_CBSIZE];        // console I/O buffer
    char *buf = console_buffer;
    int argc = 0;
    int state = 0;
    //puts(prompt);
    wy_printf("%s",prompt);
    gets(console_buffer);
    while (*buf)
        if (*buf != ' ' && state == 0)
            argv[argc++] = buf;
            state = 1;
        if (*buf == ' ' && state == 1)
            *buf = '\0';
            state = 0;
        buf++;
    return argc;
void message(void)
    wy_printf("\nThis bootloader support some command to test peripheral:\n");
    wy_printf("Such as: LCD, IIS, BUZZER \n");
    wy_printf("Try 'help' to learn them \n\n");
int main(void)
    char buf[6];
    int argc = 0;
    int i = 0;
    led_init(); // 设置对应管脚为输出
    uart_init(); // 初始化UART0
    nand_read_id(buf);
    wy_printf("\n**********************************************************\n");
    wy_printf("                     wy_bootloader\n");
    wy_printf("                     vars: %d \n",2012);
    wy_printf("                     nand id:");
    putchar_hex(buf[0]);
    putchar_hex(buf[1]);
    putchar_hex(buf[2]);
    putchar_hex(buf[3]);
    putchar_hex(buf[4]);
    while (1)
        argc = readline (CFG_PROMPT);
        if(argc == 0 && i ==0)
            message();
            i=1;
        run_command(argc, argv);
    return 0;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c nand.c mem_setup.S irq.c
    arm-linux-gcc -nostdlib -c start.s -o start.o
    arm-linux-gcc -nostdlib -c main.c -o main.o
    arm-linux-gcc -nostdlib -c uart.c -o uart.o
    arm-linux-gcc -nostdlib -c lib.c -o lib.o
    arm-linux-gcc -nostdlib -c clock.c -o clock.o
    arm-linux-gcc -nostdlib -c led.c -o led.o
    arm-linux-gcc -nostdlib -c command.c -o command.o
    arm-linux-gcc -nostdlib -c nand.c -o nand.o
    arm-linux-gcc -nostdlib -c irq.c -o irq.o
    arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
    arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o led.o command.o nand.o mem_setup.o irq.o -o uart_elf
    arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
    rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
    . = 0x36000010;
    .text : {
        * (.text)
    . = ALIGN(4);
    .rodata : {
        * (.rodata)
    . = ALIGN(4);
    .data : {
        * (.data)
    . = ALIGN(4);
    bss_start = .;
    .bss  : { *(.bss)  *(COMMON) }
    bss_end = .;
关键字:Tiny210裸机  按键中断
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241714.html
上一篇:Tiny210裸机IIC之at24cxx操作
下一篇:S3C2440、S3C6410、S5PV210中断解析
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210裸机之UART串口操作
S5PV210的时钟的时候,一定要参考该图。上面给出的clock_init()函数,设置的寄存器参数,都是用的推荐值,在手册中都能够查到。我以HCLKD为什么等于166.75MHz为例,来讲述如何借助芯片手册的361页和362页的图来配置时钟:      1.HCLKD是用于显示域(如LCD等)的时钟,因此在361页的途中找到HCLK_DSYS,顺着箭头方向往回找,发现它是由DIVhclkd分频而来,即HCLK_DSYS = MOUT_DSYS / (HCLK_DSYS_RATIO + 1),类似的分频系数对应于CLK_DIVn寄存器;
发表于 2018-10-13
Tiny210裸机之实现printf功能
注意:本节串口的printf等函数的实现方法可以参考OK6410的裸机“11th_uart_stdio”实验源码,该方法更实用。start.S源码:.global _start    _start:    ldr sp, =0xD0030000    @初始化堆栈        b main
发表于 2018-10-13
Tiny210裸机简单命令的实现
;   (*(volatile unsigned int *)0xe0100100) #define CLK_SRC0      (*(volatile unsigned int *)0xe0100200) #define CLK_DIV0      (*(volatile unsigned int *)0xe0100300) #define MPLL_CON      (*(volatile unsigned int
发表于 2018-10-13
Tiny210裸机之nand_flash操作
了,大家看我共享的代码,就明白,放在了"Tiny210学习日记_代码"目录下了,名为"6_nand"。测试:1).使用md命令:WY_BOOT # WY_BOOT # WY_BOOT # md 0xd0030000do_command  D0030000: 00EACEED CE4F284F 781CF81F 395E9CDE D0030010: 6B7DCBCF D4F870DB 9F07E61F 53BB9C51 2).使用nand read命令:WY_BOOT # WY_BOOT # nand read 0xd0030000 0x0
发表于 2018-10-13
Tiny210裸机之DDR_SDRAM重定位
u-boot里面的,只是自己从头对照寄存器去理解了一下,完全符合598页的初始化步骤),放在了"Tiny210学习日记_代码"目录下了,名为"7_ddr"注意:之前的代码,包括该部分代码,都没有重定位的操作,IROM最多可以拷贝16K的代码到IRAM中,够用了!但是,由于后面我会讲到LCD显示图片,声卡播放WAV文件,bootloader也随之慢慢变大,16K的大小可能不够,再加上现在已经把重定位的条件都准备好了,所以接下来将是重定位。(相关知识,大家可以学习韦东三一期视频的重定位部分),这里,我就不在细说,直接给出代码,和讲几个关键地方。以下为start.s的代码:.global
发表于 2018-10-13
Tiny210裸机之bootm命令启动内核
;  MACH_SMDKV210        SMDKV210        2456从而说明此时的机器ID是2456。注意:这个过程说得有点绕和啰嗦,再次抱歉。参数三:一句话,实在是没有什么可以说的,韦老大的视频里面讲得太详细了!!大家直接看视频和我上传的关于这章的代码吧,放在了"Tiny210学习日记_代码"目录下了,名为"9_bootm"。注意:本章写的代码,只能通过bootm命令来启动内核,延时自动启动内核,我会在后面章节讲到。
发表于 2018-10-13
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
