datasheet
Tiny210裸机PWM控制蜂鸣器
2018-10-12来源: eefocus关键字:Tiny210裸机  PWM控制  蜂鸣器
start.S源码:
.global _start
_start:
    ldr sp, =0xD0030000  // 初始化栈,因为后面要调用C函数
    bl clock_init                // 初始化时钟
    bl ddr_init                   // 初始化内存
    bl nand_init                // 初始化NAND
    ldr r0, =0x36000000  // 要拷贝到DDR中的位置
    ldr r1, =0x0                // 从NAND的0地址开始拷贝
    ldr r2, =bss_start       // BSS段的开始地址
    sub r2,r2,r0                // 要拷贝的大小
    bl nand_read            // 拷贝数据
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    ldreq pc, =on_ddr
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
    ldr pc, =on_ddr
on_ddr:
    ldr sp, =0x3f000000    // 重新初始化栈,指向内存
    ldr pc, =main
timer.c源码:
#define    GPD0CON     (*(volatile unsigned int *)0xE02000A0)
#define    TCFG0           (*(volatile unsigned int *)0xE2500000)
#define    TCFG1           (*(volatile unsigned int *)0xE2500004)
#define    TCON            (*(volatile unsigned int *)0xE2500008)
#define    TCNTB0         (*(volatile unsigned int *)0xE250000C)
#define    TCMPB0        (*(volatile unsigned int *)0xE2500010)
#define    TCNTO0        (*(volatile unsigned int *)0xE2500014)
void pwm_init(void)
    // 配置为GPD0_0用于PWM输出
    GPD0CON |= (0x2 << 0);     // TOUT_0
void timer0_init(void)
    // 设置时钟源
    // Timer0 input clock Frequency = 66700000 / ( {prescaler + 1} ) / {divider value}
    //      = 66700000 / (1+1) / 1
    //      = 33350000( 即1s计数33350000次 )
    TCFG0 &= ~(0xff);
    TCFG0  |= 1;        // Prescaler = 1
    TCFG1  &= ~0xf;     // 0000 = 1/1
    // 设置TCNTB0(即PWM的频率)
    TCNTB0 = 33350;     // PWM的频率为1KHz
    // 设置TCMPB0(即PWM的占空比)
    TCMPB0 = 16675;     // 占空比为50%
    TCON &= ~(1<<2);    // 不进行电平反转(即引脚初始值为0)
    TCON |= (1<<3);     // auto-reload
void pwm_start(void)
    TCON |= (1<<1);   // set manual update
    TCON |= (1<<0);   // start timer 0
    TCON &= ~(1<<1);  // clean manual update
void pwm_stop(void)
    TCON &= ~(1<<0);   // stop timer 0
command.c源码:
#include "lib.h"
#include "nand.h"
#include "timer.h"
int help(int argc, char * argv[])
    wy_printf("do_command 《%s》 \n", argv[0]);      //"《"实际为"<"
    wy_printf("help message: \n");
    wy_printf("md - memory dispaly\n");
    wy_printf("mw - memory write\n");
    wy_printf("nand read - nand read sdram_addr nand_addr size\n");
    wy_printf("nand write - nand write sdram_addr nand_addr size\n");
    wy_printf("pwm on - turn on buzzer \n");
    wy_printf("pwm off - turn off buzzer\n");
    return 0;
int md(int argc, char * argv[])
    unsigned long *p = (unsigned long *)0;
    int i, j;
    if (argc <= 1) {
        wy_printf ("Usage:\n%s\n", "md address");
        return 1;
    if (argc >= 2)
        p = (unsigned long *)atoi(argv[1]);
    for (j = 0; j < 16; j++)
        wy_printf("%x: ", p);
        for (i = 0; i < 4; i++)
            wy_printf("%x ", *p++);
        wy_printf("\n");
    return 0;
int mw(int argc, char * argv[])
    int v = 0;
    wy_printf("do_command 《%s》 \n", argv[0]);//"《"实际为"<"
    if (argc <= 2) {
        wy_printf ("Usage:\n%s\n", "md address data");
        return 1;
    if (argc >= 2)
    if (argc >= 3)
        v = atoi(argv[2]);
    *p = v;
    return 0;
int nand(int argc, char *argv[])
    int nand_addr, sdram_addr;
    unsigned int size;
    if (argc < 5)
        wy_printf("nand read sdram_addr nand_addr size\n");
        wy_printf("nand write sdram_addr nand_addr size\n");
        return 0;
    sdram_addr = atoi(argv[2]);
    nand_addr = atoi(argv[3]);
    size = atoi(argv[4]);
    wy_printf("sdram 0x%x, nand 0x%x, size 0x%x\n", sdram_addr, nand_addr, size);
    if (strcmp(argv[1], "read") == 0)
        nand_read((unsigned char *)sdram_addr, nand_addr, size);
    if (strcmp(argv[1], "write") == 0)
        nand_write(sdram_addr, nand_addr, size);
    wy_printf("nand %s finished!\n", argv[1]);
    return 0;
int pwm(int argc, char *argv[])
    pwm_init();
    if (argc < 2)
        wy_printf("pwm off - turn on buzzer\n");
        return 0;
    if (strcmp(argv[1], "on") == 0)
        pwm_start();
    if (strcmp(argv[1], "off") == 0)
        pwm_stop();
    return 0;
void run_command(int argc, char * argv[])
    if (strcmp(argv[0], "help") == 0)
        help(argc, argv);
        return;
    if (strcmp(argv[0], "md") == 0)
        md(argc, argv);
        return;
    if (strcmp(argv[0], "mw") == 0)
        mw(argc, argv);
        return;
    if (strcmp(argv[0], "pwm") == 0)
        pwm(argc, argv);
        return;
    if (strcmp(argv[0], "nand") == 0)
        nand(argc, argv);
    if(argc >= 1)
        wy_printf("Unknown command '%s' - try 'help' \n",argv[0]);
    return;
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#define   CFG_PROMPT  "WY_BOOT # " // Monitor Command Prompt
#define   CFG_CBSIZE  256                      // Console I/O Buffer Size
char *argv[10];
int readline (const char *const prompt)
    char console_buffer[CFG_CBSIZE];      // console I/O buffer
    char *buf = console_buffer;
    int argc = 0;
    int state = 0;
    //puts(prompt);
    wy_printf("%s",prompt);
    gets(console_buffer);
    while (*buf)
        if (*buf != ' ' && state == 0)
            argv[argc++] = buf;
            state = 1;
        if (*buf == ' ' && state == 1)
            *buf = '\0';
            state = 0;
        buf++;
    return argc;
void message(void)
    wy_printf("\nThis bootloader support some command to test peripheral:\n");
    wy_printf("Such as: LCD, IIS, BUZZER \n");
    wy_printf("Try 'help' to learn them \n\n");
int main(void)
    char buf[6];
    int argc = 0;
    int i = 0;
    led_init();    // 设置对应管脚为输出
    uart_init();   // 初始化UART0
    nand_read_id(buf);
    timer0_init(); // 初始化定时器0,用于PWM输出,延时1S
    wy_printf("\n**********************************************************\n");
    wy_printf("                     wy_bootloader\n");
    wy_printf("                     vars: %d \n",2012);
    wy_printf("                     nand id:");
    putchar_hex(buf[0]);
    putchar_hex(buf[1]);
    putchar_hex(buf[2]);
    putchar_hex(buf[3]);
    putchar_hex(buf[4]);
    while (1)
        argc = readline (CFG_PROMPT);
        if(argc == 0 && i ==0)
            message();
            i=1;
        run_command(argc, argv);
    return 0;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c nand.c mem_setup.S timer.c
    arm-linux-gcc -nostdlib -c start.s -o start.o
    arm-linux-gcc -nostdlib -c main.c -o main.o
    arm-linux-gcc -nostdlib -c uart.c -o uart.o
    arm-linux-gcc -nostdlib -c lib.c -o lib.o
    arm-linux-gcc -nostdlib -c clock.c -o clock.o
    arm-linux-gcc -nostdlib -c led.c -o led.o
    arm-linux-gcc -nostdlib -c command.c -o command.o
    arm-linux-gcc -nostdlib -c nand.c -o nand.o
    arm-linux-gcc -nostdlib -c timer.c -o timer.o
    arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
    arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o led.o command.o nand.o mem_setup.o timer.o -o uart_elf
    arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
    rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
    . = 0x36000010;
    .text : {
        * (.text)
    . = ALIGN(4);
    .rodata : {
        * (.rodata)
    . = ALIGN(4);
    .data : {
        * (.data)
    . = ALIGN(4);
    bss_start = .;
    .bss  : { *(.bss)  *(COMMON) }
    bss_end = .;
一,定时器用于PWM输出(驱动蜂鸣器):
下面,先介绍下定时器的几个关键的寄存器吧:
问:大家都知道,定时器的实现,其实就是一个计数的过程(从0家到一个数字或从一个数字减到0),那么这个数字从哪里来呢?
答:从寄存器TCNTBx中获得,当我们编程时,写入一个数组到该寄存器,然后通过手动装载或自动装载,就会把该寄存器的值用于"一个数字"了。
问:PWM波形是高低电平交替出现的,那么定时器输出的电平什么时候翻转呢?
答:这个情况和TCMPBx寄存器中的值有关系,当计数器中的值("一个数字")减到(或加到)和TCMPBx寄存器中的值相等时,电平翻转。
本来想多说点的,但是实在是没什么可说的,直接上部分代码吧:
    // 设置时钟源
    TCFG0 &= ~(0xff);
以上是定时器的初始化代码,关于定时器用于PWM输出的代码我以经共享在了"Tiny210学习日记_代码"目录下了,名为"14_pwm"。请大家自己阅读,十分简单。
测试方法:(在终端输入命令)
pwm on           (蜂鸣器响)
pwm off           (蜂鸣器不响)
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241712.html
上一篇:自己写bootloader倒计时启动内核
下一篇:Tiny210裸机IIC之at24cxx操作
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210裸机之UART串口操作
S5PV210的时钟的时候,一定要参考该图。上面给出的clock_init()函数,设置的寄存器参数,都是用的推荐值,在手册中都能够查到。我以HCLKD为什么等于166.75MHz为例,来讲述如何借助芯片手册的361页和362页的图来配置时钟:      1.HCLKD是用于显示域(如LCD等)的时钟,因此在361页的途中找到HCLK_DSYS,顺着箭头方向往回找,发现它是由DIVhclkd分频而来,即HCLK_DSYS = MOUT_DSYS / (HCLK_DSYS_RATIO + 1),类似的分频系数对应于CLK_DIVn寄存器;
发表于 2018-10-13
Tiny210裸机之实现printf功能
注意:本节串口的printf等函数的实现方法可以参考OK6410的裸机“11th_uart_stdio”实验源码,该方法更实用。start.S源码:.global _start    _start:    ldr sp, =0xD0030000    @初始化堆栈        b main
发表于 2018-10-13
Tiny210裸机简单命令的实现
;   (*(volatile unsigned int *)0xe0100100) #define CLK_SRC0      (*(volatile unsigned int *)0xe0100200) #define CLK_DIV0      (*(volatile unsigned int *)0xe0100300) #define MPLL_CON      (*(volatile unsigned int
发表于 2018-10-13
Tiny210裸机之nand_flash操作
了,大家看我共享的代码,就明白,放在了"Tiny210学习日记_代码"目录下了,名为"6_nand"。测试:1).使用md命令:WY_BOOT # WY_BOOT # WY_BOOT # md 0xd0030000do_command  D0030000: 00EACEED CE4F284F 781CF81F 395E9CDE D0030010: 6B7DCBCF D4F870DB 9F07E61F 53BB9C51 2).使用nand read命令:WY_BOOT # WY_BOOT # nand read 0xd0030000 0x0
发表于 2018-10-13
Tiny210裸机之DDR_SDRAM重定位
u-boot里面的,只是自己从头对照寄存器去理解了一下,完全符合598页的初始化步骤),放在了"Tiny210学习日记_代码"目录下了,名为"7_ddr"注意:之前的代码,包括该部分代码,都没有重定位的操作,IROM最多可以拷贝16K的代码到IRAM中,够用了!但是,由于后面我会讲到LCD显示图片,声卡播放WAV文件,bootloader也随之慢慢变大,16K的大小可能不够,再加上现在已经把重定位的条件都准备好了,所以接下来将是重定位。(相关知识,大家可以学习韦东三一期视频的重定位部分),这里,我就不在细说,直接给出代码,和讲几个关键地方。以下为start.s的代码:.global
发表于 2018-10-13
Tiny210裸机之bootm命令启动内核
;  MACH_SMDKV210        SMDKV210        2456从而说明此时的机器ID是2456。注意:这个过程说得有点绕和啰嗦,再次抱歉。参数三:一句话,实在是没有什么可以说的,韦老大的视频里面讲得太详细了!!大家直接看视频和我上传的关于这章的代码吧,放在了"Tiny210学习日记_代码"目录下了,名为"9_bootm"。注意:本章写的代码,只能通过bootm命令来启动内核,延时自动启动内核,我会在后面章节讲到。
发表于 2018-10-13
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
