datasheet
自己写bootloader倒计时启动内核
2018-10-12来源: eefocus关键字:bootloader  倒计时  启动内核
start.S源码:
.global _start
_start:
    ldr sp, =0xD0030000  // 初始化栈,因为后面要调用C函数
    bl clock_init                // 初始化时钟
    bl ddr_init                   // 初始化内存
    bl nand_init                // 初始化NAND
    ldr r0, =0x36000000   // 要拷贝到DDR中的位置
    ldr r1, =0x0                 // 从NAND的0地址开始拷贝
    ldr r2, =bss_start         // BSS段的开始地址
    sub r2,r2,r0                  // 要拷贝的大小
    bl nand_read              // 拷贝数据
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    ldreq pc, =on_ddr
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
    ldr pc, =on_ddr
on_ddr:
    ldr sp, =0x33000000    // 重新初始化栈,指向内存
    ldr pc, =main
clock.c源码:
#define APLL_CON      (*(volatile unsigned int *)0xe0100100)
#define CLK_SRC0      (*(volatile unsigned int *)0xe0100200)
#define CLK_DIV0      (*(volatile unsigned int *)0xe0100300)
#define MPLL_CON      (*(volatile unsigned int *)0xe0100108)
void clock_init(void)
    // 设置时钟为:
    // ARMCLK=1000MHz, HCLKM=200MHz, HCLKD=166.75MHz
    // HCLKP =133.44MHz, PCLKM=100MHz, PCLKD=83.375MHz,
    // PCLKP =66.7MHz
    // SDIV[2:0]  : S = 1
    // PDIV[13:8] : P = 0x3
    // MDIV[25:16]: M = 0x7d
    // LOCKED [29]: 1 = 使能锁
    // ENABLE [31]: 1 = 使能APLL控制器
    // 得出FoutAPLL = 500MHz
    APLL_CON = (1<<31)|(1<<29)|(0x7d<<16)|(0x3<<8)|(1<<0);
    // 时钟源的设置
    // APLL_SEL[0] :1 = FOUTAPLL
    // MPLL_SEL[4] :1 = FOUTMPLL
    // EPLL_SEL[8] :1 = FOUTEPLL
    // VPLL_SEL[12]:1 = FOUTVPLL
    // MUX_MSYS_SEL[16]:0 = SCLKAPLL
    // MUX_DSYS_SEL[20]:0 = SCLKMPLL
    // MUX_PSYS_SEL[24]:0 = SCLKMPLL
    // ONENAND_SEL [28]:1 = HCLK_DSYS
    CLK_SRC0 = (1<<28)|(1<<12)|(1<<8)|(1<<4)|(1<<0);
    // 设置分频系数
    // APLL_RATIO[2:0]: APLL_RATIO = 0x0
    // A2M_RATIO [6:4]: A2M_RATIO  = 0x4
    // HCLK_MSYS_RATIO[10:8]: HCLK_MSYS_RATIO = 0x4
    // PCLK_MSYS_RATIO[14:12]:PCLK_MSYS_RATIO = 0x1
    // HCLK_DSYS_RATIO[19:16]:HCLK_DSYS_RATIO = 0x3
    // PCLK_DSYS_RATIO[22:20]:PCLK_DSYS_RATIO = 0x1
    // HCLK_PSYS_RATIO[27:24]:HCLK_PSYS_RATIO = 0x4
    // PCLK_PSYS_RATIO[30:28]:PCLK_PSYS_RATIO = 0x1
     CLK_DIV0 = (0x1<<28)|(0x4<<24)|(0x1<<20)|(0x3<<16)|(0x1<<12)|(0x4<<8)|(0x4<<4);
    // PDIV[13:8] : P = 0xc
    // MDIV[25:16]: M = 0x29b
    // VSEL   [27]: 0
    // ENABLE [31]: 1 = 使能MPLL控制器
    // 得出FoutAPLL = 667MHz
    APLL_CON = (1<<31)|(1<<29)|(0x29d<<16)|(0xc<<8)|(1<<0);
mem_setup.S源码:
// SDRAM Controller
#define APB_DMC_0_BASE            0xF0000000
#define APB_DMC_1_BASE            0xF1400000
#define ASYNC_MSYS_DMC0_BASE        0xF1E00000
#define ELFIN_GPIO_BASE            0xE0200000
// MemControl    BL=4, 1Chip, DDR2 Type, dynamic self refresh, force precharge, dynamic power down off
#define DMC0_MEMCONTROL        0x00202400
// MemConfig0    256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC0_MEMCONFIG_0    0x20E00323
#define DMC0_MEMCONFIG_1    0x00E00323    // MemConfig1
// TimingAref   7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC0_TIMINGA_REF        0x00000618
#define DMC0_TIMING_ROW         0x2B34438A      // TimingRow    for @200MHz
#define DMC0_TIMING_DATA        0x24240000      // TimingData   CL=3
#define DMC0_TIMING_PWR         0x0BDC0343      // TimingPower
// MemControl    BL=4, 2 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
#define    DMC1_MEMCONTROL        0x00202400
// MemConfig0    512MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC1_MEMCONFIG_0    0x40F00313
#define DMC1_MEMCONFIG_1    0x00F00313    // MemConfig1
#define DMC1_TIMINGA_REF        0x00000618
#define DMC1_TIMING_ROW         0x2B34438A      // TimingRow    for @200MHz
#define DMC1_TIMING_DATA        0x24240000      // TimingData   CL=3
#define DMC1_TIMING_PWR         0x0BDC0343      // TimingPower
#define MP1_0DRV_SR_OFFSET         0x3CC
#define MP1_1DRV_SR_OFFSET         0x3EC
#define MP1_2DRV_SR_OFFSET         0x40C
#define MP1_3DRV_SR_OFFSET         0x42C
#define MP1_4DRV_SR_OFFSET         0x44C
#define MP1_5DRV_SR_OFFSET         0x46C
#define MP1_6DRV_SR_OFFSET         0x48C
#define MP1_7DRV_SR_OFFSET         0x4AC
#define MP1_8DRV_SR_OFFSET         0x4CC
#define MP2_0DRV_SR_OFFSET         0x4EC
#define MP2_1DRV_SR_OFFSET         0x50C
#define MP2_2DRV_SR_OFFSET         0x52C
#define MP2_3DRV_SR_OFFSET         0x54C
#define MP2_4DRV_SR_OFFSET         0x56C
#define MP2_5DRV_SR_OFFSET         0x58C
#define MP2_6DRV_SR_OFFSET         0x5AC
#define MP2_7DRV_SR_OFFSET         0x5CC
#define MP2_8DRV_SR_OFFSET         0x5EC
#define DMC_CONCONTROL             0x00
#define DMC_MEMCONTROL             0x04
#define DMC_MEMCONFIG0             0x08
#define DMC_MEMCONFIG1             0x0C
#define DMC_DIRECTCMD             0x10
#define DMC_PRECHCONFIG         0x14
#define DMC_PHYCONTROL0         0x18
#define DMC_PHYCONTROL1         0x1C
#define DMC_RESERVED             0x20
#define DMC_PWRDNCONFIG         0x28
#define DMC_TIMINGAREF             0x30
#define DMC_TIMINGROW             0x34
#define DMC_TIMINGDATA             0x38
#define DMC_TIMINGPOWER         0x3C
#define DMC_PHYSTATUS             0x40
#define DMC_CHIP0STATUS         0x48
#define DMC_CHIP1STATUS         0x4C
#define DMC_AREFSTATUS             0x50
#define DMC_MRSTATUS             0x54
#define DMC_PHYTEST0             0x58
#define DMC_PHYTEST1             0x5C
#define DMC_QOSCONTROL0         0x60
#define DMC_QOSCONFIG0             0x64
#define DMC_QOSCONTROL1         0x68
#define DMC_QOSCONFIG1             0x6C
#define DMC_QOSCONTROL2         0x70
#define DMC_QOSCONFIG2             0x74
#define DMC_QOSCONTROL3         0x78
#define DMC_QOSCONFIG3             0x7C
#define DMC_QOSCONTROL4         0x80
#define DMC_QOSCONFIG4             0x84
#define DMC_QOSCONTROL5         0x88
#define DMC_QOSCONFIG5             0x8C
#define DMC_QOSCONTROL6         0x90
#define DMC_QOSCONFIG6             0x94
#define DMC_QOSCONTROL7         0x98
#define DMC_QOSCONFIG7             0x9C
#define DMC_QOSCONTROL8         0xA0
#define DMC_QOSCONFIG8             0xA4
#define DMC_QOSCONTROL9         0xA8
#define DMC_QOSCONFIG9             0xAC
#define DMC_QOSCONTROL10         0xB0
#define DMC_QOSCONFIG10         0xB4
#define DMC_QOSCONTROL11         0xB8
#define DMC_QOSCONFIG11         0xBC
#define DMC_QOSCONTROL12         0xC0
#define DMC_QOSCONFIG12         0xC4
#define DMC_QOSCONTROL13         0xC8
#define DMC_QOSCONFIG13         0xCC
#define DMC_QOSCONTROL14         0xD0
#define DMC_QOSCONFIG14         0xD4
#define DMC_QOSCONTROL15         0xD8
#define DMC_QOSCONFIG15         0xDC
// SDRAM Controller
    .globl ddr_init
ddr_init:
    // DMC0 Drive Strength (Setting 2X)
    ldr    r0, =ELFIN_GPIO_BASE
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #0x3cc]
    str    r1, [r0, #MP1_0DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_1DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_2DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_3DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_4DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_5DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_6DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_7DRV_SR_OFFSET]
    ldr    r1, =0x00002AAA
    str    r1, [r0, #MP1_8DRV_SR_OFFSET]
    // DMC0 initialization at single Type
    ldr    r0, =APB_DMC_0_BASE
    ldr    r1, =0x00101000                @PhyControl0 DLL parameter setting, manual 0x00101000
    str    r1, [r0, #DMC_PHYCONTROL0]
    ldr    r1, =0x00000086                @PhyControl1 DLL parameter setting, LPDDR/LPDDR2 Case
    str    r1, [r0, #DMC_PHYCONTROL1]
    ldr    r1, =0x00101002                @PhyControl0 DLL on
    ldr    r1, =0x00101003                @PhyControl0 DLL start
find_lock_val:
    ldr    r1, [r0, #DMC_PHYSTATUS]        @Load Phystatus register value
    and    r2, r1, #0x7
    cmp    r2, #0x7                @Loop until DLL is locked
    bne    find_lock_val
    and    r1, #0x3fc0
    mov    r2, r1, LSL #18
    orr    r2, r2, #0x100000
    orr    r2 ,r2, #0x1000
    orr    r1, r2, #0x3                @Force Value locking
    // setting DDR2
    ldr    r1, =0x0FFF2010                @ConControl auto refresh off
    str    r1, [r0, #DMC_CONCONTROL]
@MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
    ldr    r1, =DMC0_MEMCONTROL
    str    r1, [r0, #DMC_MEMCONTROL]
@MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
    ldr    r1, =DMC0_MEMCONFIG_0
    str    r1, [r0, #DMC_MEMCONFIG0]
    ldr    r1, =DMC0_MEMCONFIG_1            @MemConfig1
    str    r1, [r0, #DMC_MEMCONFIG1]
    ldr    r1, =0xFF000000                @PrechConfig
    str    r1, [r0, #DMC_PRECHCONFIG]
@TimingAref    7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
    ldr    r1, =DMC0_TIMINGA_REF
    str    r1, [r0, #DMC_TIMINGAREF]
    ldr    r1, =DMC0_TIMING_ROW            @TimingRow    for @200MHz
    str    r1, [r0, #DMC_TIMINGROW]
    ldr    r1, =DMC0_TIMING_DATA            @TimingData    CL=4
    str    r1, [r0, #DMC_TIMINGDATA]
    ldr    r1, =DMC0_TIMING_PWR            @TimingPower
    str    r1, [r0, #DMC_TIMINGPOWER]
    ldr    r1, =0x07000000                @DirectCmd    chip0 Deselect
    str    r1, [r0, #DMC_DIRECTCMD]
    ldr    r1, =0x01000000                @DirectCmd    chip0 PALL
    ldr    r1, =0x00020000                @DirectCmd    chip0 EMRS2
    ldr    r1, =0x00030000                @DirectCmd    chip0 EMRS3
    ldr    r1, =0x00010400                @DirectCmd    chip0 EMRS1 (MEM DLL on, DQS# disable)
    ldr    r1, =0x00000542                @DirectCmd    chip0 MRS (MEM DLL reset) CL=4, BL=4
    ldr    r1, =0x05000000                @DirectCmd    chip0 REFA
    ldr    r1, =0x00000442                @DirectCmd    chip0 MRS (MEM DLL unreset)
    ldr    r1, =0x00010780                @DirectCmd    chip0 EMRS1 (OCD default)
    ldr    r1, =0x00010400                @DirectCmd    chip0 EMRS1 (OCD exit)
    ldr    r1, =0x07100000                @DirectCmd    chip1 Deselect
    ldr    r1, =0x01100000                @DirectCmd    chip1 PALL
    ldr    r1, =0x00120000                @DirectCmd    chip1 EMRS2
    ldr    r1, =0x00130000                @DirectCmd    chip1 EMRS3
    ldr    r1, =0x00110400                @DirectCmd    chip1 EMRS1 (MEM DLL on, DQS# disable)
    ldr    r1, =0x00100542                @DirectCmd    chip1 MRS (MEM DLL reset) CL=4, BL=4
    ldr    r1, =0x05100000                @DirectCmd    chip1 REFA
    ldr    r1, =0x00100442                @DirectCmd    chip1 MRS (MEM DLL unreset)
    ldr    r1, =0x00110780                @DirectCmd    chip1 EMRS1 (OCD default)
    ldr    r1, =0x00110400                @DirectCmd    chip1 EMRS1 (OCD exit)
    ldr    r1, =0x0FF02030                @ConControl    auto refresh on
    ldr    r1, =0xFFFF00FF                @PwrdnConfig
    str    r1, [r0, #DMC_PWRDNCONFIG]
    ldr    r1, =0x00202400
    mov    pc, lr
nand.c源码:
#define    NFCONF  (*(volatile unsigned int *)0xB0E00000)
#define    NFCONT  (*(volatile unsigned int *)0xB0E00004)
#define    NFCMMD  (*(volatile unsigned char *)0xB0E00008)
#define    NFADDR  (*(volatile unsigned char *)0xB0E0000C)
#define    NFDATA  (*(volatile unsigned char *)0xB0E00010)
#define    NFSTAT  (*(volatile unsigned int *)0xB0E00028)
#define    MP0_3CON  (*(volatile unsigned int *)0xE0200320)
#define   MP0_1CON  (*(volatile unsigned int *)0xE02002E0)
#define PAGE_SIZE    2048
#define NAND_SECTOR_SIZE_LP    2048
void wait_idle(void)
    int i;
    while(!(NFSTAT&(1<<0)));
    for(i=0; i<10; i++);
void nand_select_chip(void)
    int i;
    NFCONT &= ~(1<<1);
void nand_deselect_chip(void)
    NFCONT |= (1<<1);
void write_cmd(int cmd)
    NFCMMD = cmd;
void write_addr(unsigned int addr)
    int i;
    NFADDR = (addr>>0) & 0xFF;
    wait_idle();
    NFADDR = (addr>>8) & 0x7;
    wait_idle();
    NFADDR = (addr>>11) & 0xFF;
    wait_idle();
    NFADDR = (addr>>19) & 0xFF;
    wait_idle();
    NFADDR = (addr>>27) & 0x1;
    wait_idle();
unsigned char read_data(void)
    return NFDATA;
static void nand_reset(void)
    nand_select_chip();
    write_cmd(0xff);  // 复位命令
    wait_idle();
    nand_deselect_chip();
void nand_init(void)
    // 设置时间参数(HCLK_PSYS = 667MHz/5 = 133MHz)
    // TACLS[15:12]: TACLS  = 1     1/133Mhz  = 7.5ns
    // TWRPH0[11:8]: TWRPH0 = 1     7.5ns * 2 = 15ns
    // TWRPH1 [7:4]: TWRPH1 = 1    7.5ns * 2 = 15ns
    // AddrCycle[1]: 1 = 指明地址周期为5次,这个是和2440的区别
    NFCONF |= 1<<12 | 1<<8 | 1<<4;
    NFCONF |= 1<<1;
    // 使能NAND控制器
    // 关闭片选信号
    NFCONT |= (1<<0)|(1<<1);
    // 设置相应管脚用于Nand Flash控制器
    MP0_3CON = 0x22222222;
    // 复位NAND Flash
    nand_reset();
    return;
// 读ID
void nand_read_id(char id[])
    int i;
    nand_select_chip();
    write_cmd(0x90);
    write_addr(0x00);
    for (i = 0; i < 5; i++)
        id[i] = read_data();
// 读一页的函数
void nand_read(unsigned char *buf, unsigned long start_addr, int size)
    int i, j;
    // 选中芯片
    nand_select_chip();
    for(i=start_addr; i < (start_addr + size);)
        // 发出READ0命令
        write_cmd(0);
        // Write Address
        write_addr(i);
        write_cmd(0x30);
        wait_idle();
        for(j=0; j < NAND_SECTOR_SIZE_LP; j++, i++)
            *buf = read_data();
            buf++;
    // 取消片选信号
void nand_write(int sdram_addr, int nand_addr, int size)
uart.c源码:
#define GPA0CON      (*(volatile unsigned int *)0xE0200000)
#define ULCON0      (*(volatile unsigned int *)0xE2900000)
#define UCON0          (*(volatile unsigned int *)0xE2900004)
#define UTRSTAT0      (*(volatile unsigned int *)0xE2900010)
#define UTXH0          (*(volatile unsigned char *)0xE2900020)
#define URXH0          (*(volatile unsigned char *)0xE2900024)
#define UBRDIV0     (*(volatile unsigned int *)0xE2900028)
#define UDIVSLOT0      (*(volatile unsigned int *)0xE290002C)
void uart_init(void)
    // 设置对应GPIO用于UART0
    GPA0CON |= 0x22;
    // 设置UART0寄存器
    // bit[1:0]:0x3 = 8位数据位
    // 其他位默认,即1位停止位,无校验,正常模式
    ULCON0 |= (0x3<<0);
    // Receive Mode [1:0]:1 = 接收采用查询或者中断模式
    // Transmit Mode[3:2]:1 = 发送采用查询或者中断模式
    // bit[6]:1 = 产生错误中断
    // bit[10]:0 = 时钟源为PCLK
    UCON0 = (1<<6)|(1<<2)|(1<<0);
    // 设置波特率(详细信息请参考手册或者学习日记)
    // DIV_VAL = UBRDIVn + (num of 1's in UDIVSLOTn)/16
    // DIV_VAL = (PCLK / (bps x 16)) - 1
    UBRDIV0 = 0x23;
    UDIVSLOT0 = 0x808;
    return;
char uart_getchar(void)
    char c;
    // 查询状态寄存器,直到有有效数据
    while (!(UTRSTAT0 & (1<<0)));
    c = URXH0; // 读取接收寄存器的值
    return c;
void uart_putchar(char c)
    // 查询状态寄存器,直到发送缓存为空
    while (!(UTRSTAT0 & (1<<2)));
    UTXH0 = c; // 写入发送寄存器
    return;
lcd.c源码:
#define GPF0CON        (*(volatile unsigned int *)0xE0200120)
#define GPF1CON        (*(volatile unsigned int *)0xE0200140)
#define GPF2CON        (*(volatile unsigned int *)0xE0200160)
#define GPF3CON        (*(volatile unsigned int *)0xE0200180)
#define GPD0CON        (*(volatile unsigned int *)0xE02000A0)
#define GPD0DAT        (*(volatile unsigned int *)0xE02000A4)
#define CLK_SRC1    (*(volatile unsigned int *)0xe0100204)
#define CLK_DIV1    (*(volatile unsigned int *)0xe0100304)
#define DISPLAY_CONTROL    (*(volatile unsigned int *)0xe0107008)
#define VIDCON0        (*(volatile unsigned int *)0xF8000000)
#define VIDCON1        (*(volatile unsigned int *)0xF8000004)
#define VIDTCON2     (*(volatile unsigned int *)0xF8000018)
#define VIDTCON3     (*(volatile unsigned int *)0xF800001c)
#define WINCON0     (*(volatile unsigned int *)0xF8000020)
#define WINCON2     (*(volatile unsigned int *)0xF8000028)
#define SHADOWCON     (*(volatile unsigned int *)0xF8000034)
#define VIDOSD0A     (*(volatile unsigned int *)0xF8000040)
#define VIDOSD0B     (*(volatile unsigned int *)0xF8000044)
#define VIDOSD0C     (*(volatile unsigned int *)0xF8000048)
#define VIDW00ADD0B0     (*(volatile unsigned int *)0xF80000A0)
#define VIDW00ADD1B0     (*(volatile unsigned int *)0xF80000D0)
#define VIDW00ADD2       (*(volatile unsigned int *)0xF8000100)
#define VIDTCON0     (*(volatile unsigned int *)0xF8000010)
#define VIDTCON1     (*(volatile unsigned int *)0xF8000014)
#define VSPW       9
#define VBPD       13
#define LINEVAL    479
#define VFPD       21
#define HSPW       19
#define HBPD       25
#define HOZVAL     799
#define HFPD       209
#define LeftTopX     0
#define LeftTopY     0
#define RightBotX   799
#define RightBotY   479
#define FRAME_BUFFER   (0x3f000000)
void lcd_init(void)
    // 1. 设置相关GPIO引脚用于LCD
    GPF0CON = 0x22222222;        // GPF0[7:0]
    GPF1CON = 0x22222222;        // GPF1[7:0]
    GPF2CON = 0x22222222;        // GPF2[7:0]
    GPF3CON = 0x22222222;        // GPF3[7:0]
    // 使能LCD本身
    GPD0CON |= 1<<4;
    GPD0DAT |= 1<<1;
    // 该寄存器是时钟相关
    // Display path selection
    // 10: RGB=FIMD I80=FIMD ITU=FIMD
    DISPLAY_CONTROL = 2<<0;
    // 2. 初始化210的display controller
    // 2.1 hsync,vsync,vclk,vden的极性和时间参数
    // 2.2 行数、列数(分辨率),象素颜色的格式
    // 2.3 分配显存(frame buffer),写入display controller
    // CLKVAL_F[13:6]:该值需要根据LCD手册做相应的修改
    //                  HCLKD=166.75MHz,DCLK(min) = 20ns(50MHz)
    //                VCLK = 166.75 / (5+1) = 28MHz
    // CLKDIR  [4]:1 = Divided by CLKVAL_F
    // ENVID   [1]:1 = Enable the video output and the Display control signal.
    // ENVID_F [0]:1 = Enable the video output and the Display control signal.
    VIDCON0 &= ~((3<<26) | (1<<18) | (0xff<<6)  | (1<<2));     // RGB I/F, RGB Parallel format,
    VIDCON0 |= ((5<<6) | (1<<4) );
    // 设置极性(该值需要根据LCD手册做相应的修改)
    // IVDEN [4]:0 = Normal
    // IVSYNC[5]:1 = Inverted
    // IHSYNC[6]:1 = Inverted
    // IVCLK [7]:0 = Video data is fetched at VCLK falling edge
    VIDCON1 &= ~(1<<7);   // 在vclk的下降沿获取数据
    VIDCON1 |= ((1<<6) | (1<<5));  // HSYNC极性反转, VSYNC极性反转
    // 设置时序(需要修改)
    VIDTCON0 = (VBPD << 16) | (VFPD << 8) | (VSPW << 0);
    VIDTCON1 = (HBPD << 16) | (HFPD << 8) | (HSPW << 0);
    // 设置屏幕的大小
    // LINEVAL[21:11]:多少行   = 480
    // HOZVAL [10:0] :水平大小 = 800
    VIDTCON2 = (LINEVAL << 11) | (HOZVAL << 0);
    // WSWP_F   [15] :1    = Swap Enable(为什么要使能),很关键的一位,能够解决掉重影问题
    // BPPMODE_F[5:2]:1011 = unpacked 24 BPP (non-palletized R:8-G:8-B:8 )
    // ENWIN_F  [0]:  1    = Enable the video output and the VIDEO control signal.
    WINCON0 &= ~(0xf << 2);
    WINCON0 |= (0xB<<2)|(1<<15);
    // 窗口0,左上角的位置(0,0)
    // 窗口0,右下角的位置(800,480)
    VIDOSD0A = (LeftTopX<<11) | (LeftTopY << 0);
    VIDOSD0B = (RightBotX<<11) | (RightBotY << 0);
    // 大小
    VIDOSD0C = (LINEVAL + 1) * (HOZVAL + 1);
    VIDW00ADD0B0 = FRAME_BUFFER;
    // VBASEL = VBASEU + (LINEWIDTH+OFFSIZE) x (LINEVAL+1)
    //        = 0 + (800*4 + 0) * 479
    VIDW00ADD1B0 =  (((HOZVAL + 1)*4 + 0) * (LINEVAL + 1)) & (0xffffff);
    //VIDW00ADD1B0 = FRAME_BUFFER + HOZVAL * LINEVAL * 4; // 新加的,是该这个吗?
    SHADOWCON = 0x1; // 使能通道0
    // LCD控制器开启
    VIDCON0  |= 0x3; // 开启总控制器
    WINCON0 |= 1;     // 开启窗口0
void lcd_draw_pixel(int row, int col, int color)
    int * pixel = (int *)FRAME_BUFFER;
    *(pixel + row * (HOZVAL+1) + col) = color;
    return;
void lcd_clear_screen(int color)
    int i, j;
    for (i = 0; i < (LINEVAL+1); i++)
        for (j = 0; j < (HOZVAL+1); j++)
            lcd_draw_pixel(i, j, color);
    return;
void lcd_draw_bmp(int bmp_file_addr)
    int i, j;
    char * p = (char *)bmp_file_addr;
    int blue, green, red;
    int color;
    // read bmp file
    // bmp file header is 54 bytes
    p += 54;
    for (i = 0; i < 480; i++)
        for (j = 0; j < 800; j++)
            blue = *p++;
            green = *p++;
            red = *p++;
            color = red << 16 | green << 8 | blue << 0;
            lcd_draw_pixel(480-i, j, color);
    return;
lib.c源码:
#include "uart.h"
void delay(void)
    volatile int i = 0x100000;
    while (i--);
void putchar_hex(char c)
    char * hex = "0123456789ABCDEF";
    uart_putchar(hex[(c>>4) & 0x0F]);
    uart_putchar(hex[(c>>0) & 0x0F]);
    return;
int putchar(int c)
    if(c == '\r')
        while(!(UTRSTAT0&(1<<1)));
        UTXH0 = '\n';
    if(c == '\n')
        UTXH0 = '\r';
    UTXH0 = c;
int getchar(void)
    int c;
    c = (int)uart_getchar();
    if (c == '\r')
        return '\n';
    return c;
int puts(const char * s)
    while (*s)
        putchar(*s++);
    return 0;
char * gets(char * s)
    char * p = s;
    while ((*p = getchar()) != '\n')
        if (*p != '\b')
            putchar(*p++);
        else
            if (p > s)
                puts ("\b \b");
                p--;
    *p = '\0';
    putchar('\n');
    return s;
void putint_hex(int a)
    putchar_hex( (a>>24) & 0xFF );
    putchar_hex( (a>>16) & 0xFF );
    putchar_hex( (a>>8) & 0xFF );
    putchar_hex( (a>>0) & 0xFF );
char * itoa(int a, char * buf)
    int num = a;
    int i = 0;
    int len = 0;
    do
        buf[i++] = num % 10 + '0';
        num /= 10;
    } while (num);
    buf[i] = '\0';
    len = i;
    for (i = 0; i < len/2; i++)
        char tmp;
        tmp = buf[i];
        buf[i] = buf[len-i-1];
        buf[len-i-1] = tmp;
    return buf;
int strcmp(const char * s1, const char * s2)
    while (*s1 == *s2)
        if (*s1 == '\0')
            return 0;
        s1++;
        s2++;
    return *s1 - *s2;
int atoi(char * buf)
    int value = 0;
    int base = 10;
    int i = 0;
    if (buf[0] == '0' && buf[1] == 'x')
        base = 16;
        i = 2;
    // 123 = (1 * 10 + 2) * 10 + 3
    // 0x1F = 1 * 16 + F(15)
    while (buf[i])
        int tmp;
        if (buf[i] <= '9' && buf[i] >= '0')
            tmp = buf[i] - '0';
        else
            tmp = buf[i] - 'a' + 10;
        value = value * base + tmp;
        i++;
    return value;
typedef int * va_list;
#define va_start(ap, A)        (ap = (int *)&(A) + 1)
#define va_arg(ap, T)        (*(T *)ap++)
#define va_end(ap)        ((void)0)
int wy_printf(const char * format, ...)
    char c;
    va_list ap;
    va_start(ap, format);
    while ((c = *format++) != '\0')
        switch (c)
            case '%':
                c = *format++;
                switch (c)
                    char ch;
                    char * p;
                    int a;
                    char buf[100];
                    case 'c':
                        ch = va_arg(ap, int);
                        putchar(ch);
                        break;
                    case 's':
                        p = va_arg(ap, char *);
                        puts(p);
                        break;
                    case 'x':
                        a = va_arg(ap, int);
                        putint_hex(a);
                        break;
                    case 'd':
                        itoa(a, buf);
                        puts(buf);
                        break;
                    default:
                        break;
                break;
            default:
                putchar(c);
                break;
    return 0;
timer.c源码:
#include "lib.h"
#define    TCFG0           (*(volatile unsigned int *)0xE2500000)
#define    TCFG1           (*(volatile unsigned int *)0xE2500004)
#define    TCON            (*(volatile unsigned int *)0xE2500008)
#define    TCNTB0         (*(volatile unsigned int *)0xE250000C)
#define    TCMPB0        (*(volatile unsigned int *)0xE2500010)
#define    TCNTO0        (*(volatile unsigned int *)0xE2500014)
void pwm_init(void)
    // 配置为GPD0_0用于PWM输出
    GPD0CON |= (0x2 << 0);     // TOUT_0
void timer0_init(void)
    // 设置时钟源
    // Timer0 input clock Frequency = 66700000 / ( {prescaler + 1} ) / {divider value}
    //      = 66700000 / (1+1) / 1
    //      = 33350000( 即1s计数33350000次 )
    TCFG0 &= ~(0xff);
    TCFG0  |= 1;           // Prescaler = 1
    TCFG1  &= ~0xf;     // 0000 = 1/1
    // 设置TCNTB0(即PWM的频率)
    TCNTB0 = 33350;   // PWM的频率为1KHz
    // 设置TCMPB0(即PWM的占空比)
    TCMPB0 = 16675;  // 占空比为50%
    TCON &= ~(1<<2); // 不进行电平反转(即引脚初始值为0)
    TCON |= (1<<3);  // auto-reload
void pwm_start(void)
    TCON |= (1<<1);  // set manual update
    TCON |= (1<<0);  // start timer 0
    TCON &= ~(1<<1); // clean manual update
void pwm_stop(void)
    TCON &= ~(1<<0);   // stop timer 0
command.c源码:
#include "lib.h"
#include "nand.h"
#include "setup.h"
extern void (*fp)(int, int, int);
int help(int argc, char * argv[])
    wy_printf("do_command 《%s》 \n", argv[0]);//实际为“<”
    wy_printf("help message: \n");
    wy_printf("md - memory dispaly\n");
    wy_printf("mw - memory write\n");
    wy_printf("nand read - nand read sdram_addr nand_addr size\n");
    wy_printf("nand write - nand write sdram_addr nand_addr size\n");
    wy_printf("bootm - boot zImage\n");
    return 0;
int md(int argc, char * argv[])
    unsigned long *p = (unsigned long *)0;
    int i, j;
    if (argc <= 1) {
        wy_printf ("Usage:\n%s\n", "md address");
        return 1;
    if (argc >= 2)
        p = (unsigned long *)atoi(argv[1]);
    for (j = 0; j < 16; j++)
        wy_printf("%x: ", p);
        for (i = 0; i < 4; i++)
            wy_printf("%x ", *p++);
        wy_printf("\n");
    return 0;
int mw(int argc, char * argv[])
    int v = 0;
    if (argc <= 2) {
        wy_printf ("Usage:\n%s\n", "md address data");
        return 1;
    if (argc >= 2)
    if (argc >= 3)
        v = atoi(argv[2]);
    *p = v;
    return 0;
int nand(int argc, char *argv[])
    int nand_addr, sdram_addr;
    unsigned int size;
    if (argc < 5)
        wy_printf("nand read sdram_addr nand_addr size\n");
        wy_printf("nand write sdram_addr nand_addr size\n");
        return 0;
    sdram_addr = atoi(argv[2]);
    nand_addr = atoi(argv[3]);
    size = atoi(argv[4]);
    wy_printf("do_command 《%s》 \n", argv[0]); //实际为“<”
    wy_printf("sdram 0x%x, nand 0x%x, size 0x%x\n", sdram_addr, nand_addr, size);
    if (strcmp(argv[1], "read") == 0)
        nand_read((unsigned char *)sdram_addr, nand_addr, size);
    if (strcmp(argv[1], "write") == 0)
        nand_write(sdram_addr, nand_addr, size);
    wy_printf("nand %s finished!\n", argv[1]);
    return 0;
int bootm(int argc, char * argv[])
    wy_printf("loading linux from 0x400000 to 0x20008000...\n");
    nand_read(0x20008000, 0x400000, 0x800000);
    wy_printf("boot linux ...\n");
    fp(0, 2456, 0x20000100);
    return 0;
void run_command(int argc, char * argv[])
    if (strcmp(argv[0], "help") == 0)
        help(argc, argv);
        return;
    if (strcmp(argv[0], "md") == 0)
        md(argc, argv);
        return;
    if (strcmp(argv[0], "mw") == 0)
        mw(argc, argv);
        return;
    if (strcmp(argv[0], "bootm") == 0)
        bootm(argc, argv);
        return;
    if (strcmp(argv[0], "nand") == 0)
        nand(argc, argv);
    if(argc >= 1)
        wy_printf("Unknown command '%s' - try 'help' \n",argv[0]);
    return;
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#include "lcd.h"
#include "timer.h"
#include "setup.h"
#define  CFG_PROMPT   "WY_BOOT # " // Monitor Command Prompt
#define  CFG_CBSIZE   256          // Console I/O Buffer Size
#define  BOOTDELAY   5             // 倒计时
char *argv[10];
int readline (const char *const prompt)
    char console_buffer[CFG_CBSIZE];        // console I/O buffer
    char *buf = console_buffer;
    int argc = 0;
    int state = 0;
    //puts(prompt);
    wy_printf("%s",prompt);
    gets(console_buffer);
    while (*buf)
        if (*buf != ' ' && state == 0)
            argv[argc++] = buf;
            state = 1;
        if (*buf == ' ' && state == 1)
            *buf = '\0';
            state = 0;
        buf++;
    return argc;
void message(void)
    wy_printf("\nThis bootloader support some command to test peripheral:\n");
    wy_printf("Such as: LCD, IIS, BUZZER \n");
    wy_printf("Try 'help' to learn them \n\n");
const char cmd[] = "root=/dev/nfs nfsroot=192.168.1.104:/work/nfs_root/wy_fs ip=192.168.1.17 console=ttySAC0";
void init_tag(int addr)
    struct tag * p;
    int i;
    p = (struct tag*) addr;
    p->hdr.tag  =  ATAG_CORE;
    p->hdr.size = tag_size(tag_core);
    p->u.core.flags = 0;
    p->u.core.pagesize = 0;
    p->u.core.rootdev = 0;
    p = tag_next(p);
    p->hdr.tag = ATAG_CMDLINE;
    p->hdr.size =  (sizeof (cmd) + sizeof(struct tag_header) + 3) >>2;
    for(i=0; i< sizeof (cmd); i++)
        p->u.cmdline.cmdline[i] = cmd[i];
    p = tag_next(p);
    p->hdr.tag = ATAG_MEM;
    p->hdr.size = tag_size(tag_mem32);
    p->u.mem.size = 512*1024*1024;
    p->u.mem.start = 0x20000000;
    p = tag_next(p);
    p->hdr.tag = ATAG_NONE;
    p->hdr.size = 0;
void init_boot_parameter(void)
    int addr = 0x20008000;
    int taglist_mem_address = 0x20000100;
    fp = (void (*)(int, int, int))addr;
    init_tag(taglist_mem_address);
int tstc (void)
    return UTRSTAT0 & 0x1;
void autoboot(void)
    int i;
    char bootdelay = BOOTDELAY;
    while(1)
        wy_printf("Hit any key to stop autoboot: %d \n", bootdelay);
        if(bootdelay == 0)
            return;
        for(i=0;i<=8;i++)
            delay();
            if( tstc() )
                return;
        bootdelay--;
    return;
int main(void)
    char buf[6];
    int argc = 0;
    int i = 0;
    led_init(); // 设置对应管脚为输出
    uart_init(); // 初始化UART0
    lcd_init(); // 初始化LCD
    nand_read_id(buf);
    timer0_init(); // 初始化定时器0,用于PWM输出
    init_boot_parameter(); // 初始化启动内核需要的相关类容
    wy_printf("\nloading logo from NAND 0xc00000 to DDR 0x3fc00000...");
    nand_read((unsigned char *)0x3fc00000, 0xC00000, 0x300000);
    wy_printf("\n**********************************************************\n");
    wy_printf("                     wy_bootloader\n");
    wy_printf("                     vars: %d \n",2012);
    wy_printf("                     nand id:");
    putchar_hex(buf[0]);
    putchar_hex(buf[1]);
    putchar_hex(buf[2]);
    putchar_hex(buf[3]);
    putchar_hex(buf[4]);
    lcd_draw_bmp(0x3fc00000); //  显示LOGO
    autoboot();  // 延时自启动
    while (1)
        argc = readline (CFG_PROMPT);
        if(argc == 0 && i ==0)
            message();
            i=1;
        run_command(argc, argv);
    return 0;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c nand.c mem_setup.S lcd.c timer.c
    arm-linux-gcc -nostdlib -c start.s -o start.o
    arm-linux-gcc -nostdlib -c main.c -o main.o
    arm-linux-gcc -nostdlib -c uart.c -o uart.o
    arm-linux-gcc -nostdlib -c lib.c -o lib.o
    arm-linux-gcc -nostdlib -c clock.c -o clock.o
    arm-linux-gcc -nostdlib -c led.c -o led.o
    arm-linux-gcc -nostdlib -c command.c -o command.o
    arm-linux-gcc -nostdlib -c nand.c -o nand.o
    arm-linux-gcc -nostdlib -c lcd.c -o lcd.o
    arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
    arm-linux-gcc -nostdlib -c timer.c -o timer.o
    arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o led.o command.o nand.o mem_setup.o lcd.o timer.o -o uart_elf
    arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
    rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
    . = 0x36000010;
    .text : {
        * (.text)
    . = ALIGN(4);
    .rodata : {
        * (.rodata)
    . = ALIGN(4);
    .data : {
        * (.data)
    . = ALIGN(4);
    bss_start = .;
    .bss  : { *(.bss)  *(COMMON) }
    bss_end = .;
倒计时自启动内核:
用官方的u-boot的时候,总是有倒计时启动内核,感觉特别的爽,因此,我得给自己写的bootloader加上该功能(方法比较粗糙)。
这部分代码没有任何难道,大家一看代码就能够明白,添加类容如下:
void autoboot(void)
    int i;
    while(1)
        if(bootdelay == 0)
            return;
        for(i=0;i<=8;i++)
            delay();
            if( tstc() )     // 这个函数只是去读UART的状态而已
                return;
        bootdelay--;
    return;
该部分代码放在了"Tiny210学习日记_代码"目录下了,名为"bootloader_bootdelay"。
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241711.html
上一篇:Tiny210裸板IIS之WM8960声卡操作
下一篇:Tiny210裸机PWM控制蜂鸣器
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
R17 Pro支持解锁Bootloader
集微网消息(文/数码控),在去年OPPO Find X发布之后,过了一段时间官方就开放了该机的解锁Bootloader(简称BL)权限,到了现在OPPO旗下又有一款机型支持解锁BL。这款机型就是R17 Pro,解锁BL的方式跟OPPO Find X一样,也是通过参与深度测试活动获得解锁资格,日前官方公布了R17 Pro解锁BL的教程,全文如下:【申请加入深度测试条件】申请必须满足以下所有条件:1.机型上市时间必须超过3个月;2.60天内无申请记录;3.OPPO账号在本机登录时间超过60天;4.深度测试用户数未达到名额上限;5.非政企和运营商定制手机;6.支持中国大陆地区上市手机。【申请加入深度测试须知】1.加入测试计划后可能会
发表于 2019-03-27
STM32学习笔记之Bootloader升级Ymodem协议简介
YModem协议YModem协议是由XModem协议演变而来的,每包数据可以达到1024字节,是一个非常高效的文件传输协议 。源码宏定义#define SOH (0x01) /* start of 128-byte data packet /#define STX (0x02) / start of 1024-byte data packet /#define EOT (0x04) / end of transmission /#define ACK (0x06) / acknowledge /#define NAK (0x15) / negative acknowledge /#define CA (0x18) / two of
发表于 2019-03-24
STM32 F4 从bootloader跳转用户代码遇到的问题
; ALIGN错误说明:有未处理的中断函数,未实现的中断函数。错误原因:1.在bootloader中使用了部分外设的中断如TIM定时器,跳转到用户程序之前未关闭外设,用户程序又没有使用这些外设。2.用户程序起始地址未对齐,此处对齐不单单是按照4字节对齐,要满足向量表的地址要求为0x200对齐,即库函数中#define VECT_TAB_OFFSET  0x20200 /*!< Vector Table base offset field.This value must be a multiple of 0x200. */关于为何是0x200整数倍的解释如下:(转自http://blog.csdn.net
发表于 2019-03-24
Realme2 Pro支持解锁Bootloader
深度测试”,手机将自动重启并进入Fastboot模式;4. 在Fastboot模式下,通过工程指令进行解锁操作,按音量键选中“Unlock The Bootloader”选项,按电源键确认后手机将进入深度测试模式并清除手机中所有用户数据。开放内核源代码以及支持解锁BL,吸引发烧友用户,将进一步扩大Realme品牌的影响力,按照Realme CEO Madhav Sheth说的,不难推测不管是已经发布的Realme2、RealmeC1、Realme U1以及其他机型,Realme旗下的机型都有望开放内核源代码和支持解锁BL,这对于开发者以及喜欢折腾的发烧友来说真是重大利好,这回可以放心的购买Realme品牌的手机啦。
发表于 2019-01-18
LPC2200系列bootloader实现过程:
网上也有类似的实现办法,有NXP官方提供的,这个容易获得,在LPCware网站上就可以下载最新的版本,相对来说,这个也是比较完整 的工程。还有ZLG的,AN070701,我看了一下,好象是BOOT,与应用在一个工程里,这个对我来说,不太合适,我要做的是两个独立的工 程,一个BOOT,一个APP,不过以上来种办法原理都是一样的;另外网上还有很多网友自己做的移植,我也下载一些看了,大多都直接或 是间接用了NXP,或是ZLG的方案。经过比较,我决定使用NXP的例子。bootloader原理是boot启动之后,首先判断是否有固件需要从串口升级,如果有则通过串口下载固件,下载完成了,把固件通过IAP烧 写在0x00010000FLASH地址
发表于 2019-01-16
STM32学习笔记之简易Bootloader串口升级设计
概念简介在学习制作串口升级 Bootloader 之前,我们先了解一下STM32的 IAP (In Application Programming)即在应用编程,IAP是用户自己的程序在运行过程中对 User Flash 的部分区域进行烧写,目的是为了在产品发布后可以方便地通过预留的通信口对产品中的固件程序进行更新升级. 设计这样的功能需要有两个项目代码:Bootloader 程序: 该部分代码用于实现通过某种通信方式(如 USB,USART)接收程序或数据,执行对第二部分代码的更新,通常存储于 Flash 的起始地址(0x08000000);App 程序: 该部分代码是产品实现业务逻辑正常运行的代码,该部分代码需要
发表于 2019-01-08
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
