datasheet
Tiny210驱动之按键中断实验
2018-10-12来源: eefocus关键字:Tiny210驱动  按键中断
third_drv.c驱动源码:
#include "linux/device.h"
#include "linux/interrupt.h"
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "linux/irq.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
#include "mach/gpio.h"
static struct class *thirddrv_class;
volatile unsigned long *gph2con;
volatile unsigned long *gph2dat;
volatile unsigned long *gph3con;
volatile unsigned long *gph3dat;
static DECLARE_WAIT_QUEUE_HEAD(button_waitq);
// 中断事件标志, 中断服务程序将它置1,third_drv_read将它清0
static volatile int ev_press = 0;
struct pin_desc{
    unsigned int pin;
    unsigned int key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85
static unsigned char key_val;
struct pin_desc pins_desc[5] = {
    {S5PV210_GPH2(3), 0x01},
    {S5PV210_GPH3(0), 0x02},
    {S5PV210_GPH3(1), 0x03},
    {S5PV210_GPH3(2), 0x04},
    {S5PV210_GPH3(3), 0x05},
// 确定按键值
static irqreturn_t buttons_irq(int irq, void *dev_id)
    struct pin_desc * pindesc = (struct pin_desc *)dev_id;
    unsigned int pinval;
    pinval = gpio_get_value(pindesc->pin);
    if (pinval)
        // 松开
        key_val = 0x80 | pindesc->key_val;
    else
        // 按下
        key_val = pindesc->key_val;
    ev_press = 1;                           // 表示中断发生了
    wake_up_interruptible(&button_waitq);   // 唤醒休眠的进程
    return IRQ_RETVAL(IRQ_HANDLED);
static int third_drv_open(struct inode *inode, struct file *file)
    // 注册中断
    request_irq(IRQ_EINT(19),  buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K4", &pins_desc[0]);
    request_irq(IRQ_EINT(24),  buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K5", &pins_desc[1]);
    request_irq(IRQ_EINT(25), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                         "K6", &pins_desc[2]);
    request_irq(IRQ_EINT(26), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                         "K7", &pins_desc[3]);
    request_irq(IRQ_EINT(27), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                         "K8", &pins_desc[4]);
    return 0;
ssize_t third_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
    if (size != 1)
        return -EINVAL;
    // 如果没有按键动作, 休眠
    wait_event_interruptible(button_waitq, ev_press);
    // 如果有按键动作, 返回键值
    copy_to_user(buf, &key_val, 1);
    ev_press = 0;
    return 1;
int third_drv_close(struct inode *inode, struct file *file)
    free_irq(IRQ_EINT(19), &pins_desc[0]);
    free_irq(IRQ_EINT(24), &pins_desc[1]);
    free_irq(IRQ_EINT(25), &pins_desc[2]);
    free_irq(IRQ_EINT(26), &pins_desc[3]);
    free_irq(IRQ_EINT(27), &pins_desc[4]);
    return 0;
static struct file_operations sencod_drv_fops = {
    .owner  =  THIS_MODULE,    // 这是一个宏,推向编译模块时自动创建的__this_module变量
    .open    =  third_drv_open,
    .read     =  third_drv_read,
    .release =  third_drv_close,
int major;
static int third_drv_init(void)
    major = register_chrdev(0, "third_drv", &sencod_drv_fops);
    thirddrv_class = class_create(THIS_MODULE, "third_drv");
    device_create(thirddrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); // /dev/buttons
    gph2con = (volatile unsigned long *)ioremap(0xe0200c40, 16);
    gph2dat = gph2con + 1;
    gph3con = (volatile unsigned long *)ioremap(0xE0200C60, 16);
    gph3dat = gph3con + 1;
    return 0;
static void third_drv_exit(void)
    unregister_chrdev(major, "third_drv");
    device_destroy(thirddrv_class, MKDEV(major, 0));
    class_destroy(thirddrv_class);
    iounmap(gph2con);
    iounmap(gph3con);
    return 0;
module_init(third_drv_init);
module_exit(third_drv_exit);
MODULE_LICENSE("GPL");
thirddrvtest.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
// thirddrvtest
int main(int argc, char **argv)
    int fd;
    fd = open("/dev/buttons", O_RDWR);
    if (fd < 0)
        printf("can't open!\n");
    while (1)
        read(fd, &key_val, 1);
        printf("key_val = 0x%x\n", key_val);
    return 0;
关键字:Tiny210驱动  按键中断
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241706.html
上一篇:Tiny210驱动之按键poll机制
下一篇:Tiny210驱动之KEY测试
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210驱动之LED测试
first_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之KEY测试
second_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之按键poll机制
;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05},};// 确定按键值static irqreturn_t buttons_irq(int
发表于 2018-10-12
Tiny210驱动之按键异步通知
, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05
发表于 2018-10-12
Tiny210按键互斥锁、原子变量驱动
, 0x84 static unsigned char key_val;// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05 // 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210
发表于 2018-10-12
stm32初学之LED按键中断
NVIC_IRQChannelCmd;} NVIC_InitTypeDef;NVIC 是属于Cortex 内核的器件,不可屏蔽中断 (NMI)和外部中断都由它来处理,而SYSTICK 不是由 NVIC 来控制的,在NVIC中配置中断优先级。弄完这些之后,就差不多了,接下来就是按照启动文件 startup_stm32f10x_hd.s 中的中断向量表定义来写中断函数了,而在stm32中stm32f10x_it.c 文件是专门用来存放中断服务函数的。所以在这下面写上中断函数就ok了。这里注意的是中断服务函数名必须要跟中断向量表中的一致。最后让程序进入死循环,通过按键中断来控制就行了。
发表于 2019-04-10
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
