datasheet
Tiny210按键互斥锁、原子变量驱动
2018-10-12来源: eefocus关键字:Tiny210  按键互斥锁  原子变量驱动
sixth_drv.c驱动源码:
#include "linux/device.h"
#include "linux/interrupt.h"
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "linux/irq.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
#include "mach/gpio.h"
#include "linux/poll.h"
static struct class *sixthdrv_class;
volatile unsigned long *gph2con;
volatile unsigned long *gph2dat;
volatile unsigned long *gph3con;
volatile unsigned long *gph3dat;
static DECLARE_WAIT_QUEUE_HEAD(button_waitq);
// 中断事件标志, 中断服务程序将它置1,sixth_drv_read将它清0
static volatile int ev_press = 0;
static struct fasync_struct *button_async;
struct pin_desc{
    unsigned int pin;
    unsigned int key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84
static unsigned char key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85
struct pin_desc pins_desc[5] = {
    {S5PV210_GPH2(3), 0x01},
    {S5PV210_GPH3(0), 0x02},
    {S5PV210_GPH3(1), 0x03},
    {S5PV210_GPH3(2), 0x04},
    {S5PV210_GPH3(3), 0x05},
//static atomic_t canopen = ATOMIC_INIT(1); //定义原子变量并初始化为1
static DECLARE_MUTEX(button_lock);             //定义互斥锁
// 确定按键值
static irqreturn_t buttons_irq(int irq, void *dev_id)
    struct pin_desc * pindesc = (struct pin_desc *)dev_id;
    unsigned int pinval;
    pinval = gpio_get_value(pindesc->pin);
    if (pinval)
        // 松开
        key_val = 0x80 | pindesc->key_val;
    else
        // 按下
        key_val = pindesc->key_val;
    ev_press = 1;                                               // 表示中断发生了
    wake_up_interruptible(&button_waitq);   // 唤醒休眠的进程
    kill_fasync (&button_async, SIGIO, POLL_IN);
    return IRQ_RETVAL(IRQ_HANDLED);
static int sixth_drv_open(struct inode *inode, struct file *file)
#if 0
    if (!atomic_dec_and_test(&canopen))
        atomic_inc(&canopen);
        return -EBUSY;
#endif
    if (file->f_flags & O_NONBLOCK)
        if (down_trylock(&button_lock))
            return -EBUSY;
    else
        // 获取信号量
        down(&button_lock);
    // 注册中断
    request_irq(IRQ_EINT(19), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                       "K4", &pins_desc[0]);
    request_irq(IRQ_EINT(24), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                       "K5", &pins_desc[1]);
    request_irq(IRQ_EINT(25), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                       "K6", &pins_desc[2]);
    request_irq(IRQ_EINT(26), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K7", &pins_desc[3]);
    request_irq(IRQ_EINT(27), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                        "K8", &pins_desc[4]);
    return 0;
ssize_t sixth_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
    if (size != 1)
        return -EINVAL;
        if (!ev_press)
            return -EAGAIN;
    else
        // 如果没有按键动作, 休眠
        wait_event_interruptible(button_waitq, ev_press);
    // 如果有按键动作, 返回键值
    copy_to_user(buf, &key_val, 1);
    ev_press = 0;
    return 1;
int sixth_drv_close(struct inode *inode, struct file *file)
    //atomic_inc(&canopen);
    free_irq(IRQ_EINT(19), &pins_desc[0]);
    free_irq(IRQ_EINT(24), &pins_desc[1]);
    free_irq(IRQ_EINT(25), &pins_desc[2]);
    free_irq(IRQ_EINT(26), &pins_desc[3]);
    free_irq(IRQ_EINT(27), &pins_desc[4]);
    up(&button_lock);
    return 0;
static unsigned sixth_drv_poll(struct file *file, poll_table *wait)
    unsigned int mask = 0;
    poll_wait(file, &button_waitq, wait); // 不会立即休眠
    if (ev_press)
        mask |= POLLIN | POLLRDNORM;
    return mask;
static int sixth_drv_fasync (int fd, struct file *filp, int on)
    printk("driver: sixth_drv_fasync\n");
    return fasync_helper (fd, filp, on, &button_async);
static struct file_operations sencod_drv_fops = {
    .owner   =  THIS_MODULE,    // 这是一个宏,推向编译模块时自动创建的__this_module变量
    .open     =  sixth_drv_open,
    .read      =  sixth_drv_read,
    .release =  sixth_drv_close,
    .poll      =  sixth_drv_poll,
    .fasync  =  sixth_drv_fasync,
int major;
static int sixth_drv_init(void)
    major = register_chrdev(0, "sixth_drv", &sencod_drv_fops);
    sixthdrv_class = class_create(THIS_MODULE, "sixth_drv");
    device_create(sixthdrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); // /dev/buttons
    gph2con = (volatile unsigned long *)ioremap(0xe0200c40, 16);
    gph2dat = gph2con + 1;
    gph3con = (volatile unsigned long *)ioremap(0xE0200C60, 16);
    gph3dat = gph3con + 1;
    return 0;
static void sixth_drv_exit(void)
    unregister_chrdev(major, "sixth_drv");
    device_destroy(sixthdrv_class, MKDEV(major, 0));
    class_destroy(sixthdrv_class);
    iounmap(gph2con);
    iounmap(gph3con);
    return 0;
module_init(sixth_drv_init);
module_exit(sixth_drv_exit);
MODULE_LICENSE("GPL");
sixthdrvtest.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
#include "poll.h"
#include "signal.h"
#include "unistd.h"
#include "fcntl.h"
// sixthdrvtest
int fd;
void my_signal_fun(int signum)
    read(fd, &key_val, 1);
    printf("key_val: 0x%x\n", key_val);
int main(int argc, char **argv)
    int ret;
    int Oflags;
    //signal(SIGIO, my_signal_fun);
    fd = open("/dev/buttons", O_RDWR | O_NONBLOCK);
    if (fd < 0)
        printf("can't open!\n");
        return -1;
    //fcntl(fd, F_SETOWN, getpid());
    //Oflags = fcntl(fd, F_GETFL);
    //fcntl(fd, F_SETFL, Oflags | FASYNC);
    while (1)
        ret = read(fd, &key_val, 1);
        printf("key_val: 0x%x, ret = %d\n", key_val, ret);
        sleep(5);
    return 0;
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241703.html
上一篇:Tiny210按键阻塞访问驱动
下一篇:Tiny210驱动之按键异步通知
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny4412友善之臂ARM开发板静态IP设置(重启有效)
刚入手Tiny4412开发板,发现它的ip地址不是192.168.1.230,老是自动跳变,今天是192.168.1.7,明天开机就变成了192.168.1.8,所以就决定将其设为静态ip地址:192.168.1.240。首先参考网上提供的一个常见的方案: 要修改arm开发板的IP,如果是yaffs2文件,可以1、首先要修改/etc/init.d/rcS文件,在/sbin/ifconfig lo 127.0.0.0下添加一行/sbin/ifconfig eth0 192.168.1.20 up注:192.168.1.20 只是举例,可以改成你想要修改的IP地址本来这样修改之后就可以的,但是我发现仍然不行,使用
发表于 2018-10-14
Tiny4412和PC传文件(含挂载NFS文件系统)方法
=Device+TreeTiny4412裸机程序汇总地址:http://www.100ask.org/bbs/forum.php?mod=viewthread&tid=11778&highlight=tiny4412iTOP-4412实现NFS网络文件系统启动(包括安装Ubuntu NFS服务、编译配置内核)http://www.oschina.net/question/2371345_2158782==================================================================驱动测试搭建开发环境:由于采用nfs作为文件系统启动失败,所以在内核启动后在把服务器的/home/book
发表于 2018-10-14
tiny4412的Uboot启动流程
基于友善之臂tiny4412开发板,uboot版本是2010.12:一般我们将UBOOT分为2个阶段,第一阶段主要为汇编代码,用于初始化必要的硬件并将UBOOT copy到SDRAM中并跳转到SDRAM执行,第二阶段主要为c代码,主要作用是加载kernel到SDRAM,准备启动kernel的参数最后跳转到kernel处执行,当然uboot里也可以有许多扩展功能,比如下载功能,实现各种驱动程序等.第一阶段:1.首先就是uboot的入口的地址是arch/arm/cpu/armv7/start.S, 这可以从相同路径下的连接脚本u-boot.lds 中知道,如下
发表于 2018-10-14
Tiny4412的MMU解析
1、Tiny4412的MMU和S3C6410都是一样的,以前的程序都可以运行,因为MMU有两个特点:  ①MMU实在cp15协处理器里面操作的,协处理器由ARM公司统一设计,不会轻易变化,这部分代码和Samsung没有关系;  ②MMU的功能就是把虚拟地址映射物理地址上去。2、为什么裸机要讲MMU?  因为中断,ARM地址的布局。现在三星处理器地址的布局和以前不一样,以前S3C6410的0地址是可以选的,比如nand flash启动的时候0地址对应片内内存;nor flash启动的时候0地址对应nor flash的0地址。也就是0地址我们可以选择是ROM或者RAM
发表于 2018-10-14
Tiny4412异常处理
=0x70003000  test.o  -o test    arm-linux-objcopy  -O binary  test  test.binclean:    rm -f test.o  test  test.bin   *~ ===================================================================烧写测试参考:“Tiny4412从SD卡启动u-boot用linux的DNW烧写裸板程序”说明:
发表于 2018-10-14
Tiny4412的MMU映射代码示例
;                   段映射只用到一级页表,页映射用到一级页表和二级页表。3、关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;
发表于 2018-10-14
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
