datasheet
Tiny210按键输入子系统
2018-10-12来源: eefocus关键字:Tiny210  按键输入  子系统
buttons.c驱动源码:
// 参考drivers\input\keyboard\gpio_keys.c
#include "linux/module.h"
#include "linux/version.h"
#include "linux/init.h"
#include "linux/fs.h"
#include "linux/interrupt.h"
#include "linux/irq.h"
#include "linux/sched.h"
#include "linux/pm.h"
#include "linux/slab.h"
#include "linux/sysctl.h"
#include "linux/proc_fs.h"
#include "linux/delay.h"
#include "linux/platform_device.h"
#include "linux/input.h"
#include "linux/gpio_keys.h"
#include "linux/workqueue.h"
#include "linux/gpio.h"
struct pin_desc{
    int irq;
    char *name;
    unsigned int pin;
    unsigned int key_val;
struct pin_desc pins_desc[4] = {
    {IRQ_EINT(19), "K4", S5PV210_GPH2(3),  KEY_L},
    {IRQ_EINT(24), "K5", S5PV210_GPH3(0),  KEY_S},
    {IRQ_EINT(25), "K6", S5PV210_GPH3(1),  KEY_ENTER},
    {IRQ_EINT(26), "K7", S5PV210_GPH3(2),  KEY_LEFTSHIFT},
static struct input_dev *buttons_dev;
static struct pin_desc *irq_pd;
static struct timer_list buttons_timer;
static irqreturn_t buttons_irq(int irq, void *dev_id)
    // 10ms后启动定时器
    irq_pd = (struct pin_desc *)dev_id;
    mod_timer(&buttons_timer, jiffies+HZ/100);
    return IRQ_RETVAL(IRQ_HANDLED);
static void buttons_timer_function(unsigned long data)
    struct pin_desc * pindesc = irq_pd;
    unsigned int pinval;
    if (!pindesc)
        return;
    pinval = gpio_get_value(pindesc->pin);
    if (pinval)
        // 松开 : 最后一个参数: 0-松开, 1-按下
        input_event(buttons_dev, EV_KEY, pindesc->key_val, 0);
        input_sync(buttons_dev);
    else
        // 按下
        input_event(buttons_dev, EV_KEY, pindesc->key_val, 1);
static int buttons_init(void)
    int i;
    // 1. 分配一个input_dev结构体
    buttons_dev = input_allocate_device();;
    // 2. 设置
    // 2.1 能产生哪类事件
    set_bit(EV_KEY, buttons_dev->evbit);
    set_bit(EV_REP, buttons_dev->evbit);
    // 2.2 能产生这类操作里的哪些事件: L,S,ENTER,LEFTSHIT
    set_bit(KEY_L, buttons_dev->keybit);
    set_bit(KEY_S, buttons_dev->keybit);
    set_bit(KEY_ENTER, buttons_dev->keybit);
    set_bit(KEY_LEFTSHIFT, buttons_dev->keybit);
    // 3. 注册
    input_register_device(buttons_dev);
    // 4. 硬件相关的操作
    init_timer(&buttons_timer);
    buttons_timer.function = buttons_timer_function;
    add_timer(&buttons_timer);
    for (i = 0; i < 4; i++)
        request_irq(pins_desc[i].irq, buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
                            pins_desc[i].name, &pins_desc[i]);
    return 0;
static void buttons_exit(void)
    int i;
        free_irq(pins_desc[i].irq, &pins_desc[i]);
    del_timer(&buttons_timer);
    input_unregister_device(buttons_dev);
    input_free_device(buttons_dev);
module_init(buttons_init);
module_exit(buttons_exit);
MODULE_LICENSE("GPL");
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241701.html
上一篇:Tiny210按键分层分离(总线-驱动-设备模型)
下一篇:Tiny210按键阻塞访问驱动
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny4412友善之臂ARM开发板静态IP设置(重启有效)
刚入手Tiny4412开发板,发现它的ip地址不是192.168.1.230,老是自动跳变,今天是192.168.1.7,明天开机就变成了192.168.1.8,所以就决定将其设为静态ip地址:192.168.1.240。首先参考网上提供的一个常见的方案: 要修改arm开发板的IP,如果是yaffs2文件,可以1、首先要修改/etc/init.d/rcS文件,在/sbin/ifconfig lo 127.0.0.0下添加一行/sbin/ifconfig eth0 192.168.1.20 up注:192.168.1.20 只是举例,可以改成你想要修改的IP地址本来这样修改之后就可以的,但是我发现仍然不行,使用
发表于 2018-10-14
Tiny4412和PC传文件(含挂载NFS文件系统)方法
=Device+TreeTiny4412裸机程序汇总地址:http://www.100ask.org/bbs/forum.php?mod=viewthread&tid=11778&highlight=tiny4412iTOP-4412实现NFS网络文件系统启动(包括安装Ubuntu NFS服务、编译配置内核)http://www.oschina.net/question/2371345_2158782==================================================================驱动测试搭建开发环境:由于采用nfs作为文件系统启动失败,所以在内核启动后在把服务器的/home/book
发表于 2018-10-14
tiny4412的Uboot启动流程
基于友善之臂tiny4412开发板,uboot版本是2010.12:一般我们将UBOOT分为2个阶段,第一阶段主要为汇编代码,用于初始化必要的硬件并将UBOOT copy到SDRAM中并跳转到SDRAM执行,第二阶段主要为c代码,主要作用是加载kernel到SDRAM,准备启动kernel的参数最后跳转到kernel处执行,当然uboot里也可以有许多扩展功能,比如下载功能,实现各种驱动程序等.第一阶段:1.首先就是uboot的入口的地址是arch/arm/cpu/armv7/start.S, 这可以从相同路径下的连接脚本u-boot.lds 中知道,如下
发表于 2018-10-14
Tiny4412的MMU解析
1、Tiny4412的MMU和S3C6410都是一样的,以前的程序都可以运行,因为MMU有两个特点:  ①MMU实在cp15协处理器里面操作的,协处理器由ARM公司统一设计,不会轻易变化,这部分代码和Samsung没有关系;  ②MMU的功能就是把虚拟地址映射物理地址上去。2、为什么裸机要讲MMU?  因为中断,ARM地址的布局。现在三星处理器地址的布局和以前不一样,以前S3C6410的0地址是可以选的,比如nand flash启动的时候0地址对应片内内存;nor flash启动的时候0地址对应nor flash的0地址。也就是0地址我们可以选择是ROM或者RAM
发表于 2018-10-14
Tiny4412异常处理
=0x70003000  test.o  -o test    arm-linux-objcopy  -O binary  test  test.binclean:    rm -f test.o  test  test.bin   *~ ===================================================================烧写测试参考:“Tiny4412从SD卡启动u-boot用linux的DNW烧写裸板程序”说明:
发表于 2018-10-14
Tiny4412的MMU映射代码示例
;                   段映射只用到一级页表,页映射用到一级页表和二级页表。3、关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;
发表于 2018-10-14
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
