datasheet
Tiny210按键分层分离(总线-驱动-设备模型)
2018-10-12来源: eefocus关键字:Tiny210  按键分层分离
led_dev.c驱动源码:
#include "linux/module.h"
#include "linux/version.h"
#include "linux/init.h"
#include "linux/kernel.h"
#include "linux/types.h"
#include "linux/interrupt.h"
#include "linux/list.h"
#include "linux/timer.h"
#include "linux/serial_core.h"
#include "linux/platform_device.h"
// 分配/设置/注册一个platform_device
static struct resource led_resource[] = {
    [0] = {
        .start = 0xE0200280,
        .end   = 0xE0200280 + 8 - 1,
        .flags = IORESOURCE_MEM,
    [1] = {
        .start = 0,
        .end   = 0,
        .flags = IORESOURCE_IRQ,
static void led_release(struct device * dev)
static struct platform_device led_dev = {
    .name                  = "myled",
    .id                        = -1,
    .num_resources  = ARRAY_SIZE(led_resource),
    .resource             = led_resource,
    .dev = {
        .release            = led_release,
static int led_dev_init(void)
    platform_device_register(&led_dev);
    return 0;
static void led_dev_exit(void)
    platform_device_unregister(&led_dev);
module_init(led_dev_init);
module_exit(led_dev_exit);
MODULE_LICENSE("GPL");
led_drv.c驱动源码:
// 分配/设置/注册一个platform_driver
#include "linux/fs.h"
#include "linux/irq.h"
#include "linux/sched.h"
#include "linux/pm.h"
#include "linux/sysctl.h"
#include "linux/proc_fs.h"
#include "linux/delay.h"
#include "linux/input.h"
#include "asm/uaccess.h"
#include "asm/io.h"
static int major;
static struct class *cls;
static volatile unsigned long *gpio_con;
static volatile unsigned long *gpio_dat;
static int pin;
static int led_open(struct inode *inode, struct file *file)
    //printk("first_drv_open\n");
    // 配置为输出
    *gpio_con &= ~(0xf<<(pin*4));
    *gpio_con |= (0x1<<(pin*4));
    return 0;
static ssize_t led_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
    int val;
    //printk("first_drv_write\n");
    copy_from_user(&val, buf, count); //    copy_to_user();
    if (val == 1)
        // 点灯
        *gpio_dat &= ~(1<
    else
        // 灭灯
        *gpio_dat |= (1<
    return 0;
static struct file_operations led_fops = {
    .owner  =   THIS_MODULE,    // 这是一个宏,推向编译模块时自动创建的__this_module变量
    .open   =   led_open,
    .write  =   led_write,
static int led_probe(struct platform_device *pdev)
    struct resource        *res;
    // 根据platform_device的资源进行ioremap
    res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
    gpio_con = ioremap(res->start, res->end - res->start + 1);
    gpio_dat = gpio_con + 1;
    res = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
    pin = res->start;
    // 注册字符设备驱动程序
    printk("led_probe, found led\n");
    major = register_chrdev(0, "myled", &led_fops);
    cls = class_create(THIS_MODULE, "myled");
    device_create(cls, NULL, MKDEV(major, 0), NULL, "led"); // /dev/led
    return 0;
static int led_remove(struct platform_device *pdev)
    // 卸载字符设备驱动程序
    // iounmap
    printk("led_remove, remove led\n");
    device_destroy(cls, MKDEV(major, 0));
    class_destroy(cls);
    unregister_chrdev(major, "myled");
    iounmap(gpio_con);
    return 0;
struct platform_driver led_drv = {
    .probe    = led_probe,
    .remove  = led_remove,
    .driver     = {
        .name = "myled",
static int led_drv_init(void)
    platform_driver_register(&led_drv);
    return 0;
static void led_drv_exit(void)
    platform_driver_unregister(&led_drv);
module_init(led_drv_init);
module_exit(led_drv_exit);
led_test.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
// led_test on
// led_test off
int main(int argc, char **argv)
    int fd;
    int val = 1;
    fd = open("/dev/led", O_RDWR);
    if (fd < 0)
        printf("can't open!\n");
    if (argc != 2)
        printf("Usage :\n");
        printf("%s 《on|off》\n", argv[0]); //实际为"<"
        return 0;
    if (strcmp(argv[1], "on") == 0)
        val  = 1;
    else
        val = 0;
    write(fd, &val, 4);
    return 0;
关键字:Tiny210  按键分层分离
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241700.html
上一篇:Tiny210驱动之LCD驱动程序
下一篇:Tiny210按键输入子系统
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny4412友善之臂ARM开发板静态IP设置(重启有效)
刚入手Tiny4412开发板,发现它的ip地址不是192.168.1.230,老是自动跳变,今天是192.168.1.7,明天开机就变成了192.168.1.8,所以就决定将其设为静态ip地址:192.168.1.240。首先参考网上提供的一个常见的方案: 要修改arm开发板的IP,如果是yaffs2文件,可以1、首先要修改/etc/init.d/rcS文件,在/sbin/ifconfig lo 127.0.0.0下添加一行/sbin/ifconfig eth0 192.168.1.20 up注:192.168.1.20 只是举例,可以改成你想要修改的IP地址本来这样修改之后就可以的,但是我发现仍然不行,使用
发表于 2018-10-14
Tiny4412和PC传文件(含挂载NFS文件系统)方法
=Device+TreeTiny4412裸机程序汇总地址:http://www.100ask.org/bbs/forum.php?mod=viewthread&tid=11778&highlight=tiny4412iTOP-4412实现NFS网络文件系统启动(包括安装Ubuntu NFS服务、编译配置内核)http://www.oschina.net/question/2371345_2158782==================================================================驱动测试搭建开发环境:由于采用nfs作为文件系统启动失败,所以在内核启动后在把服务器的/home/book
发表于 2018-10-14
tiny4412的Uboot启动流程
基于友善之臂tiny4412开发板,uboot版本是2010.12:一般我们将UBOOT分为2个阶段,第一阶段主要为汇编代码,用于初始化必要的硬件并将UBOOT copy到SDRAM中并跳转到SDRAM执行,第二阶段主要为c代码,主要作用是加载kernel到SDRAM,准备启动kernel的参数最后跳转到kernel处执行,当然uboot里也可以有许多扩展功能,比如下载功能,实现各种驱动程序等.第一阶段:1.首先就是uboot的入口的地址是arch/arm/cpu/armv7/start.S, 这可以从相同路径下的连接脚本u-boot.lds 中知道,如下
发表于 2018-10-14
Tiny4412的MMU解析
1、Tiny4412的MMU和S3C6410都是一样的,以前的程序都可以运行,因为MMU有两个特点:  ①MMU实在cp15协处理器里面操作的,协处理器由ARM公司统一设计,不会轻易变化,这部分代码和Samsung没有关系;  ②MMU的功能就是把虚拟地址映射物理地址上去。2、为什么裸机要讲MMU?  因为中断,ARM地址的布局。现在三星处理器地址的布局和以前不一样,以前S3C6410的0地址是可以选的,比如nand flash启动的时候0地址对应片内内存;nor flash启动的时候0地址对应nor flash的0地址。也就是0地址我们可以选择是ROM或者RAM
发表于 2018-10-14
Tiny4412异常处理
=0x70003000  test.o  -o test    arm-linux-objcopy  -O binary  test  test.binclean:    rm -f test.o  test  test.bin   *~ ===================================================================烧写测试参考:“Tiny4412从SD卡启动u-boot用linux的DNW烧写裸板程序”说明:
发表于 2018-10-14
Tiny4412的MMU映射代码示例
;                   段映射只用到一级页表,页映射用到一级页表和二级页表。3、关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;
发表于 2018-10-14
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
