datasheet
Tiny210驱动之LCD驱动程序
2018-10-12来源: eefocus 关键字:Tiny210驱动  LCD驱动
lcd驱动源码:
// 注意:本驱动是给S70的LCD写的驱动,若为其他的LCD,应该修改时钟和时序
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/errno.h"
#include "linux/string.h"
#include "linux/mm.h"
#include "linux/slab.h"
#include "linux/delay.h"
#include "linux/fb.h"
#include "linux/init.h"
#include "linux/dma-mapping.h"
#include "linux/interrupt.h"
#include "linux/platform_device.h"
#include "linux/clk.h"
#include "linux/cpufreq.h"
#include "asm/io.h"
#include "asm/div64.h"
#include "asm/mach/map.h"
#include "mach/regs-gpio.h"
#define MHZ (1000*1000)
#define PRINT_MHZ(m)             ((m) / MHZ), ((m / 1000) % 1000)
// LCD参数
#define VSPW       9
#define VBPD       13
#define LINEVAL   479
#define VFPD       21
#define HSPW       19
#define HBPD       25
#define HOZVAL   799
#define HFPD       209
#define LeftTopX   0
#define LeftTopY   0
#define RightBotX  799
#define RightBotY  479
// LCD控制寄存器
static unsigned long *vidcon0;  // video control 0
static unsigned long *vidcon1;  // video control 1
static unsigned long *vidcon2;  // video control 2
static unsigned long *vidtcon0; // video time control 0
static unsigned long *vidtcon1; // video time control 1
static unsigned long *vidtcon2; // video time control 2
static unsigned long *wincon0;  // window control 0
static unsigned long *vidosd0a; // video window 0 position control
static unsigned long *vidosd0b; // video window 0 position control1
static unsigned long *vidosd0c; // video window 0 position control
static unsigned long *vidw00add0b0; // window 0 buffer start address, buffer 0
static unsigned long *vidw00add1b0; // window 0 buffer end address, buffer 0
static unsigned long *vidw00add2;     // window 0 buffer size
static unsigned long *wpalcon;
static unsigned long *shadowcon;
// 用于LCD的GPIO
static unsigned long *gpf0con;
static unsigned long *gpf1con;
static unsigned long *gpf2con;
static unsigned long *gpf3con;
static unsigned long *gpd0con;
static unsigned long *gpd0dat;
//时钟
static unsigned long *clk_gate_block;
static unsigned long *display_control;
static struct fb_info *tiny_lcd;
static u32 pseudo_pal[16];
static inline unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf)
    chan &= 0xffff;
    chan >>= 16 - bf->length;
    return chan << bf->offset;
static int tiny_lcdfb_setcolreg(unsigned int regno, unsigned int red,
                 unsigned int green, unsigned int blue,
                 unsigned int transp, struct fb_info *info)
    unsigned int val;
    if (regno > 16)
        return 1;
    // 用red,green,blue三原色构造出val
    val  = chan_to_field(red,     &info->var.red);
    val |= chan_to_field(green, &info->var.green);
    val |= chan_to_field(blue,   &info->var.blue);
    //((u32 *)(info->pseudo_palette))[regno] = val;
    pseudo_pal[regno] = val;
    return 0;
static struct fb_ops tiny_lcdfb_ops = {
    .owner            = THIS_MODULE,
    .fb_setcolreg  = tiny_lcdfb_setcolreg,
    .fb_fillrect       = cfb_fillrect,
    .fb_copyarea  = cfb_copyarea,
    .fb_imageblit = cfb_imageblit,
static int tiny_lcd_init(void)
    struct clk        *tiny_clk;
    // 1. 分配一个fb_info
    tiny_lcd = framebuffer_alloc(0, NULL);
    // 2. 设置
    // 2.1 设置固定的参数
    strcpy(tiny_lcd->fix.id, "tiny_lcd");
    //tiny_lcd->fix.smem_start = ;  //显存的物理起始地址
    tiny_lcd->fix.smem_len = 800*480*4;
    tiny_lcd->fix.type = FB_TYPE_PACKED_PIXELS;
    tiny_lcd->fix.visual = FB_VISUAL_TRUECOLOR;
    tiny_lcd->fix.line_length = 800*4;
    // 2.2 设置可变的参数
    tiny_lcd->var.xres           = 800;
    tiny_lcd->var.yres           = 480;
    tiny_lcd->var.xres_virtual   = 800;
    tiny_lcd->var.yres_virtual   = 480;
    tiny_lcd->var.bits_per_pixel = 32;
    //RGB = 8:8:8
    tiny_lcd->var.red.offset     = 16;
    tiny_lcd->var.red.length     = 8;
    tiny_lcd->var.green.offset   = 8;
    tiny_lcd->var.green.length   = 8;
    tiny_lcd->var.blue.offset    = 0;
    tiny_lcd->var.blue.length    = 8;
    tiny_lcd->var.activate       = FB_ACTIVATE_NOW;
    // 2.3 设置操作函数
    tiny_lcd->fbops = &tiny_lcdfb_ops;
    // 2.4 其他的设置
    //tiny_lcd->screen_base = ; //显存的虚拟起始地址
    tiny_lcd->screen_size = 800*480*4;
    tiny_lcd->pseudo_palette = pseudo_pal;
    // 3. 硬件相关的操作
    // 3.1 配置GPIO用于LCD
    gpf0con = ioremap(0xE0200120,4);
    gpf1con = ioremap(0xE0200140,4);
    gpf2con = ioremap(0xE0200160,4);
    gpf3con = ioremap(0xE0200180,4);
    gpd0con = ioremap(0xE02000A0,4);
    gpd0dat = ioremap(0xE02000A4,4);
    *gpf0con = 0x22222222;        // GPF0[7:0]
    *gpf1con = 0x22222222;        // GPF1[7:0]
    *gpf2con = 0x22222222;        // GPF2[7:0]
    *gpf3con = 0x22222222;        // GPF3[7:0]
    *gpd0con |= 1<<4;
    *gpd0dat |= 1<<1;
    // 3.2 使能时钟
    tiny_clk = clk_get(NULL, "lcd");
    if (!tiny_clk || IS_ERR(tiny_clk)) {
        printk(KERN_INFO "failed to get lcd clock source\n");
    clk_enable(tiny_clk);
    printk("Tiny_LCD clock got enabled :: $ld.$03ld Mhz\n", PRINT_MHZ(clk_get_rate(tiny_clk))); //$为%
    // 3.3 根据LCD手册设置LCD控制器, 比如VCLK的频率等
    display_control = ioremap(0xe0107008,4);
    vidcon0  = ioremap(0xF8000000,4);
    vidcon1  = ioremap(0xF8000004,4);
    wincon0  = ioremap(0xF8000020,4);
    vidosd0a = ioremap(0xF8000040,4);
    vidosd0b = ioremap(0xF8000044,4);
    vidosd0c = ioremap(0xF8000048,4);
    vidw00add0b0  = ioremap(0xF80000A0,4);
    vidw00add1b0  = ioremap(0xF80000D0,4);
    vidw00add2    = ioremap(0xF8000100,4);
    vidtcon0      = ioremap(0xF8000010,4);
    vidtcon1      = ioremap(0xF8000014,4);
vidtc
[1] [2]
关键字:Tiny210驱动  LCD驱动
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241699.html
上一篇:Tiny210触摸屏之触摸屏控制器驱动
下一篇:最后一页
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210字符设备驱动的另外一种写法
//字符设备驱动的另外一种写法:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "linux/irq.h"#include "asm/uaccess.h"#include "asm/irq.h"
发表于 2018-10-12
S3C2440之LCD驱动代码模板(RealView MDK)
好记心不如烂笔头,为方便以后查看代码及代码重复利用,这里贴出S3C2440 LCD控制初始化代码。使用友善MINI2440开发板,LCD为320*240,开发环境为RealView MDK 4.22。该源码结构简单明了,原始工程下载地址:点击打开链接寄存器宏定义:#define rGPCCON     (*(volatile unsigned long *)0x56000020)  #define rGPCUP      (*(volatile
发表于 2018-06-04
stm32_19264液晶LCD驱动程序
编译器为:MDK4.0注意:若显示出现乱码的现象请适当修改延时函数/****************************lcd.h********************************************/#ifndef __LCD_H#define __LCD_H  #include "sys.h"#define LCD_RS  PFout(0)// PF.0#define LCD_E   PFout(1)// PF.1 #define LCD_CS1 PFout(2)// PF.2#define LCD_RST PFout(3)// PF.3#define
发表于 2018-06-03
ARM嵌入式之lcd驱动程序之显示图片
内核版本:linux-3.4.2                   lcd:4.3上代码之前我得讲解一些基本的知识点,LCD驱动我们只需要写硬件这一块的代码就可以了,下面有三个函数内核已经帮我们写好了,我们只需要调用就可以了,这几个函数实现了内核层和应用成数据的传递,有兴趣的朋友去分析一下源码,我里驱动写好了我们可以选择动态加载驱动或者直接静态编译进内核,这个的区别在前文中我讲解的非常清楚了,希望朋友一定要去看一下,Linux驱动静态编译和动态编译方法
发表于 2018-04-13
PIC16Fxxx的LCD驱动程序(适用于HD44780兼容的驱动器)
PIC16Fxxx的LCD驱动程序(适用于HD44780兼容的驱动器);************************************************;* LCD.ASM                                      *;************************************************;* Contains subroutines to control an
发表于 2018-03-12
在EM78Pxx上模拟8(COM)*8(SEG)LCD驱动
;/*=============================================================================;             在EM78Pxx上模拟8(COM)*8(SEG)LCD驱动
发表于 2018-01-29
小广播
何立民专栏
单片机及嵌入式宝典
