datasheet
Tiny210触摸屏之触摸屏控制器驱动
2018-10-12来源: eefocus关键字:Tiny210  触摸屏  控制器驱动
tiny_ts.c驱动源码:
#include "linux/errno.h"
#include "linux/kernel.h"
#include "linux/module.h"
#include "linux/slab.h"
#include "linux/input.h"
#include "linux/init.h"
#include "linux/serio.h"
#include "linux/delay.h"
#include "linux/platform_device.h"
#include "linux/clk.h"
#include "asm/io.h"
#include "asm/irq.h"
#include "asm/plat-s3c24xx/ts.h"
#include "asm/arch/regs-adc.h"
#include "asm/arch/regs-gpio.h"
#define MHZ (1000*1000)
#define PRINT_MHZ(m)             ((m) / MHZ), ((m / 1000) % 1000)
struct tiny_ts_regs {
    unsigned long tsadccon1;
    unsigned long tscon1;
    unsigned long tsdly1;
    unsigned long tsdatx1;
    unsigned long tsdaty1;
    unsigned long tspenstat1;
    unsigned long clrintadc1;
    unsigned long reserved;
    unsigned long clrintpen1;
static struct input_dev *tiny_ts_dev;
static volatile struct tiny_ts_regs *tiny_ts_regs;
static unsigned long *tsadccon0;
static struct timer_list ts_timer;
static void enter_wait_pen_down_mode(void)
    tiny_ts_regs->tscon1 = 0xd3;
static void enter_wait_pen_up_mode(void)
    tiny_ts_regs->tscon1 = 0x1d3;
static void enter_measure_xy_mode(void)
    tiny_ts_regs->tscon1 = (1<<3)|(1<<2);
static void start_adc(void)
    tiny_ts_regs->tsadccon1 |= (1<<0);
static int tiny_filter_ts(int x[], int y[])
#define ERR_LIMIT 10
    int avr_x, avr_y;
    int det_x, det_y;
    avr_x = (x[0] + x[1])/2;
    avr_y = (y[0] + y[1])/2;
    det_x = (x[2] > avr_x) ? (x[2] - avr_x) : (avr_x - x[2]);
    det_y = (y[2] > avr_y) ? (y[2] - avr_y) : (avr_y - y[2]);
    if ((det_x > ERR_LIMIT) || (det_y > ERR_LIMIT))
        return 0;
    avr_x = (x[1] + x[2])/2;
    avr_y = (y[1] + y[2])/2;
    det_x = (x[3] > avr_x) ? (x[3] - avr_x) : (avr_x - x[3]);
    det_y = (y[3] > avr_y) ? (y[3] - avr_y) : (avr_y - y[3]);
        return 0;
    return 1;
static void tiny_ts_timer_function(unsigned long data)
    if (tiny_ts_regs->tsdatx1 & (1<<15))
        // 已经松开
        input_report_abs(s3c_ts_dev, ABS_PRESSURE, 0);
        input_report_key(s3c_ts_dev, BTN_TOUCH, 0);
        input_sync(s3c_ts_dev);
        enter_wait_pen_down_mode();
    else
        // 测量X/Y坐标
        enter_measure_xy_mode();
        start_adc();
static irqreturn_t pen_down_up_irq(int irq, void *dev_id)
        //printk("pen up\n");
    else
        //printk("pen down\n");
        //enter_wait_pen_up_mode();
        start_adc();
    return IRQ_HANDLED;
static irqreturn_t adc_irq(int irq, void *dev_id)
    static int cnt = 0;
    static int x[4], y[4];
    int adcdat0, adcdat1;
    // 优化措施2: 如果ADC完成时, 发现触摸笔已经松开, 则丢弃此次结果
    adcdat0 = tiny_ts_regs->tsdatx1;
    adcdat1 = tiny_ts_regs->tsdaty1;
        // 已经松开
        cnt = 0;
    else
        // printk("adc_irq cnt = %d, x = %d, y = %d\n", ++cnt, adcdat0 & 0x3ff, adcdat1 & 0x3ff);
        // 优化措施3: 多次测量求平均值
        x[cnt] = adcdat0 & 0x3ff;
        y[cnt] = adcdat1 & 0x3ff;
        ++cnt;
        if (cnt == 4)
            // 优化措施4: 软件过滤
            if (tiny_filter_ts(x, y))
                //printk("x = %d, y = %d\n", (x[0]+x[1]+x[2]+x[3])/4, (y[0]+y[1]+y[2]+y[3])/4);
                input_report_abs(s3c_ts_dev, ABS_X, (x[0]+x[1]+x[2]+x[3])/4);
                input_report_abs(s3c_ts_dev, ABS_Y, (y[0]+y[1]+y[2]+y[3])/4);
                input_report_abs(s3c_ts_dev, ABS_PRESSURE, 1);
                input_report_key(s3c_ts_dev, BTN_TOUCH, 1);
            cnt = 0;
            // 启动定时器处理长按/滑动的情况
            mod_timer(&ts_timer, jiffies + HZ/100);
        else
            start_adc();
    return IRQ_HANDLED;
static int s3c_ts_init(void)
    struct clk* clk;
    // 1. 分配一个input_dev结构体
    tiny_ts_dev = input_allocate_device();
    // 2. 设置
    // 2.1 能产生哪类事件
    set_bit(EV_KEY, tiny_ts_dev->evbit);
    set_bit(EV_ABS, tiny_ts_dev->evbit);
    // 2.2 能产生这类事件里的哪些事件
    set_bit(BTN_TOUCH, tiny_ts_dev->keybit);
    input_set_abs_params(tiny_ts_dev, ABS_X, 0, 0x3FF, 0, 0);
    input_set_abs_params(tiny_ts_dev, ABS_Y, 0, 0x3FF, 0, 0);
    input_set_abs_params(tiny_ts_dev, ABS_PRESSURE, 0, 1, 0, 0);
    // 3. 注册
    input_register_device(tiny_ts_dev);
    // 4. 硬件相关的操作
    // 4.1 使能时钟(CLKCON[15])
    clk = clk_get(NULL, "adc");
    if (!clk || IS_ERR(clk)) {
        printk(KERN_INFO "failed to get adc clock source\n");
    clk_enable(clk);
    printk("Tiny_TS clock got enabled :: %ld.ld Mhz\n", PRINT_MHZ(clk_get_rate(tiny_clk)));
    // 4.2 设置S3C2440的ADC/TS寄存器
    tsadccon0 =  ioremap(0xE1700000, 4);
    tiny_ts_regs = ioremap(0xE1701000, sizeof(struct tiny_ts_regs));
    // s5pv210有触摸屏接口0,1
    // Tiny210开发板向外提供接口1
    // 所以这里选择接口1
    tsadccon0 |= 1<<17;
    // bit[14]  : 1-A/D converter prescaler enable
    // bit[13:6]: A/D converter prescaler value,
    //            65, ADCCLK=PCLKP/(65+1)=66.7MHz/(65+1)=1MHz
    // bit[2]: 默认为1,即Standby mode,我们要设置为0,正常模式
    // bit[0]: A/D conversion starts by enable. 先设为0
    tiny_ts_regs->tsadccon1 &= ~(1<<2);
    tiny_ts_regs->tsadccon1 |= (1<<14)|(65<<6);
    request_irq(IRQ_TC, pen_down_up_irq, IRQF_SAMPLE_RANDOM, "ts_pen", NULL);
    request_irq(IRQ_ADC, adc_irq, IRQF_SAMPLE_RANDOM, "adc", NULL);
    // 优化措施1:
    // 设置ADCDLY为最大值, 这使得电压稳定后再发出IRQ_TC中断
    tiny_ts_regs->tsdaty1 = 0xffff;
    // 优化措施5: 使用定时器处理长按,滑动的情况
    init_timer(&ts_timer);
    ts_timer.function = tiny_ts_timer_function;
    add_timer(&ts_timer);
    return 0;
static void s3c_ts_exit(void)
    free_irq(IRQ_TC, NULL);
    free_irq(IRQ_ADC, NULL);
    iounmap(tiny_ts_regs);
    iounmap(tsadccon0);
    input_unregister_device(tiny_ts_dev);
    input_free_device(tiny_ts_dev);
    del_timer(&ts_timer);
module_init(s3c_ts_init);
module_exit(s3c_ts_exit);
MODULE_LICENSE("GPL");
测试以及tslib-1.4.tar.gz安装编译方法参考:“触摸屏驱动程序(输入子系统)
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241698.html
上一篇:Tiny210触摸屏之一线触摸屏驱动
下一篇:Tiny210驱动之LCD驱动程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny4412友善之臂ARM开发板静态IP设置(重启有效)
刚入手Tiny4412开发板,发现它的ip地址不是192.168.1.230,老是自动跳变,今天是192.168.1.7,明天开机就变成了192.168.1.8,所以就决定将其设为静态ip地址:192.168.1.240。首先参考网上提供的一个常见的方案: 要修改arm开发板的IP,如果是yaffs2文件,可以1、首先要修改/etc/init.d/rcS文件,在/sbin/ifconfig lo 127.0.0.0下添加一行/sbin/ifconfig eth0 192.168.1.20 up注:192.168.1.20 只是举例,可以改成你想要修改的IP地址本来这样修改之后就可以的,但是我发现仍然不行,使用
发表于 2018-10-14
Tiny4412和PC传文件(含挂载NFS文件系统)方法
=Device+TreeTiny4412裸机程序汇总地址:http://www.100ask.org/bbs/forum.php?mod=viewthread&tid=11778&highlight=tiny4412iTOP-4412实现NFS网络文件系统启动(包括安装Ubuntu NFS服务、编译配置内核)http://www.oschina.net/question/2371345_2158782==================================================================驱动测试搭建开发环境:由于采用nfs作为文件系统启动失败,所以在内核启动后在把服务器的/home/book
发表于 2018-10-14
tiny4412的Uboot启动流程
基于友善之臂tiny4412开发板,uboot版本是2010.12:一般我们将UBOOT分为2个阶段,第一阶段主要为汇编代码,用于初始化必要的硬件并将UBOOT copy到SDRAM中并跳转到SDRAM执行,第二阶段主要为c代码,主要作用是加载kernel到SDRAM,准备启动kernel的参数最后跳转到kernel处执行,当然uboot里也可以有许多扩展功能,比如下载功能,实现各种驱动程序等.第一阶段:1.首先就是uboot的入口的地址是arch/arm/cpu/armv7/start.S, 这可以从相同路径下的连接脚本u-boot.lds 中知道,如下
发表于 2018-10-14
Tiny4412的MMU解析
1、Tiny4412的MMU和S3C6410都是一样的,以前的程序都可以运行,因为MMU有两个特点:  ①MMU实在cp15协处理器里面操作的,协处理器由ARM公司统一设计,不会轻易变化,这部分代码和Samsung没有关系;  ②MMU的功能就是把虚拟地址映射物理地址上去。2、为什么裸机要讲MMU?  因为中断,ARM地址的布局。现在三星处理器地址的布局和以前不一样,以前S3C6410的0地址是可以选的,比如nand flash启动的时候0地址对应片内内存;nor flash启动的时候0地址对应nor flash的0地址。也就是0地址我们可以选择是ROM或者RAM
发表于 2018-10-14
Tiny4412异常处理
=0x70003000  test.o  -o test    arm-linux-objcopy  -O binary  test  test.binclean:    rm -f test.o  test  test.bin   *~ ===================================================================烧写测试参考:“Tiny4412从SD卡启动u-boot用linux的DNW烧写裸板程序”说明:
发表于 2018-10-14
Tiny4412的MMU映射代码示例
;                   段映射只用到一级页表,页映射用到一级页表和二级页表。3、关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;
发表于 2018-10-14
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
