datasheet
Tiny210块设备驱动之内存模拟磁盘
2018-10-12来源: eefocus关键字:Tiny210  块设备驱动  内存模拟磁盘
ramblock.c驱动源码:
#include "linux/module.h"
#include "linux/errno.h"
#include "linux/interrupt.h"
#include "linux/mm.h"
#include "linux/fs.h"
#include "linux/kernel.h"
#include "linux/timer.h"
#include "linux/genhd.h"
#include "linux/hdreg.h"
#include "linux/ioport.h"
#include "linux/init.h"
#include "linux/wait.h"
#include "linux/blkdev.h"
#include "linux/blkpg.h"
#include "linux/delay.h"
#include "linux/io.h"
#include "linux/gfp.h"
#include "linux/slab.h"
#include "asm/system.h"
#include "asm/uaccess.h"
#include "asm/dma.h"
#define RAMDISK_SIZE (1024*1024)
static DEFINE_SPINLOCK(ramdisk_lock);
static const struct block_device_operations ramdisk_fops = {
    .owner    = THIS_MODULE,
static struct gendisk *ramblock_disk;
static struct request_queue *ramblock_queue;
static unsigned char *ram_buff;
static int major;
static void ramblock_do_request(struct request_queue * q)
    struct request *req;
    printk("do:ramblock_do_request\n");
    req = blk_fetch_request(q);
    while (req)
        //源或目的
        unsigned long offset = blk_rq_pos(req) * 512;
        //目的或源
        //req->buffer
        //长度
        unsigned long len  = blk_rq_cur_bytes(req);
        if (rq_data_dir(req) == READ)
            memcpy(req->buffer, ram_buff+offset, len);
        else
            memcpy(ram_buff+offset, req->buffer, len);
        // wrap up, 0 = success, -errno = fail
        if (!__blk_end_request_cur(req, 0))
static int ramblock_init(void)
    //获得主设备号
    major = register_blkdev(major, "ramdisk");
    //1.分配一个gendisk结构体
    ramblock_disk = alloc_disk(16);
    //2.设置
    //2.1设置一个请求队列
    ramblock_queue = blk_init_queue(ramblock_do_request, &ramdisk_lock);
    ramblock_disk->queue = ramblock_queue;
    //2.2设置其他信息
    ramblock_disk->major = major;
    ramblock_disk->first_minor = 0;
    sprintf(ramblock_disk->disk_name, "ramdisk");
    ramblock_disk->fops = &ramdisk_fops;
    set_capacity(ramblock_disk, RAMDISK_SIZE);
    //3.硬件相关
    ram_buff = kzalloc(RAMDISK_SIZE, GFP_KERNEL);
    //4.注册
    add_disk(ramblock_disk);
    return 0;
static void ramblock_exit(void)
    unregister_blkdev(major, "ramdisk");
    del_gendisk(ramblock_disk);
    put_disk(ramblock_disk);
    blk_cleanup_queue(ramblock_queue);
    kfree(ram_buff);
module_init(ramblock_init);
module_exit(ramblock_exit);
MODULE_LICENSE("GPL");
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241695.html
上一篇:Tiny210驱动之NAND_FLASH驱动程序
下一篇:Tiny210驱动之USB设备驱动程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny4412友善之臂ARM开发板静态IP设置(重启有效)
刚入手Tiny4412开发板,发现它的ip地址不是192.168.1.230,老是自动跳变,今天是192.168.1.7,明天开机就变成了192.168.1.8,所以就决定将其设为静态ip地址:192.168.1.240。首先参考网上提供的一个常见的方案: 要修改arm开发板的IP,如果是yaffs2文件,可以1、首先要修改/etc/init.d/rcS文件,在/sbin/ifconfig lo 127.0.0.0下添加一行/sbin/ifconfig eth0 192.168.1.20 up注:192.168.1.20 只是举例,可以改成你想要修改的IP地址本来这样修改之后就可以的,但是我发现仍然不行,使用
发表于 2018-10-14
Tiny4412和PC传文件(含挂载NFS文件系统)方法
=Device+TreeTiny4412裸机程序汇总地址:http://www.100ask.org/bbs/forum.php?mod=viewthread&tid=11778&highlight=tiny4412iTOP-4412实现NFS网络文件系统启动(包括安装Ubuntu NFS服务、编译配置内核)http://www.oschina.net/question/2371345_2158782==================================================================驱动测试搭建开发环境:由于采用nfs作为文件系统启动失败,所以在内核启动后在把服务器的/home/book
发表于 2018-10-14
tiny4412的Uboot启动流程
基于友善之臂tiny4412开发板,uboot版本是2010.12:一般我们将UBOOT分为2个阶段,第一阶段主要为汇编代码,用于初始化必要的硬件并将UBOOT copy到SDRAM中并跳转到SDRAM执行,第二阶段主要为c代码,主要作用是加载kernel到SDRAM,准备启动kernel的参数最后跳转到kernel处执行,当然uboot里也可以有许多扩展功能,比如下载功能,实现各种驱动程序等.第一阶段:1.首先就是uboot的入口的地址是arch/arm/cpu/armv7/start.S, 这可以从相同路径下的连接脚本u-boot.lds 中知道,如下
发表于 2018-10-14
Tiny4412的MMU解析
1、Tiny4412的MMU和S3C6410都是一样的,以前的程序都可以运行,因为MMU有两个特点:  ①MMU实在cp15协处理器里面操作的,协处理器由ARM公司统一设计,不会轻易变化,这部分代码和Samsung没有关系;  ②MMU的功能就是把虚拟地址映射物理地址上去。2、为什么裸机要讲MMU?  因为中断,ARM地址的布局。现在三星处理器地址的布局和以前不一样,以前S3C6410的0地址是可以选的,比如nand flash启动的时候0地址对应片内内存;nor flash启动的时候0地址对应nor flash的0地址。也就是0地址我们可以选择是ROM或者RAM
发表于 2018-10-14
Tiny4412异常处理
=0x70003000  test.o  -o test    arm-linux-objcopy  -O binary  test  test.binclean:    rm -f test.o  test  test.bin   *~ ===================================================================烧写测试参考:“Tiny4412从SD卡启动u-boot用linux的DNW烧写裸板程序”说明:
发表于 2018-10-14
Tiny4412的MMU映射代码示例
;                   段映射只用到一级页表,页映射用到一级页表和二级页表。3、关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;
发表于 2018-10-14
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
