datasheet
OK6410裸机学习之时钟设置-C语言
2018-10-11来源: eefocus关键字:OK6410  裸机  时钟设置  C语言
start.S源码:
.globl _start
_start:
// 硬件相关的设置
    // Peri port setup
    ldr r0, =0x70000000
    orr r0, r0, #0x13
    mcr p15,0,r0,c15,c2,4       @ 256M(0x70000000-0x7fffffff)
// 关看门狗
    // 往WTCON(0x7E004000)写0
    ldr r0, =0x7E004000
    mov r1, #0
    str r1, [r0]
    // 设置栈
    ldr sp, =8*1024
    // 设置时钟
    bl clock_init
    bl main
halt:
    b halt
clock.c源码:
#define APLL_LOCK (*((volatile unsigned long *)0x7E00F000))
#define MPLL_LOCK (*((volatile unsigned long *)0x7E00F004))
#define EPLL_LOCK (*((volatile unsigned long *)0x7E00F008))
#define OTHERS    (*((volatile unsigned long *)0x7e00f900))
#define CLK_DIV0  (*((volatile unsigned long *)0x7E00F020))
#define ARM_RATIO    0     // ARMCLK = DOUTAPLL / (ARM_RATIO + 1)
#define HCLKX2_RATIO 4   // HCLKX2 = HCLKX2IN / (HCLKX2_RATIO + 1) = 100MHz
#define HCLK_RATIO   0     // HCLK = HCLKX2 / (HCLK_RATIO + 1)   = 100MHz
#define PCLK_RATIO   1     // PCLK   = HCLKX2 / (PCLK_RATIO + 1) = 50MHz
#define MPLL_RATIO   0    // DOUTMPLL = MOUTMPLL / (MPLL_RATIO + 1)
#define APLL_CON  (*((volatile unsigned long *)0x7E00F00C))
#define APLL_CON_VAL  ((1<<31) | (250 << 16) | (3 << 8) | (1))
#define MPLL_CON  (*((volatile unsigned long *)0x7E00F010))
#define MPLL_CON_VAL  ((1<<31) | (250 << 16) | (3 << 8) | (1))
#define CLK_SRC   (*((volatile unsigned long *)0x7E00F01C))
//MDIV=250 对应: ARMCLK = 500MHz, HCLK = 100MHz, PCLK = 50MHZ
//MDIV=266 对应: ARMCLK = 532MHz, HCLK = 133MHz, PCLK = 66.5MHZ
void clock_init(void)
    APLL_LOCK = 0xffff;
    MPLL_LOCK = 0xffff;
    EPLL_LOCK = 0xffff;
    // set async mode 当CPU时钟 != HCLK时,要设为异步模式
    OTHERS &= ~0xc0;
    while ((OTHERS & 0xf00) != 0);
    CLK_DIV0 = (ARM_RATIO) | (MPLL_RATIO << 4) | (HCLK_RATIO << 8) | (HCLKX2_RATIO << 9) | (PCLK_RATIO << 12);
    APLL_CON = APLL_CON_VAL;    // 500MHz
    MPLL_CON = MPLL_CON_VAL;  // 500MHz
    CLK_SRC = 0x03;
led.c源码:
void delay()
    volatile int i = 0x10000;
    while (i--);
int main()
    int i = 0;
    volatile unsigned long *gpmcon = (volatile unsigned long *)0x7F008820;
    volatile unsigned long *gpmdat = (volatile unsigned long *)0x7F008824;
    // gpm0,1,2,3设为输出引脚
    *gpmcon = 0x1111;
    while (1)
        *gpmdat = i;
        i++;
        if (i == 16)
            i = 0;
        delay();
    return 0;
Makefile:
led.bin: start.o clock.o led.o
    arm-linux-ld -Ttext 0 -o led.elf start.o clock.o led.o
    arm-linux-objcopy -O binary led.elf led.bin
    arm-linux-objdump -D led.elf > led.dis
%.o : %.S
    arm-linux-gcc -o $@ $< -c
%.o : %.c
clean:
    rm *.o led.elf led.bin led.dis
OK6410裸机学习之时钟设置-C语言
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101141675.html
上一篇:OK6410裸机学习之串口实验
下一篇:OK6410裸机学习之时钟设置-汇编
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
OK6410开发板uboot烧写
uboot的移植完成以后,满以为很快能烧写到板子上并安装linux,结果uboot烧写了三天才终于成功,这其中碰到了不少的问题,在此做个总结。首先,飞凌的OK6410开发板并不支持JLink烧写uboot,只能通过SD卡来烧写,这一点我事先并不知道,他们网店介绍里并未说明,而且销售人员也没有做出任何提示,结果我花了整整一天时间尝试所有通过JLink烧写uboot的可能方法,结合网上个别人反映,最终意识到通过JLink完成uboot烧写是不可能成功的了,后来在销售人员那里确认了这一点,对飞凌表示不满。当时买板的时候没有买SD卡,因为感觉没什么用,就想给老板省点钱,现在没SD卡不行了,但在寻找JLink烧写uboot方法的过程中我发现
发表于 2018-10-12
OK6410裸机汇编:1th_led
;   rm *.o led.elf led.bin led.dis=====================================================================下载测试,下载方法可以参考“烧写OK6410裸板方法汇总”章节介绍:    用SecureCRT下载led.bin:    tftp 0x50008000 led.bin    go 0x50008000即可看到程序运行效果。
发表于 2018-10-12
OK6410裸机学习第二天:2th_leds
start.S文件:.globl _start_start:1、硬件相关的设置:把外设的基地址告诉CPU 0 ~ 0x6fff ffff为内存的地址空间,0x7000 0000 ~ 0x7fff ffff为外设寄存器的地址空间       ldr r0, =0x70000000    orr r0, r0, #0x13    mcr p15,0,r0,c15,c2,4       @ 256M(0x70000000-
发表于 2018-10-12
OK6410裸机学习第三天:3th_leds_c
start.S文件:.globl _start_start:1、硬件相关的设置:把外设的基地址告诉CPU 0 ~ 0x6fff ffff为内存的地址空间,0x7000 0000 ~ 0x7fff ffff为外设寄存器的地址空间    //Peri port setup     ldr r0, =0x70000000    orr r0, r0, #0x13    mcr p15,0,r0,c15,c2,4     &
发表于 2018-10-12
OK6410裸机学习第四天:4th_leds_params
发表于 2018-10-12
OK6410光盘里的uboot不能用TFTP下载文件?
无论用ping命令还是tftp命令,都显示CS8900 Ethernet chip not found?!看了uboot1.1.6/include/configs/smdk6410.h,里面确实是配置为网卡使用CS8900,什么时候发布个配置为DM9000的uboot源码啊?或者发个补丁也行此问题已解决 方法很简单,给用飞凌S3C6410的朋友一个参考。  a.用\u-boot-1.1.6-TQ6410\drivers\目录下的dm9000x.c和dm9000x.h替换OK6410的u-boot里的同名文件  b.用\u-boot-1.1.6-TQ6410\include\configs\tq6410.h里配置网卡的几行代码替换
发表于 2018-10-12
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
