datasheet
NRF24L01实现msp430单片机通信(SPI)
2018-07-11来源: eefocus 关键字:NRF24L01  msp430  单片机通信  SPI
24l01.h
#ifndef _24L01_H_
#define _24L01_H_
typedef unsigned char     BYTE;
#define uchar unsigned char
//24L01发送接收数据宽度定义
#define TX_ADR_WIDTH    5   //5字节的地址宽度
#define RX_ADR_WIDTH    5   //5字节的地址宽度
#define TX_PLOAD_WIDTH  7  //20字节的用户数据宽度
#define RX_PLOAD_WIDTH  7  //20字节的用户数据宽度
#define nRF_TX_Mode 0x00
#define nRF_RX_Mode 0x01
// SPI(nRF24L01) commands
#define READ_REG         0x00  // Define read command to register
#define WRITE_REG       0x20  // Define write command to register
#define RD_RX_PLOAD 0x61  // Define RX payload register address
#define WR_TX_PLOAD  0xA0  // Define TX payload register address
#define FLUSH_TX         0xE1  // Define flush TX register command
#define FLUSH_RX         0xE2  // Define flush RX register command
#define REUSE_TX_PL    0xE3  // Define reuse TX payload register command
#define NOP             0xFF  // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG           0x00  // 'Config' register address
#define EN_AA           0x01  // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR       0x02  // 'Enabled RX addresses' register address
#define SETUP_AW         0x03  // 'Setup address width' register address
#define SETUP_RETR      0x04  // 'Setup Auto. Retrans' register address
#define RF_CH           0x05  // 'RF channel' register address
#define RF_SETUP         0x06  // 'RF setup' register address
#define STATUS           0x07  // 'Status' register address
#define OBSERVE_TX      0x08  // 'Observe TX' register address
#define CD               0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A  // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B  // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C  // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D  // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E  // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F  // 'RX address pipe5' register address
#define TX_ADDR         0x10  // 'TX address' register address
#define RX_PW_P0         0x11  // 'RX payload width, pipe0' register address
#define RX_PW_P1         0x12  // 'RX payload width, pipe1' register address
#define RX_PW_P2         0x13  // 'RX payload width, pipe2' register address
#define RX_PW_P3         0x14  // 'RX payload width, pipe3' register address
#define RX_PW_P4         0x15  // 'RX payload width, pipe4' register address
#define RX_PW_P5         0x16  // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
//STATUS REG ?μ?÷
#define MAX_RT   0x10  //′?μ?×?′ó·¢?í′?êy?D??
#define TX_OK   0x20  //TX·¢?ííê3é?D??
#define RX_OK   0x40  //?óê?μ?êy?Y?D??
#define nRF24L01_CE_1         P4OUT |=  BIT4              //CE = 1
#define nRF24L01_CE_0         P4OUT &=~ BIT4            //CE = 0
#define nRF24L01_CSN_1       P4OUT |=  BIT5             //CSN = 1
#define nRF24L01_CSN_0       P4OUT &=~ BIT5            //CSN = 0
#define nRF24L01_SCK_1       P5OUT |=  BIT3              //SCK = 1
#define nRF24L01_SCK_0       P5OUT &=~ BIT3            //SCK = 0
#define nRF24L01_MOSI_1   P5OUT |=  BIT2         //MOSI = 1
#define nRF24L01_MOSI_0   P5OUT &=~ BIT2       //MOSI = 0
#define nRF24L01_MISO_IN     ((P5IN>>1)  & 0x01)    //读入MISO,P5.1//((P5IN >> 1) & 0x04)
///===============REG setting data===============
//===0x00 CONFIG===============
#define MASK_RX_DR 0x40
#define MASK_TX_DS 0x20
#define MASK_MAX_RT 0x10
#define EN_CRC 0x08
#define CRCO 0x04// 0---1byte,1---2byte
#define PWR_UP 0x02// 1---power up,0---power down
#define PRIM_RX 0x01// 1---RX mode,0---TX mode
//===0x01 EN_AA================
//使能自响应通道,默认5通道全开
#define ENAA_P5 0x20
#define ENAA_P4 0x10
#define ENAA_P3 0x08
#define ENAA_P2 0x04
#define ENAA_P1 0x02
#define ENAA_P0 0x01
#define ENAA_DisableALL 0x00
//===0x02 EN_RXADDR============
#define ERX_P5 0x20
#define ERX_P4 0x10
#define ERX_P3 0x08
#define ERX_P2 0x04
#define ERX_P1 0x02
#define ERX_P0 0x01
#define ERX_None 0x00
//===0x03 SETUP_AW=============
#define AW_3Bytes 0x01
#define AW_4Bytes 0x02
#define AW_5Bytes 0x03
//===0x04 SETUP_RETR============
#define AutoReTxDalay_250uS 0x00//default
#define AutoReTxDalay_500uS 0x10
#define AutoReTxDalay_750uS 0x20
#define AutoReTxDalay_1000uS 0x30
#define AutoReTxDalay_1250uS 0x40
#define AutoReTxDalay_1500uS 0x50
#define AutoReTxDalay_1750uS 0x60
#define AutoReTxDalay_2000uS 0x70
#define AutoReTxDalay_2250uS 0x80
#define AutoReTxDalay_2500uS 0x90
#define AutoReTxDalay_2750uS 0xA0
#define AutoReTxDalay_3000uS 0xB0
#define AutoReTxDalay_3250uS 0xC0
#define AutoReTxDalay_3500uS 0xD0
#define AutoReTxDalay_3750uS 0xE0
#define AutoReTxDalay_4000uS 0xF0
#define AutoReTx_Disable 0x00
#define AutoReTxTimes_1 0x01
#define AutoReTxTimes_2 0x02
#define AutoReTxTimes_3 0x03//default
#define AutoReTxTimes_4 0x04
#define AutoReTxTimes_5 0x05
#define AutoReTxTimes_6 0x06
#define AutoReTxTimes_7 0x07
#define AutoReTxTimes_8 0x08
#define AutoReTxTimes_9 0x09
#define AutoReTxTimes_10 0x0A
#define AutoReTxTimes_11 0x0B
#define AutoReTxTimes_12 0x0C
#define AutoReTxTimes_13 0x0D
#define AutoReTxTimes_14 0x0E
#define AutoReTxTimes_15 0x0F
//===0x06 RF_SETUP============
#define RF_DR_1Mbps 0x00
#define RF_DR_2Mbps 0x08
//#define RF_PWR_
uchar SPI_RW(uchar byte);
uchar SPI_RW_Reg(BYTE reg, BYTE value);
BYTE SPI_Read(BYTE reg);
uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes);
uchar SPI_Write_Buf(BYTE reg, BYTE const *pBuf, BYTE bytes);
void RX_Mode(void);
void TX_Mode(void);
void nRF24L01_Init(unsigned char Mode);
void nRF24L01_Send(void);
void nRF24L01_Revceive(void);
uchar NRF_Check(void);
void nRF24L01_IO_set(void);
#endif
24l01.c
#include  <msp430x14x.h>
#include "24l01.h"
unsigned char TestBuf=0;
uchar  const TX_ADDRESS[TX_ADR_WIDTH]  = {0x6d,0x61,0x67,0x69,0x63}; // Define a static TX address
uchar rx_buf[RX_PLOAD_WIDTH];
uchar tx_buf[TX_PLOAD_WIDTH]={0xB3,0x73,0x6b,0x79,0x00,0x00,0x00};//,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02};
uchar flag,q;
//延时函数
void delay_50us(unsigned int i)
//for(unsigned char i=0; i<77; i++);
unsigned long j;
for(;i>0;i--)
for(j=0;j<33;j++);//50.4us
void delay_100ms(unsigned int i)
unsigned long j;
for(;i>0;i--)
for(j=0;j<144200;j++);
void msDelay(unsigned int ms)
    unsigned int i,j;
    for(i=0;i    {
       j=1329;;
       while(j--);
void delay_1ms(unsigned int i)
unsigned long j;
for(;i>0;i--)
//for(j=0;j<640;j++);//8M--->880us
for(j=0;j<730;j++);//8M--->1ms
//for(j=0;j<80;j++);//1M
//for(j=0;j<200;j++);//1M 1ms延时是对的,但345数据在12ms就准备完成了,这影响后面计数
void inerDelay_us(int n)
for(;n>0;n--);
void CE_Pin(BYTE state)
    if(state)
    nRF24L01_CE_1;
  else
    nRF24L01_CE_0;
void CSN_Pin(BYTE state)                                // Set/reset CSN pin
    if(state)
    nRF24L01_CSN_1;
  else
    nRF24L01_CSN_0;
void SCK_Pin(BYTE state)                                // Set/reset SCK pin
  if(state)
    nRF24L01_SCK_1;
  else
    nRF24L01_SCK_0;
void MOSI_Pin(BYTE state)                               // Set/reset MOSI pin
  if(state)
    nRF24L01_MOSI_1;
  else
    nRF24L01_MOSI_0;
BYTE MISO_Pin(void)                                     // Read MISO pin
  return nRF24L01_MISO_IN;
//Function: SPI_RW();
//escription:
 // Writes one byte to nRF24L01, and return the byte read
 // from nRF24L01 during write, according to SPI protocol
uchar bit_ctr;
    for(bit_ctr=0;bit_ctr<8;bit_ctr++)   // output 8-bit
    MOSI_Pin(byte&0x80);         // output 'byte', MSB to MOSI
    byte = (byte << 1);           // shift next bit into MSB..
    SCK_Pin(1);// Set SCK high..
    byte|=MISO_Pin();        // capture current MISO bit
    SCK_Pin(0);              // ..then set SCK low again
    return(byte);            // return read byte
//Function: SPI_RW_Reg();
//Description:
 // Writes value 'value' to register 'reg'
        uchar status;
  CSN_Pin(0);                   // CSN low, init SPI transaction
  status = SPI_RW(reg);      // select register
  SPI_RW(value);             // ..and write value to it..
  CSN_Pin(1);                   // CSN high again
  return(status);            // return nRF24L01 status byte
Function: SPI_Read();
Description:
  Read one byte from nRF24L01 register, 'reg'
BYTE reg_val;
  CSN_Pin(0);                // CSN low, initialize SPI communication...
  SPI_RW(reg);            // Select register to read from..
  reg_val = SPI_RW(0);    // ..then read registervalue
  CSN_Pin(1);                // CSN high, terminate SPI communication
  return(reg_val);        // return register value
Function: SPI_Read_Buf();
Description:
  Reads 'bytes' #of bytes from register 'reg'
  Typically used to read RX payload, Rx/Tx address
uchar status,byte_ctr;
  CSN_Pin(0);                     // Set CSN low, init SPI tranaction
  status = SPI_RW(reg);       // Select register to write to and read status byte
  for(byte_ctr=0;byte_ctr    pBuf[byte_ctr] = SPI_RW(0);    // Perform SPI_RW to read byte from nRF24L01
  CSN_Pin(1);                           // Set CSN high again
Function: SPI_Write_Buf();
Description:
  Writes contents of buffer '*pBuf' to nRF24L01
  Typically used to write TX payload, Rx/Tx address
  for(byte_ctr=0; byte_ctr    SPI_RW(*pBuf++);
Function: RX_Mode();
Description:
  This function initializes one nRF24L01 device to
  RX Mode, set RX address, writes RX payload width,
  select RF channel, datarate & LNA HCURR.
  After init, CE is toggled high, which means that
  this device is now ready to receive a datapacket.
void RX_Mode(void)
        CE_Pin(0);
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // D′±?μ?μ??·
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, RX_ADR_WIDTH); // D′?óê???μ??·
SPI_RW_Reg(WRITE_REG + EN_AA, ENAA_DisableALL);  //???1×??ˉó|′e
SPI_RW_Reg(WRITE_REG + SETUP_RETR,AutoReTx_Disable);//???1×??ˉ??·¢
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  ?êDí?óê?μ??·??óD?μμà0
SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //   éè??D?μà1¤×÷?a2.4GHZ£?ê?·¢±?D?ò???
SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //éè???óê?êy?Y3¤?è
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x27);   //éè??·¢é??ù?ê?a250kHZ£?·¢é?1|?ê?a×?′ó?μ0dB
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);   // IRQê?·¢íê3é?D???ìó|£?16??CRC £?·¢?í
        CE_Pin(1);
Function: TX_Mode();
Description:
  TX mode, set TX address, set RX address for auto.ack,
  fill TX payload, select RF channel, datarate & TX pwr.
  PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX.
  ToDo: One high pulse(>10us) on CE will now send this
  packet and expext an acknowledgment from the RX device.
void TX_Mode(void)
CE_Pin(0);
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);   // IRQê?·¢íê3é?D???ìó|£?16??CRC £?·¢?í
CE_Pin(1);
TestBuf = SPI_Read(RX_ADDR_P4);//return is 0xC5,if connection is ok
if(Mode == nRF_TX_Mode)
TX_Mode();
else RX_Mode();
delay_1ms(2);//24L01 掉电模式到待机模式需要1.5ms
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload
TestBuf = SPI_Read(STATUS);
SPI_RW_Reg(WRITE_REG+STATUS,TestBuf);
if(TestBuf&RX_OK)
SPI_Read_Buf(RD_RX_PLOAD, rx_buf, RX_PLOAD_WIDTH);
SPI_RW_Reg(FLUSH_RX, 0xff);
//Cycle_Cnt = (rx_buf[4]<<8)|rx_buf[5];
 * 函数名:NRF_Check
 * 描述  :主要用于NRF与MCU是否正常连接
 * 输入  :无
 * 输出  :SUCCESS/ERROR 连接正常/连接失败
 * 调用  :外部调用
uchar buf[5]={0xC2,0xC2,0xC2,0xC2,0xC2};
uchar buf1[5];
uchar i;
/*写入5个字节的地址.  */
SPI_Write_Buf(WRITE_REG+TX_ADDR,buf,5);
/*读出写入的地址 */
SPI_Read_Buf(TX_ADDR,buf1,5);
/*比较*/
for(i=0;i<5;i++)
if(buf1[i]!=0xC2)
break;
if(i==5)
return 1 ;        //MCU与NRF成功连接
else
return 0 ;        //MCU与NRF不正常连接
      P4DIR |= BIT4;         //ce
      //P4OUT = BIT4;         //ce
      P4DIR |= BIT5;         //csn
      P5DIR |= BIT3;         //sck
      P5DIR |= BIT2;         //mosi out
      P5DIR &=~BIT1;         //MISO IN
      P1DIR &=~BIT4;         //IRQ
      SCK_Pin(0);
      CE_Pin(0);
main.c
[1] [2]
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news071140253.html
上一篇:MSP430单片机USART串口发送字符和字符串
下一篇:LCD1602动态显示--基于MSP430F149单片机
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
stm32之nRF24L01无线模块(1):SPI2到SPI1的移植
(GPIOG,GPIO_Pin_6)#define NRF24L01_CE_CLR GPIO_ResetBits(GPIOG,GPIO_Pin_6)    在移植的时候,这种预定义很容易忽略,忘了的话根本就不会开始SPI通信,自然也就没有现象了。4.库函数的改变    在SPI2的函数中,只要是涉及写寄存器的部分,就要看下到底写的是SPI2还是SPI1的寄存器,当然,这里有一个很明显的特点,就是stm32官方的库函数一般是通用的,像下面这个SPI命令函数SPI_Cmd(SPI_TypeDef* SPIx, FunctionalState NewS
发表于 2018-10-16
stm32之nRF24L01无线模块(2):无线模块的地址
    可能刚开始接触nRF24L01的童鞋都会注意到例程函数中有两个定义的地址const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};     这个非常让人疑惑,为什么地址还是数组,而且网上一搜,几乎所有的例程地址都是这一个,为什么呢,换一个不行吗?下面我们从数据手册和实验两个方面来分析,这里注意下,由于Enhanced ShockBurst
发表于 2018-10-16
发表于 2018-10-10
nRF24L01单片机通信的总结
1周时间,我从一个没用过STC单片机,不知道什么叫SPI接口的“文盲”,把nRF24L01的整个通信过程弄到完全没有bug.。兴奋之余来小屁一下。给那些正在奋斗着这个牛逼的芯片的小牛们小炫一下。希望有所帮助。屁话少说。正题:基本的东西我理解了,那就是:1.用5根线的SPI接口向2401发送数据或指令。2.芯片在每次上电的时候都需要进行一番配置。这些配置数据,就是所谓的指令了。3.配置完成后知道芯片处在哪个模式。并且知道它将要转向哪个模式。4.通讯协议。5.观察现象。好了,小牛们一定急切想知道自己的程序问题出在哪里了,再小白一点的一定想急切的知道如何配置才能让它工作。更小白一点的一定想知道这个芯片的各个模式之间是怎么联系的。又是
发表于 2018-07-14
基于ATmega16单片机 NRF24L01无线收发驱动程序源代码
//NRF2401发送驱动程序#include <avr/io.h>#define  uint unsigned  int#define  uchar unsigned  char//------------------------------------------------------------------------------//--------------------------------NRF24L01接口定义
发表于 2018-06-21
MSP430单片机低功耗结构原理
当系统时钟发生器基本功能建立之后,CPU内状态寄存器SR的SCG1,SCG0,CPUOFF,OSCOFF位是重要的低功耗控制位。只要任意中断被响应,上述控制位就被压入堆栈保存,中断处理之后,又可恢复先前的工作方式。在中断处理子程序执行期间,通过间接访问堆栈数据,可以操作这些控制位;这样允许程序在中断返回(RETI) 后,以另一种功耗方式继续运行。各控制位的作用如下:SCG1: 复位,使能SMCLK;置位,禁止SMCLK。SCG0: 复位,激活直流发生器,只有SCG0置位,并且DCOCLK没有被用作MCLK或SMCLK时,直流发生器才能被禁止。OSCOFF:复位,激活LFXT1,只有当OSCOFF被置位并且LFXT1CLK不用于MCL
发表于 2018-11-21
小广播
何立民专栏
单片机及嵌入式宝典
pt type="text/javascript" src="//v3.jiathis.com/code/jia.js?uid=2113614" charset="utf-8">
