datasheet
STM32定时器----主从模式触发PWM移相
2018-06-28来源: eefocus关键字:STM32  定时器  主从模式  触发PWM移相
本文中使用的是:触发模式,而非:门模式
代码如下:
void TIM3_PWMShiftInit(void)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseInitStruct;
    GPIO_InitTypeDef  GPIO_InitStruct;
    TIM_OCInitTypeDef TIM_OCInitStruct;
    /**********************TIM3 GPIO配置*****************************/
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_13;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB,&GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8;
    GPIO_Init(GPIOA,&GPIO_InitStruct);
    /**********************初始化TimBase结构体*************************/
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); //开启TIM时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
    TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;   //定时器不分频
    TIM_TimeBaseInitStruct.TIM_CounterMode   = TIM_CounterMode_Up;
    TIM_TimeBaseInitStruct.TIM_Period    = 1799;       //频率 = 72000000/PSC/(ARR+1) = 40KHz
    TIM_TimeBaseInitStruct.TIM_Prescaler = 0;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct);
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseInitStruct);
    /**********************初始化TIM3 OC结构体*************************/
    TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
    TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStruct.TIM_Pulse = 600;                 //TIM3 CH3占空比:600/(ARR+1)=33.3%
    TIM_OC3Init(TIM3,&TIM_OCInitStruct);
    //TIM1 CH1pwm输出配置
    TIM_OCInitStruct.TIM_Pulse=600;                   //TIM1 CH1占空比:600/(ARR+1)=33.3%
    TIM_OCInitStruct.TIM_OCPolarity=TIM_OCPolarity_Low;        //设置输出极性
    TIM_OCInitStruct.TIM_OutputNState=TIM_OutputNState_Disable;//禁止互补端输出,缺失此语句无法调节输出极性
    TIM_OC1Init(TIM1,&TIM_OCInitStruct);
    /**************************配置移相触发**************************/
    TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM2;  //PWM2与Toggle模式可触发移相,其他模式不可
    TIM_OCInitStruct.TIM_Pulse = 600-2;             //约需2个定时器周期触发,移相:360*600/(ARR+2)= 120度
    TIM_OC2Init(TIM1,&TIM_OCInitStruct);            //需要CH2上升沿触发如果无法触发移相请更改CH2输出极性
    /**************************配置主从模式*************************/
    TIM_SelectOutputTrigger(TIM1, TIM_TRGOSource_OC2Ref);  //TIM1 OC2触发从定时器
    TIM_SelectMasterSlaveMode(TIM1, TIM_MasterSlaveMode_Enable);
    TIM_SelectInputTrigger(TIM3, TIM_TS_ITR0);      //ITRO触发
    TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Trigger);
    TIM_Cmd(TIM1, ENABLE);
    TIM_CtrlPWMOutputs(TIM1, ENABLE);               //高级定时器pwm输出使能,一定要记得打开
示波器显示波形如下:
CH1: TIM1 CH1
CH2: TIM3 CH3
图一可以频率以及占空比正确,结合图二可知移相度数正确。
经过观察两定时器在不同频率、占空比下的输出,发现移相有25ns左右误差,故初始化时进行2个定时器周期修正
示波器放大到25ns,可以看到,经过600-2,2个定时器周期(定时器不分频)修正后,移相基本没有偏移。
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news062840091.html
上一篇:STM32高级定时器从模式 四种
下一篇:STM32定时器产生PWM--呼吸灯
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32堆栈设置
1.堆和栈大小 定义大小在startup_stm32f2xx.sStack_Size      EQU     0x00000400                AREA    STACK, NOINIT, READWRITE, ALIGN=3Stack_Mem
发表于 2019-04-16
STM32堆栈设置
STM32堆和栈(Heap & Stack)的资料理解
源起:在移植cjson的过程中,解析json包的时候发现动态内存分配不足而导致解析失败,为解决这一问题,而深入了解stm32的堆和栈。stm32的存储器结构。Flash,SRAM寄存器和输入输出端口被组织在同一个4GB的线性地址空间内。可访问的存储器空间被分成8个主要块,每个块为512MB。FLASH存储下载的程序。SRAM是存储运行程序中的数据。而SRAM一般分这几个部分:静态存储区:内存在程序编译的时候就已经分配好,这块内存在程序的整个运行期间都存在。它主要存放静态数据、全局数据和常量。栈区:在执行函数时,函数内局部变量的存储单元都可以在栈上创建,函数执行结束时这些存储单元自动被释放。栈内存分配运算内置于处理器的指令集中,效率
发表于 2019-04-16
STM32定义堆栈地址到ram区顶部
本设置针对stm32f103rbt6的设置,该芯片RAM大小为20kB,故RAM区地址范围为0x20000000—0x20005000,芯片信息如下图所示;第一步:设置.sct文件;;*************************************************************; *** Scatter-Loading Description Filegenerated by uVision ***; *************************************************************LR_IROM1 0x08000000 0x00020000
发表于 2019-04-16
STM32定义堆栈地址到ram区顶部
STM32之程序如何防止堆栈溢出
近日为某个项目写了个草稿程序,即非正式程序,后来发现老是进入hardfaulthandler,原来是堆栈溢出,后仔细查看发现函数调用纵深太深,最多的时候可保持7个函数在堆栈中调用。因此有心得如下:一、函数调用不要纵深太深,即以下模式:main(){   fun1();}fun1(){  fun2();}fun2(){   fun3();}fun3(){  fun4();}fun4(){  fun5();}fun5(){  fun6();}fun6(){   fun7();}这样子main函数要调用fun1函数完成某个功能,则要一直调到
发表于 2019-04-16
stm32之堆栈
stm32中的堆栈设置keil编译完成时存储情况当编译成功时,会出现: BUILD://Program Size: Code=340 RO-data=252 RW-data=0 ZI-data=1632Code:程序代码部分RO-data: 程序定义的常量const tempRW-data:已初始化的全局变量ZI-data:未初始化的全局变量片中的:flash=Code+RO-data+RW-dataRAM=RW-data+ZI-data通过上面的BUILD可以看出,这个程序已经用了1600多的RAM,为什么会出用到这么多的RAM呢?在startup_stm32f10x_md.s文件中存在:St
发表于 2019-04-16
说说STM32的堆栈与内存
1.概念这里所说的堆栈,是针对单片机所说的“堆”与“栈”,指的是内存中一片特殊用途的区域。而不是数据结构中的堆栈(虽然其实规则一样)。这里所说的内存,是指RAM,RAM包括SRAM,DRAM等。而不是什么手机内存卡之类。这里所说的flash,指的是用作为ROM的存储器,保存代码与常量数据。而不是动画制作。。。栈的生长方向:指的是入栈方向,从高地址向低地址生长叫做向下生长,或逆向生长;反过来就叫向上生长,或正向生长。STM32的栈是向下生长。2.内存中的堆栈安排确切地说,是keil mdk根据STM32的特性,对stm32的RAM甚至flash进行部署。编译工程后,在生成的.map文件里可以看到具体的安排。双击工程界面的工程根目录
发表于 2019-04-16
说说STM32的堆栈与内存
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
