datasheet
CAN总线控制器IP核代码分析
2011-08-25 22:42:55来源: 互联网 关键字:总线控制器  控制器  代码  分析
include "timescale.v"
// synopsys translate_on
`include "can_defines.v"
module can_top
  `ifdef CAN_WISHBONE_IF
    wb_clk_i,
    wb_rst_i,
    wb_dat_i,
    wb_dat_o,
    wb_cyc_i,
    wb_stb_i,
    wb_we_i,
    wb_adr_i,
    wb_ack_o,
  `else
    rst_i,
    ale_i,
    rd_i,
    wr_i,
    port_0_io,
  `endif
  cs_can_i,
  clk_i,
  rx_i,
  tx_o,
  irq_on,
  clkout_o
parameter Tp = 1;
  input        wb_clk_i;
  input        wb_rst_i;
  input  [7:0] wb_dat_i;
  output [7:0] wb_dat_o;
  input        wb_cyc_i;
  input        wb_stb_i;
  input        wb_we_i;
  input  [7:0] wb_adr_i;
  output       wb_ack_o;
  reg          wb_ack_o;
  reg          cs_sync1;
  reg          cs_sync2;
  reg          cs_sync3;
  reg          cs_ack1;
  reg          cs_ack2;
  reg          cs_ack3;
  reg          cs_sync_rst1;
  reg          cs_sync_rst2;
`else
  input        rst_i;
  input        ale_i;
  input        rd_i;
  input        wr_i;
  inout  [7:0] port_0_io;
  reg    [7:0] addr_latched;
  reg          wr_i_q;
  reg          rd_i_q;
`endif
input        cs_can_i;
input        clk_i;
input        rx_i;
output       tx_o;
output       irq_on;
output       clkout_o;
reg          data_out_fifo_selected;
wire         irq_o;
wire   [7:0] data_out_fifo;
wire   [7:0] data_out_regs;
/* Mode register */
wire         reset_mode;
wire         listen_only_mode;
wire         acceptance_filter_mode;
wire         self_test_mode;
/* Command register */
wire         release_buffer;
wire         tx_request;
wire         abort_tx;
wire         self_rx_request;
wire         single_shot_transmission;
/* Arbitration Lost Capture Register */
wire         read_arbitration_lost_capture_reg;
/* Error Code Capture Register */
wire         read_error_code_capture_reg;
wire   [7:0] error_capture_code;
/* Bus Timing 0 register */
wire   [5:0] baud_r_presc;
wire   [1:0] sync_jump_width;
/* Bus Timing 1 register */
wire   [3:0] time_segment1;
wire   [2:0] time_segment2;
wire         triple_sampling;
/* Error Warning Limit register */
wire   [7:0] error_warning_limit;
/* Rx Error Counter register */
wire         we_rx_err_cnt;
/* Tx Error Counter register */
wire         we_tx_err_cnt;
/* Clock Divider register */
wire         extended_mode;
/* This section is for BASIC and EXTENDED mode */
/* Acceptance code register */
wire   [7:0] acceptance_code_0;
/* Acceptance mask register */
wire   [7:0] acceptance_mask_0;
/* End: This section is for BASIC and EXTENDED mode */
/* This section is for EXTENDED mode */
wire   [7:0] acceptance_code_1;
wire   [7:0] acceptance_code_2;
wire   [7:0] acceptance_code_3;
wire   [7:0] acceptance_mask_1;
wire   [7:0] acceptance_mask_2;
wire   [7:0] acceptance_mask_3;
/* End: This section is for EXTENDED mode */
/* Tx data registers. Holding identifier (basic mode), tx frame information (extended mode) and data */
wire   [7:0] tx_data_0;
wire   [7:0] tx_data_1;
wire   [7:0] tx_data_2;
wire   [7:0] tx_data_3;
wire   [7:0] tx_data_4;
wire   [7:0] tx_data_5;
wire   [7:0] tx_data_6;
wire   [7:0] tx_data_7;
wire   [7:0] tx_data_8;
wire   [7:0] tx_data_9;
wire   [7:0] tx_data_10;
wire   [7:0] tx_data_11;
wire   [7:0] tx_data_12;
/* End: Tx data registers */
wire         cs;
/* Output signals from can_btl module */
wire         clk_en;
wire         sample_point;
wire         sampled_bit;
wire         sampled_bit_q;
wire         tx_point;
wire         hard_sync;
wire         resync;
/* output from can_bsp module */
wire         rx_idle;
wire         transmitting;
wire         last_bit_of_inter;
wire         set_reset_mode;
wire         node_bus_off;
wire         error_status;
wire   [7:0] rx_err_cnt;
wire   [7:0] tx_err_cnt;
wire         rx_err_cnt_dummy;  // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
wire         tx_err_cnt_dummy;  // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
wire         transmit_status;
wire         receive_status;
wire         tx_successful;
wire         need_to_tx;
wire         overrun;
wire         info_empty;
wire         set_bus_error_irq;
wire         set_arbitration_lost_irq;
wire   [4:0] arbitration_lost_capture;
wire         node_error_passive;
wire         node_error_active;
wire   [6:0] rx_message_counter;
wire         tx_out;
wire         tx_oen;
wire         rst;
wire         we;
wire   [7:0] addr;
wire   [7:0] data_in;
reg    [7:0] data_out;
/* Connecting can_registers module */
can_registers i_can_registers
  .clk(clk_i),
  .rst(rst),
  .cs(cs),
  .we(we),
  .addr(addr),
  .data_in(data_in),
  .data_out(data_out_regs),
  .irq(irq_o),
  .sample_point(sample_point),
  .transmitting(transmitting),
  .set_reset_mode(set_reset_mode),
  .node_bus_off(node_bus_off),
  .error_status(error_status),
  .rx_err_cnt(rx_err_cnt),
  .tx_err_cnt(tx_err_cnt),
  .transmit_status(transmit_status),
  .receive_status(receive_status),
  .tx_successful(tx_successful),
  .need_to_tx(need_to_tx),
  .overrun(overrun),
  .info_empty(info_empty),
  .set_bus_error_irq(set_bus_error_irq),
  .set_arbitration_lost_irq(set_arbitration_lost_irq),
  .arbitration_lost_capture(arbitration_lost_capture),
  .node_error_passive(node_error_passive),
  .node_error_active(node_error_active),
  .rx_message_counter(rx_message_counter),
  /* Mode register */
  .reset_mode(reset_mode),
  .listen_only_mode(listen_only_mode),
  .acceptance_filter_mode(acceptance_filter_mode),
  .self_test_mode(self_test_mode),
  .clear_data_overrun(),
  .release_buffer(release_buffer),
  .abort_tx(abort_tx),
  .tx_request(tx_request),
  .self_rx_request(self_rx_request),
  .single_shot_transmission(single_shot_transmission),
  .read_arbitration_lost_capture_reg(read_arbitration_lost_capture_reg),
  .read_error_code_capture_reg(read_error_code_capture_reg),
  .error_capture_code(error_capture_code),
  .baud_r_presc(baud_r_presc),
  .sync_jump_width(sync_jump_width),
  .time_segment1(time_segment1),
  .time_segment2(time_segment2),
  .triple_sampling(triple_sampling),
  .error_warning_limit(error_warning_limit),
  .we_rx_err_cnt(we_rx_err_cnt),
  .we_tx_err_cnt(we_tx_err_cnt),
  .extended_mode(extended_mode),
  .clkout(clkout_o),
  .acceptance_code_0(acceptance_code_0),
  .acceptance_mask_0(acceptance_mask_0),
  .acceptance_code_1(acceptance_code_1),
  .acceptance_code_2(acceptance_code_2),
  .acceptance_code_3(acceptance_code_3),
  .acceptance_mask_1(acceptance_mask_1),
  .acceptance_mask_2(acceptance_mask_2),
  .acceptance_mask_3(acceptance_mask_3),
  .tx_data_0(tx_data_0),
  .tx_data_1(tx_data_1),
  .tx_data_2(tx_data_2),
  .tx_data_3(tx_data_3),
  .tx_data_4(tx_data_4),
  .tx_data_5(tx_data_5),
  .tx_data_6(tx_data_6),
  .tx_data_7(tx_data_7),
  .tx_data_8(tx_data_8),
  .tx_data_9(tx_data_9),
  .tx_data_10(tx_data_10),
  .tx_data_11(tx_data_11),
  .tx_data_12(tx_data_12)
assign irq_on = ~irq_o;
/* Connecting can_btl module */
can_btl i_can_btl
  .clk(clk_i),
  .rst(rst),
  .rx(rx_i),
  /* Mode register */
  /* Output signals from this module */
  .clk_en(clk_en),
  .sampled_bit(sampled_bit),
  .sampled_bit_q(sampled_bit_q),
  .tx_point(tx_point),
  .hard_sync(hard_sync),
  .resync(resync),
  .rx_idle(rx_idle),
  .last_bit_of_inter(last_bit_of_inter)
can_bsp i_can_bsp
  .clk(clk_i),
  .rst(rst),
  /* From btl module */
  .addr(addr),
  .data_in(data_in),
  .data_out(data_out_fifo),
  .fifo_selected(data_out_fifo_selected),
/* Mode register */
  .rx_idle(rx_idle),
  .last_bit_of_inter(last_bit_of_inter),
  .rx_err_cnt({rx_err_cnt_dummy, rx_err_cnt[7:0]}),   // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
  .tx_err_cnt({tx_err_cnt_dummy, tx_err_cnt[7:0]}),   // The MSB is not displayed. It is just used for easier calculation (no counter overflow).
  .overrun(overrun),
  .tx_data_12(tx_data_12),
  /* Tx signal */
  .tx(tx_out),
  .tx_oen(tx_oen)
assign tx_o = tx_oen? 1'bz : tx_out;
// Multiplexing wb_dat_o from registers and rx fifo
always @ (extended_mode or addr or reset_mode)
begin
  if (extended_mode & (~reset_mode) & ((addr >= 8'd16) && (addr <= 8'd28)) | (~extended_mode) & ((addr >= 8'd20) && (addr <= 8'd29)))
    data_out_fifo_selected <= 1'b1;
  else
    data_out_fifo_selected <= 1'b0;
end
always @ (posedge clk_i)
begin
//  if (wb_cyc_i & (~wb_we_i))
  if (cs & (~we))
    begin
      if (data_out_fifo_selected)
        data_out <=#Tp data_out_fifo;
      else
        data_out <=#Tp data_out_regs;
    end
end
  // Combining wb_cyc_i and wb_stb_i signals to cs signal. Than synchronizing to clk_i clock domain.
  always @ (posedge clk_i or posedge rst)
  begin
    if (rst)
      begin
        cs_sync1     <= 1'b0;
        cs_sync2     <= 1'b0;
        cs_sync3     <= 1'b0;
        cs_sync_rst1 <= 1'b0;
        cs_sync_rst2 <= 1'b0;
      end
    else
      begin
        cs_sync1     <=#Tp wb_cyc_i & wb_stb_i & (~cs_sync_rst2) & cs_can_i;
        cs_sync2     <=#Tp cs_sync1            & (~cs_sync_rst2);
        cs_sync3     <=#Tp cs_sync2            & (~cs_sync_rst2);
        cs_sync_rst1 <=#Tp cs_ack3;
        cs_sync_rst2 <=#Tp cs_sync_rst1;
      end
  end
  assign cs = cs_sync2 & (~cs_sync3);
  always @ (posedge wb_clk_i)
  begin
    cs_ack1 <=#Tp cs_sync3;
    cs_ack2 <=#Tp cs_ack1;
    cs_ack3 <=#Tp cs_ack2;
  end
  // Generating acknowledge signal
  begin
    wb_ack_o <=#Tp (cs_ack2 & (~cs_ack3));
  end
  assign rst      = wb_rst_i;
  assign we       = wb_we_i;
  assign addr     = wb_adr_i;
  assign data_in  = wb_dat_i;
  assign wb_dat_o = data_out;
`else
  // Latching address
  always @ (negedge clk_i or posedge rst)
  begin
    if (rst)
      addr_latched <= 8'h0;
    else if (ale_i)
      addr_latched <=#Tp port_0_io;
  end
  // Generating delayed wr_i and rd_i signals
  begin
    if (rst)
      begin
        wr_i_q <= 1'b0;
        rd_i_q <= 1'b0;
      end
    else
      begin
        wr_i_q <=#Tp wr_i;
        rd_i_q <=#Tp rd_i;
      end
  end
  assign cs = ((wr_i & (~wr_i_q)) | (rd_i & (~rd_i_q))) & cs_can_i;
  assign rst       = rst_i;
  assign we        = wr_i;
  assign addr      = addr_latched;
  assign data_in   = port_0_io;
  assign port_0_io = (cs_can_i & rd_i)? data_out : 8'hz;
`endif
endmodule
关键字:总线控制器  控制器  代码  分析
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0825/article_8255.html
上一篇:闭路电视监控系统在轨道交通中的应用
下一篇:超声波测距系统中单片机的应用
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
总线控制器
控制器
代码
分析
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
