datasheet
红外线远程控制电路
2011-05-24 15:46:41来源: 互联网 关键字:远程控制
      红外线远程控制电路 Infa-Red Remote Control
I have received a number of emails requesting schematics for infa-red remotes. So here is one. This remote transmits a tone using an infa-red LED. This tone is decoded by the receiver. Since the receiver only switches when it "hears" the tone, there are no accidental activations.
Schematic For Transmitter
Parts:
Part
 Total Qty.
 Substitutions
R1
 22K 1/4W Resistor
R2
 1 Meg 1/4W Resistor
R3
 1K 1/4W Resistor
R4, R5
 100K 1/4W Resistor
R6
 50K Pot
C1, C2
 0.01uF 16V Ceramic Disk Capacitor
C3
 100pF 16V Ceramic Disk Capacitor
C4
 0.047uF 16V Ceramic Disk Capacitor
C5
 0.1uF 16V Ceramic Disk Capacitor
C6
 3.3uF 16V Electrolytic Capacitor
C7
 1.5uF 16V Electrolytic Capacitor
Q1
 2N2222 NPN Silicon Transistor
 2N3904
Q2
 2N2907 PNP Silicon Transistor
Q3
 NPN Phototransistor
D1
 1N914 Silicon Diode
IC1
 LM308 Op Amp IC
IC2
 LM567 Tone Decoder
LED1
 Infa-Red LED
RELAY
 6 Volt Relay
S1
 SPST Push Button Switch
B1
 3 Volt Battery
 Two 1.5V batteries in series
MISC
 Board, Sockets For ICs, Knob For R6, Battery Holder
RELAY
 6 Volt Relay
Notes:
1. To adjust the circuit, hold down S1 while pointing LED1 at the receiver. Adjust R6 until you hear the relay click.
2. You can increase range by using a high output LED for LED1.
3. Bright light will stop the receiver from responding to the transmitter.
关键字:远程控制
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0524/article_6078.html
上一篇:红外遥控器干扰电路
下一篇:可控硅调光灯电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
远程控制
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
