datasheet
红外遥控器干扰电路
2011-05-24 15:45:50来源: 互联网 关键字:遥控器  干扰  电路
     红外遥控器干扰电路 IR Remote Control Jammer
By Carl
Don't like your little brother's TV channel selection? Hate the volume your wife sets the stereo at? Want to just annoy someone? This circuit does all that and more by jamming most IR remote signals. The circuit releases a flood of pulsing IR light that confuses the reciever by corrupting the data stream.
Schematic
Part
 Total Qty.
 Substitutions
R1
 100K 1/4W Resistor
R2
 150K 1/4W Resistor
R3
 10K 1/4W Resistor
R4
 1K 1/4W Resistor
R5
 See "Notes"
C1
 10nF Ceramic Disc Capacitor
C2
 1uF Electrolytic Capacitor
D1, D2, D3
 High Output IR LED
Q1
 2N4403 PNP Transistor
Q2
 2N4401 NPN Transistor
S1
 Normally Open Momentary Push Botton
B1
 4.5V Battery (Three "AA"'s In Series)
MISC
 Wire, Case, Board
Notes:
1. Email Carl with questions, comments, etc.
2. You may need to adjust the value of R3 for the right frequency. A pot can be used.
3. You may only need one IR LED.
4. It goes without saying that this circuit should be used with descretion.
关键字:遥控器  干扰  电路
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0524/article_6077.html
上一篇:激光发射器/接收器电路
下一篇:红外线远程控制电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
遥控器
干扰
电路
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
