datasheet
激光发射器/接收器电路
2011-05-24 15:44:47来源: 互联网 关键字:接收器  电路
      This set of two circuits from the basis for a very simple light wave transmitter. A LASER beam is modulated and then aimed at a receiver that demodulates the signal and then presents the information (voice, data, etc..). The whole thing is very easy to build and requires no specialized parts execpt for the LASER itself. LASERs are available from MWK Industries.
Schematic Of Receiver
Parts:
Part
 Total Qty.
 Substitutions
C1, C2
 0.1uf Ceramic Disc Capacitor
C3
 100uf 25V Electrolytic Capacitor
R1
 100K Ohm 1/4W Resistor
R2
 1M Ohm 1/4W Resistor
R3
 10K Pot
Q1
 NPN Phototransistor
U1
 741 Op Amp
U2
 LM386 Audio Amp
SPKR1
 8 Ohm Speaker
T1
 8 Ohm:2K Audio Transformer
MISC
 Wire, Board, Knob For R3, LASER Tube and Power Supply
Notes:
1. In the transmitter schematic, no ballast resistor is shown because most small LASER power supplies already have one built in. Yours may differ, and a resistor may be needed.
2. The receiver should be kept away from bright lights. You may want to put a piece of wax paper in front of Q1 to keep the LASER from swamping it.
3. In order to get any decent amount of modulation, you may need to drive T1 with more then a watt.
4. The circuit can be made to transmit computer data with the use of two modem chips.
关键字:接收器  电路
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0524/article_6076.html
上一篇:维萨拉在线监测六氟化硫绝缘性能的全新独特方案
下一篇:红外遥控器干扰电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
接收器
电路
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
