datasheet
脉宽调制直流电动机控制电路
2011-05-24 15:44:01来源: 互联网 关键字:脉宽调制  直流电动机  电动  控制
    脉宽调制直流电动机控制电路 Pulse Width Modulation DC Motor Control
Often, people attempt to control DC motors with a variable resistor or variable resistor connected to a transistor. While the latter approach works well, it generates heat and hence wastes power. This simple pulse width modulation DC motor control eliminates these problems. It controls the motor speed by driving the motor with short pulses. These pulses vary in duration to change the speed of the motor. The longer the pulses, the faster the motor turns, and vice versa.
Schematic
Parts
Part
 Total Qty.
 Substitutions
R1
 1 Meg 1/4W Resistor
R2
 100K Pot
C1
 0.1uF 25V Ceramic Disc Capacitor
C2
 0.01uF 25V Ceramic Disc Capacitor
Q1
 IRF511 MOSFET
 IRF620
U1
 4011 CMOS NAND Gate
S1
 DPDT Switch
M1
 Motor (See Notes)
MISC
 Case, Board, Heatsink, Knob For R2, Socket For U1
1. R2 adjusts the speed of the oscillator and therefore the speed of M1.
2. M1 can be any DC motor that operates from 6V and does not draw more than the maximum current of Q1. The voltage can be increased by connecting the higher voltage to the switch instead of the 6V that powers the oscillator. Be sure not to exceed the power rating of Q1 if you do this.
3. Q1 will need a heatsink.
4. Q1 in the parts list can handle a maximum of 5A. Use the IRF620 for 6A, if you need any higher.
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0524/article_6075.html
上一篇:简单的直流电机PWM调速电路
下一篇:步进电机控制器电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
脉宽调制
直流电动机
电动
控制
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
