datasheet
ST LSM320HAY30 3D数字线性加速度传感方案
2011-05-20 09:14:51来源: 互联网 关键字:传感  方案
The LSM320HAY30 is a low-power system-in-package featuring a 3D digital linear acceleration sensor and a 2D analog angular rate pitch and yaw sensor. It provides excellent temperature stability and high resolution over an extended operating temperature range (-40℃to +85℃).
ST’s family of sensor modules leverages the robust and mature manufacturing process already used for the production of micromachined accelerometers. The LSM320HAY30 has a dynamically user-selectable full-scale acceleration range of ±2 g/±4 g/±8 g, and an angular rate of ±300 dps capable of detecting rates with a -3 dB bandwidth up to 140 Hz along pitch and yaw axes. The LSM320HAY30 is capable of measuring linear accelerations with output data rates from 0.5 Hz up to 1 kHz. The embedded self-test capability allows the user to check the functioning of each sensor in the final application. The device can be configured to generate an interrupt signal by inertial wakeup/free-fall events as well as by the position of the device itself. Several years ago ST successfully pioneered the use of this package for accelerometers. Today, ST has the widest manufacturing capability and strongest expertise in the world for production of sensors in plastic LGA packages.
LSM320HAY30主要特性:
■ 2.7 V to 3.6 V power supply operation
■ Low voltage compatible digital IOs, 1.8 V
■ ±2 g/±4 g/±8 g dynamically selectable full-scale
■ ±300 dps absolute analog angular rate output
■ I2C/SPI digital linear acceleration interface (16 bit data output)
■ Two separated outputs for pitch and yaw axis (1x and 4x amplified)
■ Integrated low-pass filters for angular rate
■ 2 independent programmable interrupt generators for free-fall and motion detection
■ Sleep-to-wakeup function
■ 6D orientation detection
■ Extended operating temperature range (40℃ to +85℃)
■ High stability over temperature
■ High shock survivability
■ Embedded self-test
■ Embedded power-down
■ Embedded low-power mode
■ ECOPACK® RoHS and “Green” compliant
LSM320HAY30应用:
■ Motion control for smart user interface
■ Display orientation
■ Gaming and virtual reality input devices
■ Industrial and robotics
■ Vibration monitoring and compensation
■ Impact recognition and logging
■ Motion-activated functions
■ Intelligent power-saving for handheld devices
■ Free-fall detection
图1.LSM320HAY30方框图
图2.LSM320HAY30电连接框图
LSM320HAY30外接元件数值表:
The device core is supplied through the Vdd line. Power supply decoupling capacitors
(C1=100 nF ceramic, C2=10 μF aluminum) should be placed as near as possible to the
supply pin of the device (common design practice).
关键字:传感  方案
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0520/article_6059.html
上一篇:热电偶应用中冷结点补偿的实现
下一篇:电涡流式传感器的结构和工作原理
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
传感
方案
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
