datasheet
红外灯调光器电路
2011-05-19 18:37:30来源: 互联网 关键字:电路
红外灯调光器电路,IR Light Dimmer
This is a device for adjusting lights in your home with any type of remote controller (tv, dvd, video,). Today we are using many devices in our homes to improve quality of our life and this is another example on how you can enhance a simple procedure like switching the lights ON/OFF. It may be difficult to many of us to stand up from our chair only to switch lights, so try imagining yourself doing this with your remote controller.
Here is a solution for you
The Ir LightDimmer is simple to use, you only need two keys of your remote controller, which are not often used (like teletext keys or similar) or which are not used at all and one push-button that you will put in place of  the existing light switch. Ir LightDimmer can memorize two remote controller keys (see “memorizing the remote controller keys section), so that the first one will be used to turn on lights or increase light intensity, and the other will be used to turn off lights or decrease light intensity.
Schematic
IR detectors
TSOP1738 - 38Khz
TSOP1138 - 38Khz
TSOP1736 - 36Khz
SFH5110 - 38 ( 38Khz)
How it works
We have two ways to control light: either with push-button or with remote controller. Using the push-button, when we apply a short press we can turn ON or OFF lights, but if we press and hold the button more than 300ms the light intensity is increasing to maximum or decreasing to minimum continuously until you press the button. If we press and hold the button so that lights go to maximum 3 times, then device enters “memorizing the remote controller keys” mode.
In a new software version, I will add a “double click” mode (like PC mousses), so when you double click the push-button, the lights go ON to 70%, and slowly decreasing light intensity to minimum in a period of 1 minute. This mode is good for your bedroom, so when you go to sleep just double click the button and go to bed. If you don’t like to wait lights to go OFF in 1 minute, you can break this mode by pressing button or by pressing remote controller keys.
Using remote controller key to control the dimmer you can turn on lights or increase light intensity. With a short press, lights turn ON to maximum and if you press and hold key then light intensity increases until you press that key.
The same thing happens with second remote controller key which is used to turn lights off or decrease light intensity. When you short press that key, the lights will turn OFF and if you press and hold key then light intensity decrease until you press that key.
When turning lights ON or OFF they are not reacting immediately but they change state slowly so your bulbs will have longer life duration. Also with adjusting light intensity you save on electrical energy.
Memorizing the remote controller keys
If you have chosen which remote controller keys will be used as controlling keys, we can start with memorizing process. Press and hold button until lights go 3 times to maximum. After that, light will turn OFF, and that is indication of successful entering “memorizing the remote controller keys” mode, then you can release button. In the next 5 seconds, you must press the first key on remote controller, if you do, lights will blink several times. After that, you must press the second remote controller key, if you do, lights will also blink several times. That’s all, memorizing process is finished.
You can change the assigned remote controller keys when you wish. After powering down the Ir LightDimmer, it will keep in memory these remote controller keys, so you don’t have to memorizing remote controller keys again when the device powers up.
Instructions
Ir LightDimmer is a small device (36*32mm) and can be easily mounted in electrical case where electrical wires terminate. Device works only with 220V/50Hz and only for resistive loads of 40W-400W.
With Ir LightDimmer you can’t use inductive or capacity loads (only bulbs). Device is based on PIC12F629 which is a small microchip microcontroller and therefore overall device is small and uses a few components.
On circuit board you can find the IR-receiver, which in our case is TSOP1738, but you can use any other type of IR-receiver which has frequency of 38KHz.
For output power stage you can use triac TIC206 or TIC216. For loads more than 150W you must add a heat sink on triac. The rest of parts are defined in schematic.
You must be careful when you connect IrLightDimmer to electrical wire, so you must break fuse switches of your lights. All connections must be like in my schematic, otherwise device will definitive burn out.
If you have IrLightDimmer mounted and connected and you want to change your lights, you must break fuse switches because there is risk of electric shock.
关键字:电路
编辑:eeleader 引用地址:http://www.eeworld.com.cn/gykz/2011/0519/article_6042.html
上一篇:灯光控制系统电路
下一篇:高电流双极步进电机控制器电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
电路
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
