Intersil Supported Functions
______________________________________________________________________
PWM
IS-1825ASRH-Single Event and Total Dose Hardened, High-Speed, Dual Output PWM
IS-1845ASRH-Single Event Rad-Hard High Speed, Current Mode PWM
HS-1825ARH-Rad-Hard High-Speed, Dual Output PWM
FET Driver
ISL74422BRH-Rad-Hard, 9A, Non-Inverting Power MOSFET Driver
ISL74422RH-Rad-Hard 9A, Non-Inverting Power MOSFET Drivers
IS-1715ARH-Rad-Hard Complementary Switch FET Driver
IS-2981RH-Rad-Hard 8-Channel Source Driver
IS-2100ARH-Rad-Hard High Frequency Half Bridge Driver
HS-4424BRH-Rad-Hard Dual, Non-Inverting Power MOSFET Drivers
HS-4424RH-Rad-Hard Dual, Non-Inverting Power MOSFET Drivers
HS-4080ARH-Rad-Hard Full Bridge N-Channel FET Driver
HS-4423RH-Rad-Hard Dual, Inverting Power MOSFET Drivers
HS-4423BRH-Radiation Hardened Dual, Inverting Power MOSFET Drivers
Regulator
ISL72991RH-Rad-Hard Negative Low Dropout Adjustable Voltage Regulator
HS-117RH-Rad-Hard Adjustable Positive Voltage Regulator
Power-on Reset
IS-705RH-Rad-Hard Power-Up/Down Microprocessor Reset Circuit
Signal Processing
ISL7124SRH-Single-Event Hardened, Single Supply, Quad Operational Amplifier
IS-139ASRH-Single Event Radiation Hardened Quad Voltage Comparator
IS-1009RH-Rad-Hard 2.5V Reference
HS-508BRH-Rad-Hard 8 Channel CMOS Analog Multiplexer with Overvoltage Protection
HS-201HSRH-Rad-Hard High Speed, Quad SPST, CMOS Analog Switch
HS-3530ARH-Rad-Hard Programmable Low Power Op Amp
HS-139RH-Rad-Hard Quad Voltage Comparator
HS-1840ARH-Rad-Hard 16 Channel CMOS Analog Multiplexer with High-Z Analog Input Protection
