最近在Kickstarter网站上,Valent F(x)团队正在为LOGi FPGA开发板的生产筹备资金。
LOGi 是fpga开发与arm平台的结合。Valent F(x)团队开发了可以支持树莓派和Beaglebone上开发的FPGA开发板,LOGi系列。它让FPGA开发与入门变得简单,同时趋于统一现存硬件接口和开源开发平台,如树莓派和Beaglebone Black这两个流行的开源开发平台。
Valent F(x)团队分别针对树莓派和Beaglebone Black开发了两个版本的LOGi板,如下图的LOGi-Pi和LOGi-Bone。LOGi-Pi的FPGA板的底部连接器可与树莓派的GPIO头连接,LOGi-Bone的FPGA板有两行的连接器可与Beaglebone Black 2x46引脚头相连接。不需要JTAG或者繁杂的命令,只需要在树莓派或者Beaglebone Black平台的终端输入logi_loader.bit,就可以运行LOGi板。
LOGi-Pi for the Raspberry Pi
LOGi-Pi 的基本技术参数:
Xilinx Spartan 6 LX9 FPGA 9,152 Logic Cells, 16 DSP48A1 Slices, 576Kb RAM
Plug-and-Play Interfacing for the Raspberry Pi 4 Layer Optimized Design to Support Maximum Performance of High Bandwidth Applications Length-tuned GPMC, SDRAM, LVDS Signals
3.3V I/O Regulator and 1.2V Core Regulator
256 Mb SDRAM connected to the FPGA
2x LEDs 2x Push Buttons 2x DIP Switches
1x High Bandwidth SATA connector expansion, port Length tuned and impedance routed differential signals for maximum bandwidth (Designed for modular LVDS expansion, Not SATA devices - see FAQ on SATA connector)
2x Digilent Inc. PMOD ports supporting 59+ plug-and-play hardware modules
1x Arduino compatible headers connected to the FPGA pins (3.3V only) Supports over 200+ Arduino Shield Modules
10x Length-tuned LVDS Pairs 32 FPGA I/O available through PMOD and Arduino headers
Connection to the SPI Interface of the Raspberry Pi (3.8 MBps maximum Bandwidth)
Connection to 16 I/O of the Raspberry Pi expansion port (including SPI, UART, I2C and GCLK and GPIO).
Bit-Stream loading interface connected to the host processor, optional bitstream FPGA self-loading from onboard Flash.
LOGi-Bone for the Beaglebone
LOGi-Bone的基本技术参数:
- Xilinx Spartan 6 LX9 TQFP-144 FPGA 9,152 Logic Cells, 16 DSP48A1 Slices, 576Kb RAM
- Beaglebone Black Optimized 4 Layer Optimized Design to Support Maximum Performance of High Bandwidth Applications Length-tuned GPMC, SDRAM, LVDS Signals 3.3v I/O Regulator and 1.2v Core
- Regulator 256 Mb SDRAM connected to the FPGA
- 2x LEDs 2x Push Buttons 2x DIP Switches
- 1x High Bandwidth SATA connector expansion port, Length tuned and impedance routed differential signals for maximum bandwidth (Designed for modular LVDS expansion, Not SATA devices - see FAQ on SATA connector)
- 2x Digilent Inc. PMOD ports supporting 59+ plug-and-play hardware modules
- 1x Arduino compatible headers connected to the FPGA pins (3.3V only) Supports over 200+ Arduino Shield Modules
- Optional GPMC, SPI or I2C port access from the Beaglebone Black
- 10x Length-tuned LVDS Pairs
- Bit-Stream loading interface connected to the host processor, optional bitstream FPGA self-loading from onboard Flash.
更多内容请参见网站:https://www.kickstarter.com/projects/1575992013/logi-fpga-development-board-for-raspberry-pi-beagl
